Old 06-11-2021, 10:35 PM #16
D'arce D'arce is offline
D'arce will become famous soon enough
Originally Posted by Bad Luck View Post
From the Barnes installation instructions:
"Fill the differential with the factory recommended weight gear oil. Fill the differential until the oil reaches half way up the ring gear." Step number 13: https://www.barnes4wd.com/assets/ima...structions.pdf
Going to be hard to tell what's halfway up the ring gear by looking through the fill hole. I have a spare axle assembly I'm going to sight a line across the axle tube to the fill hole and see if I can make some kind of depth reference for a dipstick as mentioned earlier. The fluid capacity should change very little I'd think from stock. I'll start with 2.9 quarts and see what happens. Excited to get this beast back on the road.
1996 4Runner with a 3rz-fe, e-locker and 5spd
2005 Passat TDI 5spd swapped
1997 E350 4x4 7.3 Powerstroke
D'arce is offline   Reply With QuoteReply With Quote
Old 06-12-2021, 02:27 PM #17
MarkamisPrime's Avatar
MarkamisPrime MarkamisPrime is offline
MarkamisPrime will become famous soon enough MarkamisPrime will become famous soon enough
Your over thinking it.
More fluid = less heat
Just fill it as you normally would and call it a day
2012 TRD Tacoma wheels
Grey wire mod
Toytec ultimate lift w/super flex rear coils
1.25 spidertrax coming soon
MarkamisPrime is offline   Reply With QuoteReply With Quote
Old 06-12-2021, 09:08 PM #18
Yeah I agree. I dumped in 3 quarts and call it good. While under the truck I noticed I was a quart low in the t case. Now I have to check everything lol.
axle , barnes , cover , rear , sitting
WTB: Philadelphia- Non rusty 3rd gen rear axle of rear axle cover 4:10 Temple90 Want to Buy/Trade 0 05-14-2019 12:34 PM
request for 2wd rear axle fluid type and amount needed keakar 4th Gen T4Rs 32 08-18-2018 12:31 AM
Rear Axle Fluid Fill Plug Stuck hungryeddy Classic T4Rs 13 10-10-2017 12:35 PM
Brake fluid/dash light situation/ fluid level FlaskTL 5th gen T4Rs 19 06-03-2015 10:53 PM
difficulty level installing URD supercharger kit? Jc12 3rd gen T4Rs 5 03-20-2013 12:35 AM
