View Poll Results: What gear ratio would you choose?
4.88 3 100.00%
4.88
3 100.00%
5.29 0 0%
5.29
0 0%
Leave as-is with 4.10 0 0%
0 0%
Buy yourself a sports car and leave that poor 4Runner alone 0 0%
0 0%
Voters: 3. You may not vote on this poll
Old 06-01-2021, 11:37 PM #1
gamefreakgc's Avatar
Real Name: Jerod
gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold gamefreakgc is a splendid one to behold
Real Name: Jerod
Opinions on Performance Final Gear Ratio
Looking for some thoughts on final drive ratio. I have a A340E auto in my 4Runner. The first gear is just way too big. I've known that for a while but driving my friend's manual has only accentuated that fact. This it what it looks like with stock 4.10 gearing at redline in each gear with stock sized tires:
1st: 43 MPH (Slow)
2nd: 78 MPH (Seriously Toyota)
3rd: 120 MPH (Speed governor is at 110!! Again, Toyota??)
4th: Irrelevant
Cruising at 70 MPH is 2200 RPM
This is what 4.88 gears would look like:
1st: 36 MPH
2nd: 66 MPH
3rd: 101 MPH
4th: 142 (still irrelevant)
Cruising at 70 MPH is 2660 RPM
This is what 5.29 gears would look like:
1st: 33 MPH (still taller than a 5 speed)
2nd: 61 MPH
3rd: 93 MPH
4th: 131 MPH (mostly irrelevant)
Cruising at 70 MPH is 2880 RPM
What would you choose and why?
Also, not doing a manual swap. Too much work and too much money to do it. 5-speeds, even in a wrecker, cost way too much around here. Plus I don't have time for a project with 3 kids under 5.
'98 4Runner SR5 - 4x4 JDM 5VZ-FE Supercharged - 233K miles.
326WHP 347TQ
Old 06-01-2021, 11:57 PM #2
T4topher's Avatar
T4topher T4topher is online now
T4topher is a jewel in the rough T4topher is a jewel in the rough T4topher is a jewel in the rough T4topher is a jewel in the rough
T4topher's Avatar
1st: 43 MPH (Slow)
4th: Irrelevant
1st: 36 MPH
2nd: 66 MPH
3rd: 101 MPH
2nd: 61 MPH
3rd: 93 MPH
I had a 3rz Tacoma with 5.29s and 33s and it was definitely a bit over geared feeling.. Great acceleration though.. I mean it depends on what your going for, stock tire size Id probably go 4.56s or maybe 4.88s.. 5.29 seems more race car status on stock size lol..
T4Tophers build (click here)
T4topher is online now   Reply With QuoteReply With Quote
Old 06-02-2021, 12:29 AM #3
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot is a jewel in the rough Devbot is a jewel in the rough Devbot is a jewel in the rough Devbot is a jewel in the rough
Devbot's Avatar
Real Name: Devan
I mean, speed and breakneck acceleration were never part of this vehicles design but I get the jist of what you're saying. That said I've yet to hear anybody regret going with 4.88, both for on and offroad performance. That's what I was considering if I was ever in a position to re-gear
Y2K Highlander Millennium Silver 3.4L auto @ 295k and climbing
Tundra TRD Lift in Front / LC Lift in Rear / JBA UCAs / CVJ 9168R Axles / Diff Drop / PCK / Extended Bump Stops; Brake Lines; Sway Bar Links; Rear Diff Breather / True North Fab. Hybrid Bumper / Smittybilt XRC Gen 3 Comp. / Northstar 880CCA AGM / Drivelines NW Rear Shaft / Lil Skip Gas Skid / BudBuilt Front Skid
Old 06-02-2021, 12:34 AM #4
Cree's Avatar
Cree Cree is offline
Cree will become famous soon enough
Cree's Avatar
Swap in some 4.30's from a Limited. Probably the best compromise. That's about a 7% change and you could find parts to swap instead of having to mess with setup.
00 Limited - Stuff!
18 A6 3.0T - No stuff, Just boost
Cree is offline   Reply With QuoteReply With Quote
Old 06-02-2021, 01:43 PM #5
Real Name: Jerod
Real Name: Jerod
That's great feedback. I was wondering that as well. If it felt over geared with 33's then probably too much with my 31's.
