Old 06-05-2021, 11:05 PM #1
5VZ-FE's Avatar
5VZ-FE 5VZ-FE is offline
5VZ-FE will become famous soon enough 5VZ-FE will become famous soon enough
5VZ-FE's Avatar
ABS toggle switches
The two OTRATTW switches on the left turn my ABS system on and off. The mod was installed by the previous owner and I’ve never really used it, but might as well keep it since he went through the trouble of putting it in. The issue is I’m out of blank spaces for switches and I need somewhere to put the switch for my arb compressor. I’m not experienced with electrical so I don’t know how hard it would be to find a switch that combines the two ABS switches. So it would be;
Position 1: Both off
Position 2: First switch (lower one) on
Position 3: Both on
Another thing:
You’ll notice in the picture that both switches are on, and in that situation the abs system is on. I want the abs system on 99% of the time, but when I get in I always inadvertently hit the lower switch with my knee. It would be easy to change which way is on and which way is off, right?
Thanks
‘98 T100 SR5 4X4 5spd (sold)
‘99 4Runner SR5 4x4 5spd E-Locker Unicorn
5VZ-FE is offline   Reply With QuoteReply With Quote
Old 06-06-2021, 01:42 AM #2
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
I know this isn't really related by why/how the hell is your mirror adjustment up there What's on the door panel then?? Or is this just something different between years?
In regards to moving switches you should be able to pop that out pretty easily once that trim piece is off. Unfortunately it doesn't look like you have/they used the removable switch panels that usually go there so I have a feeling you'll have a gaping hole there afterwards
Old 06-06-2021, 04:03 PM #3
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
You could ditch those two switches and consolidate into something much cleaner, like one toggle switch. Looks like the the previous owner accomplished his goal, but not in a very logical way.
Here's what I did:
OTRATTW parts:
1. Switch:
SKU: V1D2UXXB- Contura V Upper and Lower LED Independent rocker switch
2. Switch rocker cover:
SKU: VVAXCYT-HAH - Contura II – custom text rocker switch, rocker only. Top line ABS on, Bottom Line ABS off
Wired it up to cut power to the ABS module. 1 Relay for logic, 1 relay for power cut to the module.
Now it’s a LED-lit toggle switch. LED appears on the top or bottom, in the position it’s in (off or on)
Here it is in action:
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 06-06-2021, 04:44 PM #4
5VZ-FE's Avatar
5VZ-FE's Avatar
The previous owner put the mirror control there when he swapped to manual windows. When I switched back I put the master window switch in, with the mirror adjustment control, but I haven’t switched the wires back over yet. I’m not sure if the extremely small number of 3rd gens with OEM manual windows came with power mirrors, but if they did it makes sense that the double-wide spot on the dash would be there for those controls.
As to the switches, I’m not looking to move them so much as consolidate two switches into one, and then put the ARB switch where one of the two OTRATTW switches was. So I’m not going to need one of the blanks that were originally there.
Old 06-06-2021, 04:49 PM #5
5VZ-FE's Avatar
5VZ-FE's Avatar
ABS toggle switches
Here's what I did:
OTRATTW parts:
1.Switch:
2.Switch rocker cover:
This is exactly the kind of solution I’m looking for. However, I don’t think a two-throw ‘on/off’ switch would work with the way it was wired. For the abs to be on, both switches have to be up/on, and vice versa for it to be off. I think your solution would work if only one of them was on at a time, right?
The other thing is that I’m not really sure how it’s wired to the abs module and I know there are definitely a few different ways of doing it, so I’m not actually 100% sure what each switch is doing, though I do know the bottom one turns off the speedometer.
Old 06-07-2021, 01:40 AM #6
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about
2TH4IST's Avatar
@WeakSauz mind if you share how you wired this up? Been looking for a switch to shut it off as abs has almost killed me off road a few times.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 06-07-2021, 07:57 AM #7
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
ABS toggle switches
Me too. This is on my list to figure out a one-switch, on-the-fly ABS toggle (that preserves speedometer functionality), but if @WeakSauz has already done the heavy lifting…
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
abs , position , switch , switches , system
Toggle in my fuse panel 46runner 4th Gen T4Rs 4 12-07-2014 09:57 AM
Map light toggle switch dakine_999 4th Gen T4Rs 3 06-19-2013 03:20 PM
Toggle switch on a condenser fan? 4runner86 Classic T4Rs 4 10-22-2012 09:46 PM
Adding toggle switch for DRL Cas5Id4 3rd gen T4Rs 17 07-05-2010 11:46 AM
NEED help ECT button won't toggle? RadRunner 3rd gen T4Rs 7 02-16-2010 01:34 PM
