Old 06-07-2021, 03:00 PM #1
lawrencesam74's Avatar
lawrencesam74 lawrencesam74 is offline
Real Name: Samuel
lawrencesam74 is on a distinguished road
Real Name: Samuel
Rounded Fuel Filter Nut
Howdy all,
Im in a tight pinch! Just got done with a beautiful tundra brake upgrade on my 97 limited and thought "while the truck is in the air, why not change the fuel filter?"
Well I've gone and done it, the fitting on the gas tank side came out easy, however the engine side fitting is pretty damn round. Tried to be easy on it, but as soon as it gave it was gone, and the fitting is really stuck on there as well.
Now I think I have three options:
1. Try to do the oil filter technique where you drive a screwdriver through it and try to turn it lose of the filter side? No too keen on this one since the nut is so rounded, I think the wrench will just slip off.
2. Get a fuel line repair kit. I think this is a good option but am not too sure how it will go since there is a bend in the hard line not too far off the filter so I guess I may need to get a pipe bender and do some guess work or some careful measuring.
3. Whole new hardline from Toyota. Don't know how much the line costs at the dealership but I think I found the part number for about $45 online. Seems like a tough job to replace it .
Any advice or ideas much apreciated!
77251-02080 - Genuine Toyota TUBE, FUEL MAIN
lawrencesam74 is offline   Reply With QuoteReply With Quote
Old 06-07-2021, 04:19 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Originally Posted by lawrencesam74 View Post
Howdy all,
Same thing happened to my 97 5 speed. I ended up just changing the hard line to the engine. you can snake it through there and in without taking a part too much except for some vacum lines etc.
Best to have the hard line in your possession before messing with it anymore.
Then after having all your parts in hand. Cut the fuel line at the filter. Replace the line and filter.
Keep in mind, If your tank is full and has fuel in it. You may get a seep coming through of gas. So have something to catch the gas coming from the tank Line if yours seeps too.
Also double check that tube...
When i hit the link it says it not capable with a 1997 v6 limited says for a
for a 1998-2002 Toyota Corolla CE, LE, S, VE|4 Cyl 1.8L
this one is
77251-3D140 - Genuine Toyota TUBE, FUEL MAIN)
As I checked my log and mine was this part number
Part Number: 77251-3D140
Old 06-07-2021, 04:33 PM #3
spartacus's Avatar
spartacus spartacus is online now
spartacus's Avatar
If you you tried pb blaster and a line wrench or flare nut wrench and it's a no go. Just cut the line then put a flare nut on the engine side. Then measure and cut another line going to the tank from'the filter since that line has to get longer by the same amount you cut from the engine side. It's going to be a pita. Good luck.
spartacus is online now   Reply With QuoteReply With Quote
Old 06-07-2021, 05:24 PM #4
Real Name: Samuel
Real Name: Samuel
for a 1998-2002 Toyota CorollaCE, LE, S, VE|4 Cyl 1.8L
this one is
sounds good, thanks for checking that link for me. glad to hear that it’s not TOO hard to replace the whole line so that may be what i end up doing. thank you!
Old 06-07-2021, 07:07 PM #5
zedjr zedjr is offline
zedjr is on a distinguished road
they make socket tools to get rounded nuts off
zedjr is offline   Reply With QuoteReply With Quote
Old 06-08-2021, 07:48 AM #6
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Something tells me the PO didn't have a set of flare nut wrenches. If you don't I'd grab some asap
And how exactly do you plan to get a socket on it...?
Old 06-08-2021, 10:23 AM #7
Wedgy's Avatar
Wedgy Wedgy is offline
Wedgy has a spectacular aura about Wedgy has a spectacular aura about
Wedgy's Avatar
These; Double-End Metric Flare Nut Wrench Set, 5 Pc.
Rounded Fuel Filter Nut-flair-jpg
Wedgy is offline   Reply With QuoteReply With Quote
Old 06-08-2021, 01:11 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Always use line wrenches on lines.. I did and my still rounded soaked with penetrating oil. Besides once rounded your screwed and it needs replaced with a new flare nut. besides that line isnt that hard to get in. I changed it on my 5 speed with some wiggling and some basic line removal for room.
Mine was never changed until 2017. Hence why mine was rusted on. :-(
Old 06-08-2021, 02:39 PM #9
davidch davidch is offline
davidch will become famous soon enough
Originally Posted by Wedgy View Post
Some have better luck with H-F flare nut wrenches than I had.
Rounded Fuel Filter Nut-hf-wrench-jpg
davidch is offline   Reply With QuoteReply With Quote
Old 06-08-2021, 06:09 PM #10
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Good god, you cant make this up
Old 06-08-2021, 07:29 PM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Thanks for sharing. Now I know the HF flare nut wrenches are junk. :/ mine are craftsman.
Old 06-09-2021, 05:13 PM #12
Real Name: Samuel
Real Name: Samuel
my bad, should’ve disclosed that i have some gear wrench flare but wrenches and soaked in PB blast. i ended up cutting the line and doing a repair with a dorman fuel line repair kit from pep boys. worked out fine and should work, lemme know if anyone wants pics
Old 06-09-2021, 05:31 PM #13
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Always have to have pictures.. Glad the dorman Fuel line repair kit patched you up and on the road again..
Old 07-19-2022, 09:38 AM #14
JBDaddy JBDaddy is offline
JBDaddy is on a distinguished road
Just documenting my experience for anyone else who gets to this thread via search and thinks "Yes! That's what I'll do"...
The dorman kit I got from Amazon Amazon.com: Dorman 800-151 STEEL FUEL LINE REPAIR KIT. 5/16 IN. x 18 IN. w/14mm FITTING. : Automotive doesn't fit the threads on the OEM fuel filter.
I ended up having to buy an OEM forward fuel line -- which arrived bent in half and creased, dammit. Like it was packed into the shipping box that way - not damaged in shipping. Argh.
So instead of replacing the whole thing, I was able to cut just the half I really needed off and patch that into my existing forward fuel line, and the threads on it fit fine into my fuel filter.
Save yourself grief - don't try and thread the dorman kit. just use 2 compression fittings to replace a length of fuel line with it.
If you can't get your fuel filter disconnected from the OEM fuel line, get a new OEM fuel line - it's less hassle.
Just a programmer who likes to wrench and always wanted a 4x4.
1998 Limited, Auto, 4WD, 275k. No name, no boasts.
JBDaddy is offline   Reply With QuoteReply With Quote
Old 07-19-2022, 03:37 PM #15
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
flare wrenches X100
ive twisted wrenches for a long time....but for fuel lines, brake lines...flare wrenches....and of course if dirty/rusty...pb blaster daily. for many days ahead of job... dont use heat/flame
filter , fitting , fuel , line , side
Fuel leak stops. Now have a blue liquid on outside of fuel filter. Hard start getting 3rdgen_4runner 3rd gen T4Rs 2 09-05-2017 10:23 AM
Repeated fuel filter clog, failing fuel pump, or ? hour 3rd gen T4Rs 74 10-09-2016 12:58 PM
If I ever strip the nuts that screws the fuel lines onto fuel filter trdrun 3rd gen T4Rs 20 06-25-2013 04:01 AM
FS: 96-01 Fuel Filter, Oil Filter, & Spark Plugs Package: $30 DudeMan For Sale: T4R Items 2 06-05-2013 01:45 PM
Fuel Pump Filter / Sock - Inline Filter 86SupraMKII 3rd gen T4Rs 1 08-15-2012 08:17 AM
