Old 06-09-2021, 03:55 AM #1
jzarech's Avatar
jzarech jzarech is offline
jzarech is on a distinguished road
jzarech's Avatar
Hum/Growl/Vibration at 70MPH while stepping on Gas
After getting a new engine and new tires -- 318,000 miles on my 1997 4Runner 4WD I notice that it vibrates a TON at 70mph and faster. At first I thought my new tires, Goodyear Wrangler's, were causing the noise or something tire related. I called a few Toyota experts - watched all the YouTube videos I could find and called Yota1 Performance (thanks Nick and crew you rock!) -- and since the noise didn't happen when the truck was on the hoist and ONLY HAPPENED WHEN ON THE GROUND AND I WAS STEPPING ON THE GAS -- it came down to these 4 possibilities --
Wheel Bearings
Driveline
Torque Converter Shudder (but rpm's didn't flutter so I didn't think it was this)
Front or Rear Differential Bearings
With this checklist in hand (all the experts I talked to agreed it was one of these things) the quest to solve the mystery began.
First shop was a differential shop and they said rear diff bearings were shot so replaced them along with shims.
Hop on Freeway after replacing the rear diff bearings and noise is still there.
Second shop lifts it on hoist and brings it up to 70 mph and notices that the rear transmission mount is broken as well as the Dynamic Damper (bolted to side of transfer case heavy rubber thing). I fix those and hop on freeway and problem still there.
Third Shop, Manny's Transmission in North Hollywood, bring it in to check the wheel bearings and explain the problem and Armando the owner says "stop talking just tell me the symptom" I tell him horrid noise and vibration at 70mph and higher -- he says "Go home - I'll call you when it's fixed."
A couple of hours later it's fixed! Wasn't the wheel bearings either.
It was a rear driveshaft front yoke with worn splines allowing driveshaft to flex at high speeds along with a super-worn super-non-lubed u-joint. I take it on the freeway and it purrs like a kitten! Yay!!!
I'm posting this because everywhere I searched for a solution to a 70mph hum vibration for a 3rd Gen 4Runner there's never a solution -- I only found guesses. Really expensive guesses.
So, at least in this case, I found the solution and it's way cheaper than wheel bearings and rebuilding differentials etc...
Start at a great transmission shop and hopefully save some bucks.
Thanks and good luck.
Joseph
jzarech is offline   Reply With QuoteReply With Quote
Old 06-09-2021, 12:46 PM #2
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 will become famous soon enough Malcolm99 will become famous soon enough
Malcolm99's Avatar
Interesting, what companion flange yoke did he replace it with, Toyota quoted me $396 for #33309-35091..., tempted to try one off my other parts 4Runner but itís probably a ball of rust or no better.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 06-09-2021, 04:13 PM #3
jzarech's Avatar
jzarech's Avatar
It was a used Toyota OEM part (I double checked with him). He showed me the worn out part and you could see some of the splines were erased looking almost. 318,000 miles on the original part though -- not too shabby.
Here's a pic of the part after the fix -
Old 06-10-2021, 07:41 AM #4
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree has a spectacular aura about thezentree has a spectacular aura about
thezentree's Avatar
3330935091 Toyota FLANGE SUB-ASSY, OUTPUT SHAFT COMPANION, Price: 88.19$, Weight: 1.043kg - PartSouq Auto Parts Around the World
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 06-10-2021, 09:42 AM #5
Malcolm99's Avatar
Malcolm99's Avatar
Thanks Jz. And I don't order things from across the world except for Japan if I can avoid it, have you ordered stuff from Dubai before.
Old 06-10-2021, 10:20 AM #6
thezentree's Avatar
thezentree's Avatar
Yeah on several occasions. Partsouq is good to go in my experience.
70mph , bearings , rear , shop , wheel
Front End Vibration at 70mph Rusty Shackleford 3rd gen T4Rs 20 01-27-2021 10:06 AM
Vibration at 70MPH Tha Krazy One 3rd gen T4Rs 29 11-10-2020 06:01 PM
Growl in front end CDM4RSD 4th Gen T4Rs 6 12-19-2016 07:48 PM
Rear End Growl.... jp4runner Classic T4Rs 10 12-12-2010 01:29 PM
vibration/growl coming from front end --> help channer 4th Gen T4Rs 3 12-03-2004 07:11 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
