View Poll Results: What gear ratio would you choose?
4.88
3 |
100.00% |
5.29
0 |
0% |
Leave as-is with 4.10
0 |
0% |
0 |
0% |
Buy yourself a sports car and leave that poor 4Runner alone
0 |
0% |
0 |
0% |
06-01-2021, 11:37 PM
Real Name: Jerod
Real Name: Jerod
Opinions on Performance Final Gear Ratio
Looking for some thoughts on final drive ratio. I have a A340E auto in my 4Runner. The first gear is just way too big. I've known that for a while but driving my friend's manual has only accentuated that fact. This it what it looks like with stock 4.10 gearing at redline in each gear with stock sized tires:
1st: 43 MPH (Slow)
2nd: 78 MPH (Seriously Toyota)
3rd: 120 MPH (Speed governor is at 110!! Again, Toyota??)
4th: Irrelevant
Cruising at 70 MPH is 2200 RPM
This is what 4.88 gears would look like:
1st: 36 MPH
2nd: 66 MPH
3rd: 101 MPH
4th: 142 (still irrelevant)
Cruising at 70 MPH is 2660 RPM
This is what 5.29 gears would look like:
1st: 33 MPH (still taller than a 5 speed)
2nd: 61 MPH
3rd: 93 MPH
4th: 131 MPH (mostly irrelevant)
Cruising at 70 MPH is 2880 RPM
What would you choose and why?
Also, not doing a manual swap. Too much work and too much money to do it. 5-speeds, even in a wrecker, cost way too much around here. Plus I don't have time for a project with 3 kids under 5.
06-01-2021, 11:57 PM
1st: 43 MPH (Slow)
4th: Irrelevant
1st: 36 MPH
2nd: 66 MPH
3rd: 101 MPH
2nd: 61 MPH
3rd: 93 MPH
I had a 3rz Tacoma with 5.29’s and 33’s and it was definitely a bit over geared feeling.. Great acceleration though.. I mean it depends on what your going for, stock tire size I’d probably go 4.56’s or maybe 4.88’s.. 5.29 seems more race car status on stock size lol..
06-02-2021, 12:29 AM
Real Name: Devan
Real Name: Devan
I mean, speed and breakneck acceleration were never part of this vehicles design but I get the jist of what you're saying. That said I've yet to hear anybody regret going with 4.88, both for on and offroad performance. That's what I was considering if I was ever in a position to re-gear
06-02-2021, 12:34 AM
Swap in some 4.30's from a Limited. Probably the best compromise. That's about a 7% change and you could find parts to swap instead of having to mess with setup.
18 Audi A6 3.0T - APR Tuned, RS6 Interior 19 Audi A6 3.0T
06-02-2021, 01:43 PM
Real Name: Jerod
Real Name: Jerod
That's great feedback. I was wondering that as well. If it felt over geared with 33's then probably too much with my 31's.
Ha, yeah I'm sort of crazy I guess. A 4Runner was never designed to go fast. But somehow I managed to make mine do just that. I've really enjoyed the process of building it up too.
If mine had the 4.30's I don't think I'd even feel the need to regear. It seems like that was the best ratio these 4Runners came with from the factory. I did also like my old Toyota Pickup's gears though, it had 4.56's in the rear with 29" tires and a manual transmission. Total slug of an engine but it was quick through those first 2 gears. Then absolutely nothing after that!
06-02-2021, 01:48 PM
Stock gearing was clearly picked for fuel economy reasons (as were the shift points in non-ECT-PWR mode). Go with the lowest gears you can stand for your highway cruising.
I'd try driving around with OD off for a while and see how it feels. OD with 5.29's would be pretty close to 3rd with the stock 4.1's on the highway.
I *personally* wouldn't want anything over about 2200 rpm on the highway - but I'm not looking for acceleration up there - I have other vehicles for that.
EDIT: I did drive around with the 29" tires and 4.1's for a bit - it is pretty big difference in pep. Then I put on the 32's and was back to normal...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
06-02-2021, 02:24 PM
I'd say it was absolutely the best ratio.
06-02-2021, 03:30 PM
Real Name: Robert');DROP TABLE Students;
4.56s and 33s are a good combo if you spend a lot of time on the interstate (I do) but 4.88s would be more fun every other time.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
06-02-2021, 07:17 PM
Real Name: Jerod
Real Name: Jerod
I have been driving a bit with O/D off and seeing if I like it or not. I absolutely love the extra power as it enters the torque curve and makes passing & onramps a real blast. My exhaust is actually quieter at 2600 and even 2880 RPM than at 2200, as it drones down low near 2100 RPM. My "commute" is 2 miles so I don't do a ton of highway driving currently. I am undecided as to if I like the 2880 cruising RPM on the highway though, which is why I asked here.
I don't spend a lot of time on the highway, except for 15-30 minute trips to Sacramento every once in a while and the occasional road trip (which is uncommon with 3 kids under 5). Most of it is city streets. Have you owned a vehicle with 4.88's as well?
06-02-2021, 08:05 PM
4.56 or 4.88
4.3 will not make much difference and 5.29 is kind of crazy unless you are going to wheel it. Now that you have been driving a manual 4runner you probably realize its not the engine that is underpowered but the auto transmission that limits the engines ability. I have both and it really is a night and day difference
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
06-03-2021, 05:55 AM
I haven't had a vehicle with 4.88s, but it sounds like you should.
My commute to work is mostly interstate, and I make a 10-12hr trip back to NC several times a year, so taking that into consideration 4.56s seemed like a better choice for me. It's only a 7% difference though and 4.88s would certainly be doable. I just wanted to keep rpms as close to the stock range as I could for highway fuel mileage and I think 4.56s do a pretty good job for the way my truck is built. It'd be perfect if my low range had deeper gears.
06-03-2021, 12:06 PM
Real Name: Jerod
Real Name: Jerod
Sounds like the consensus is 4.88. I hope to have them purchased and installed in the near future!
