Old 06-02-2021, 04:48 PM #1
Nology's Avatar
Nology Nology is offline
Nology is on a distinguished road
Nology's Avatar
Stock tires rubbing after alignment?
I recently put on some Falken Wildpeak tires in the stock size and had an alignment. After the alignment, I started getting some tire rub on the left side mud flap. I went through the paperwork and realized I never got a print out of the specs so I can't see exactly where everything is at. I've seen countless threads of this happening with larger tires and a lift but don't recall seeing any with stock tires.
Stock tires rubbing after alignment?-img_9395-jpg  Stock tires rubbing after alignment?-img_9394-jpg
Nology is offline   Reply With QuoteReply With Quote
Old 06-02-2021, 04:59 PM #2
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Mud flap? Are you referring to the rear tires? If so it's solid axle and does not receive alignment. Maybe they rotated them around and a slightly larger one got swapped in, now causing rubbing?
In any sense, caster angle is what determines how far forward your wheel is, so if by some chance you're referring to the front I'd just go back and ask them to increase it/set it back to where it was
Edit: just realized they're brand new. Could be the size of the tread being increased opposed to what you had previously. I'm assuming you didn't notice rubbing before the alignment when you still have them on, at least
Old 06-02-2021, 05:12 PM #3
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
My 285s fit better than that. I'd take that back and let them have the opportunity to try again.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 06-02-2021, 05:25 PM #4
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Pretty sure rear wheels receive a toe and camber adjustment. I always get a "4 wheel alignment" (for $50 using a Groupon - old school) and the sheet has different degrees noted before/after for the rears. I pulled my mud flaps before I tired-up, so no help there.
Old 06-02-2021, 06:06 PM #5
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
I'd love to see where these alignment cams are then, cause I have a strong feeling they're jerking you around.
Old 06-02-2021, 06:28 PM #6
Real Name: Blair
Real Name: Blair
They never mentioned it. Some kind of black magic I suppose......that's Big-O Tires for ya! It makes no sense. I know you can adjust thrust angle on a leaf spring rear end....
Old 06-02-2021, 06:31 PM #7
They'd have to really pull the caster down to get the tire back that far. You say stock sized tire - can you confirm the actual numbers on the side of the tire?
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 06-02-2021, 06:39 PM #8
Nology's Avatar
Nology's Avatar
That's with the tire turned closest to where it rubs. It only rubs in reverse. Tire size is 265/70R16.
Old 06-03-2021, 01:42 PM #9
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
There is no way to adjust toe and camber on the rear axle. If you have adjustable upper and lower control arms then you can change the pinion angle and the thrust angle of the axle but that's it. You are really only get a front end alignment.
Old 06-03-2021, 02:28 PM #10
Real Name: Blair
Real Name: Blair
I wonder what the hocus-pocus they put on the sheet is all about. If I ever get another alignment from them, I'll call them on it.
Old 06-03-2021, 02:46 PM #11
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
You still get camber & toe readings for the rear wheels but they're not adjustable on the rear solid axle.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 06-03-2021, 03:20 PM #12
Real Name: Blair
Real Name: Blair
Yep but how is it that they appear to change somewhat on the printout before/after the fronts are adjusted? Is it a result of an altered front stance? Seems odd, if so...
Old 06-03-2021, 05:06 PM #13
fourfive's Avatar
fourfive's Avatar
The changes in the rear toe & camber during a front end alignment is usually pretty minimal but yes, my experience has been as the front end alignment changes, it has a mild impact on the unadjustable rear wheels.
Old 06-03-2021, 05:11 PM #14
Real Name: Patrick
Real Name: Patrick
Even the laser alignment machines aren't as accurate/repeatable as everyone is made to think. They are much better than the old style "analog" alignment machines but they still aren't perfect. During the alignment process most laser alignment machines require you to roll the vehicle either forward into position or backward then forward to where it was in order to measure camber. In order to get a caster reading the steering wheel needs to be rotated one way, then the opposite direction, then centered. All of this movement can cause sensors to change from the original positions resulting in a slight change in the rear alignment. Typically 0.01-0.03 changes in rear toe throughout that process are normal to see. I have seen rear alignment measurements change more than that due to bent parts or bad bushings allowing for more movement.
Old 06-03-2021, 05:48 PM #15
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Like I said, they're jerking you around most likely. """Alignment technicians""", if you can even call them that, are as sketchy as lube techs. You give them an inch of ignorance and they take a mile
But I just don't trust many mechanics so I'm always skeptical of getting shafted somehow
alignment , countless , specs , stock , tires
Stock Tires Rubbing?? DavidR1 5th gen T4Rs 6 10-04-2019 07:27 AM
Stock tires rubbing Brown2mu 5th gen T4Rs 5 02-27-2019 03:36 AM
Alignment Help !!! : Rubbing tires dreyday 3rd gen T4Rs 8 12-29-2018 10:40 PM
Rubbing on stock tires? simple 4th Gen T4Rs 9 02-08-2017 09:25 AM
Biggest tires without rubbing on stock '03 SR5 Ohcrymore 4th Gen T4Rs 19 11-19-2014 03:48 PM