Ha, yeah I'm sort of crazy I guess. A 4Runner was never designed to go fast. But somehow I managed to make mine do just that. I've really enjoyed the process of building it up too.
If mine had the 4.30's I don't think I'd even feel the need to regear. It seems like that was the best ratio these 4Runners came with from the factory. I did also like my old Toyota Pickup's gears though, it had 4.56's in the rear with 29" tires and a manual transmission. Total slug of an engine but it was quick through those first 2 gears. Then absolutely nothing after that!
326WHP 347TQ
Old 06-02-2021, 01:48 PM #6
phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of
Stock gearing was clearly picked for fuel economy reasons (as were the shift points in non-ECT-PWR mode). Go with the lowest gears you can stand for your highway cruising.
I'd try driving around with OD off for a while and see how it feels. OD with 5.29's would be pretty close to 3rd with the stock 4.1's on the highway.
I *personally* wouldn't want anything over about 2200 rpm on the highway - but I'm not looking for acceleration up there - I have other vehicles for that.
EDIT: I did drive around with the 29" tires and 4.1's for a bit - it is pretty big difference in pep. Then I put on the 32's and was back to normal...
'16 Honda Odyssey
Old 06-02-2021, 02:24 PM #7
Cree's Avatar
Cree's Avatar
I'd say it was absolutely the best ratio.
00 Limited - Stuff!
Old 06-02-2021, 03:30 PM #8
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree has a spectacular aura about thezentree has a spectacular aura about
thezentree's Avatar
4.56s and 33s are a good combo if you spend a lot of time on the interstate (I do) but 4.88s would be more fun every other time.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 06-02-2021, 07:17 PM #9
Real Name: Jerod
Real Name: Jerod
I have been driving a bit with O/D off and seeing if I like it or not. I absolutely love the extra power as it enters the torque curve and makes passing & onramps a real blast. My exhaust is actually quieter at 2600 and even 2880 RPM than at 2200, as it drones down low near 2100 RPM. My "commute" is 2 miles so I don't do a ton of highway driving currently. I am undecided as to if I like the 2880 cruising RPM on the highway though, which is why I asked here.
I don't spend a lot of time on the highway, except for 15-30 minute trips to Sacramento every once in a while and the occasional road trip (which is uncommon with 3 kids under 5). Most of it is city streets. Have you owned a vehicle with 4.88's as well?
326WHP 347TQ
Old 06-02-2021, 08:05 PM #10
St Runner's Avatar
St Runner St Runner is offline
St Runner will become famous soon enough
St Runner's Avatar
4.56 or 4.88
4.3 will not make much difference and 5.29 is kind of crazy unless you are going to wheel it. Now that you have been driving a manual 4runner you probably realize its not the engine that is underpowered but the auto transmission that limits the engines ability. I have both and it really is a night and day difference
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
St Runner is offline   Reply With QuoteReply With Quote
Old 06-03-2021, 05:55 AM #11
thezentree's Avatar
thezentree's Avatar
I haven't had a vehicle with 4.88s, but it sounds like you should.
My commute to work is mostly interstate, and I make a 10-12hr trip back to NC several times a year, so taking that into consideration 4.56s seemed like a better choice for me. It's only a 7% difference though and 4.88s would certainly be doable. I just wanted to keep rpms as close to the stock range as I could for highway fuel mileage and I think 4.56s do a pretty good job for the way my truck is built. It'd be perfect if my low range had deeper gears.
Old 06-03-2021, 12:06 PM #12
Real Name: Jerod
Real Name: Jerod
Sounds like the consensus is 4.88. I hope to have them purchased and installed in the near future!
326WHP 347TQ
1st , 2nd , 3rd , 4th , mph
Final Drive Ratio Compatability ?? AusTex4x4Sport 3rd gen T4Rs 7 06-15-2015 02:26 AM
Gear Ratio Opinions, 4.30 vs 4.56 coinball 3rd gen T4Rs 7 12-29-2014 01:08 PM
Final Drive Ratio cdn87 4th Gen T4Rs 7 10-21-2011 10:49 PM
Final Drive Ratio between Limited and SR5? Robb235 3rd gen T4Rs 9 06-14-2011 09:56 PM
Is there a tool to calculate how taller tires well affect final drive ratio? 4RunnERD 4th Gen T4Rs 9 04-25-2011 04:25 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
