Old 06-16-2021, 03:42 PM #16
3bears 3bears is offline
Real Name: 3 Bears
3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light
Real Name: 3 Bears
well,, 200 miles and several days and the light is back. so prob a pluged converter. someone said pack the adapter I put in with steel wool. might try that , otherwise guess live with it. not going to by a cat where inspections are not required. runs good, gets 16+mpg this time of year
2000 SR-5 Highlander. 4:30's, factory locker green bought june 2021
2001 SR-5...sold june 2021
2000 SR-5 V6 Auto . lifted, e locker, other cool stuff, totaled 10/20
Old 06-16-2021, 03:58 PM #17
Real Name: 3 Bears
Real Name: 3 Bears
Talking
Old 06-16-2021, 09:19 PM #18
19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light 19963.4lsr5 is a glorious beacon of light
p0420 code again
Do you need to add antifreeze to your overflow tank on occasion?
Do you have any exhaust leak?
Old 06-18-2021, 01:56 AM #19
Real Name: 3 Bears
Real Name: 3 Bears
this is on my 2001
hard to say on both....it has an exhaust leak but its after the muffler.
not adding antifreeze very much. maybe a few sips in 500 miles, but ive had a freeze plug block heater that was seeping ( fixed the other day). I hope its not a headgasket issue. The light has been on ever sice I have owned it, and the lady I bought it from said it had been on for a while., Does not overheat, passed a leak down and the dye test on radiator that checks for exhaust gas in cooling.
Old 06-18-2021, 10:55 AM #20
tubby45 tubby45 is offline
tubby45 is on a distinguished road
Had the same issue. Owner before me had the same thig replaced the O2 sensors. I did it about a year later and it just seemed to be a temporary fix of 3-4 months. After consulting with a local 4Runner mechanic and the internet I finally opted to replace the cat convertor. Since doing that over 2 years ago I've had no issues with the code at all.
Forgot to say - the mechanic was able to pin point it being the cat convertor and not a sensor based on testing it. He would measure before and after the cat to see what levels were at. Since they were the same before and after he could deem the cat done for.
tubby45 is offline   Reply With QuoteReply With Quote
Old 06-18-2021, 06:01 PM #21
FD7683 FD7683 is offline
FD7683 will become famous soon enough
I had this issue as well recently but it went away after a week of being on. It was the o2 sensor code after the cats.
2000 4Runner Limited 4x4 Sport Edition V6
Old 06-18-2021, 06:06 PM #22
Endlessblockades's Avatar
Endlessblockades is just really nice Endlessblockades is just really nice Endlessblockades is just really nice Endlessblockades is just really nice
Just for the hell of it can you patch the exhaust leak (even though it's beyond the muffler) with some type of metal wrap?
Y2K/E - SLOW AND LOW
Old 06-20-2021, 11:43 AM #23
giguchan's Avatar
giguchan giguchan is offline
giguchan will become famous soon enough
giguchan's Avatar
Originally Posted by spartacus View Post
The Sawzall method should work even on frozen cams.
"Sawzall" method! Nice!
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 192K
Cheers
giguchan is offline   Reply With QuoteReply With Quote
Old 06-20-2021, 10:58 PM #24
brillo_76's Avatar
Real Name: Jon
brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold
brillo_76's Avatar
Real Name: Jon
Being it's on the 01 and those have 2 cats with 4 sensors wide band. Those will detect a high airflow burned out cat error.
My 02 Camry had that error and it was the front cat burn through.
So being it disables the VSC and Trac with the CEL on. What happens when you put a spacer with 2 gaskets on the 2nd O2 sensor after the first cat?
5 3rd gens listed in the build thread
Old 06-21-2021, 02:30 PM #25
Bad Luck Bad Luck is online now
Real Name: Patrick
Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold
Real Name: Patrick
01 and 02 have 4 oxygen sensors? I thought they only had 2 of them total similar to the Cali emissions 4Runners from earlier years.
2000 Limited V6 Auto E-Locker
Bad Luck is online now   Reply With QuoteReply With Quote
Old 06-21-2021, 02:42 PM #26
Chris_Overland's Avatar
Chris_Overland Chris_Overland is offline
Chris_Overland is on a distinguished road
Mine really never goes away, went away after changing the rear O2 sensor a few weeks ago, just to come back. I gave up.
1999 Imperial Jade Mica Limited
Bilstein 5100 & OME 881/891
SpyderTrax 1.5 spacers
Tundra brake upgrade
238,000 and still kickin
Chris_Overland is offline   Reply With QuoteReply With Quote
Old 06-21-2021, 03:38 PM #27
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I will verify but I thought they had more then 2 as the federal emissions of 96-00. I will report back when i look under my 01 sport
Old 06-21-2021, 09:07 PM #28
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Correction thanks to bad luck. I thought they had more than 2 02 sensors but the 3rd gen has 2. I work on too many different Toyota vehicles in my fleet..:/
Old 06-21-2021, 10:39 PM #29
Real Name: 3 Bears
Real Name: 3 Bears
for some magic reason, today it was not on....dont get it...yet i found another way to get the cel light out of my face.........the 2001 is for sale.....I will be honest, if the light is off, I will tell someone that it will pop on and what it "could" indicate
but shcuks I drove it for 6 months with it on....in the winter/snow
light , lights , p0420 , point , vsc
P0420 code vtferret 3rd gen T4Rs 39 06-22-2019 09:58 PM
98 3rd Gen 2.7 P0420 code now P0401 mortreport 3rd gen T4Rs 4 01-10-2017 12:27 AM
Code P0420 Roost General Discussions 1 02-08-2015 03:21 PM
Code P0420 help mgcorreia 3rd gen T4Rs 3 09-25-2013 10:06 PM
P0420 code. Please help! AlexaG. 4th Gen T4Rs 3 01-09-2013 04:36 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
