Old 07-05-2021, 09:48 PM #31
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Originally Posted by 96RedRunner View Post
Look at a parts page for it, I'm talking everything you take off from a 01 limited it adds up.
That's what I was talking about, I don't see it adding up when you look at all the steel going on vs what's been removed. It's just the bumper, lights/brackets and cross member right? I know some OEM bumpers were reinforced but those only tack on another 20ish pounds I thought
Old 07-05-2021, 09:53 PM #32
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
i think the weight includes the weight of the reinforcement bar & attachments that connect to the horns of the ladder frame
Originally Posted by Devbot View Post
The big ol plastic fatlip weighs like 20lbs total though? Weighed absolutely nothing when I took mine off
Every so often someone talks about how the front bumper is 100-something pounds and I dont have a damn clue where this comes from
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 10:16 PM #33
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
All I can tell you good scales don't lie vs I don't see it adding up.
I can't weigh it again sold fatlip shortly after taking it off.
Didn't weigh each piece set bumper on scale put rest of junk in bumper.
Old 07-06-2021, 12:41 AM #34
4x3Lander's Avatar
4x3Lander 4x3Lander is offline
4x3Lander will become famous soon enough 4x3Lander will become famous soon enough
4x3Lander's Avatar
Fatlip mid 90#'s AOR plate 105#'s approx.
Something to check before paint, the lower tubes topside where they tie into center section is hard to get at welding
a side didn't get fully welded. Rain/water will get in the tube wind from driving will force water out leave you
rust colored water trails on bumper and frame until water evaporates.
Didn't catch this till after paint clear silicone to the rescue, can't see it lasts till it doesn't.
Also this may not happen on all bumpers.
I will definitely take a look at mine when I get it. Good tip!
2002 4Runner Sport Edition - 4WD auto / 3” lift / 33” tires
4x3Lander is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 12:48 AM #35
jrkiernan's Avatar
jrkiernan jrkiernan is offline
Real Name: Josh
jrkiernan will become famous soon enough
jrkiernan's Avatar
Real Name: Josh
I ordered my bumper in April and have been trying to see what winch they recomend as I would prefer not to cut the grill unless I have to. But no return emails or phone calls. So any info would be great. I ordered the plated bumper.
Thanks,
jrkiernan is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 12:52 AM #36
4x3Lander's Avatar
4x3Lander's Avatar
Thanks,
Mine was March 1, so let’s see who gets theirs first
I will be installing a winch as well, but not right away. I will finalize which one I go with once I get the bumper installed. I will let you know anything I hear from AO as soon as I do.
Old 07-06-2021, 02:37 AM #37
JUICE222 JUICE222 is offline
JUICE222 is on a distinguished road
Thanks,
I’m in the process of installing an X2O 10k winch on my AOR tube bumper. It appears I will be doing some minor trimming on the grill.
JUICE222 is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 03:31 AM #38
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Thanks,
When I was waiting for mine I emailed about what winches fit and there was a pretty small list of like 4-5 that fit (didn’t save the email). I ended up going with the smittybilt 9.5k synthetic. First out of laziness I mounted the control box on top of the winch and did some super minor trimming on the grill. Then I relocated the control box into the passenger wing of the bumper and wouldn’t of had to trim the grill at all. One thing to note if you mount the control box on top is you will most likely have to remove the control box to remove your grill which is a PITA.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 02:14 PM #39
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Fwiw OP the XRC Gen 3 is slightly smaller than the X20 and nominally lighter
Old 07-07-2021, 12:07 AM #40
4x3Lander's Avatar
4x3Lander's Avatar
Thank you both as that’s useful info to know! I was potentially considering these:
WARN 103255 VR EVO 12-S
Smittybilt X2O COMP
Will see if I do go with them or not. I don’t foresee the need to remove the grill once this is all done since I will replace the radiator too, but might be better if I mount the control box as mentioned.
Old 07-07-2021, 12:20 AM #41
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Smittybilt X2O COMP
If you're taking votes I'd go for Warn over SB any day of the week. They're spendy but they're much better quality and have outstanding customer service
Fwiw I also have my box in my passenger wing, seems pretty common. I believe it technically would fit in either wing if your wiring lets you
Old 07-07-2021, 09:35 PM #42
4x3Lander's Avatar
4x3Lander's Avatar
I have always been partial to Warn since I was much younger, but wanted to keep a second option open in case. I will probably go with the Warn though.
Good to know that. I will see where I can mount it!
Old 07-08-2021, 08:00 AM #43
Real Name: Mark
Real Name: Mark
I used a SB XRC8 for 10 yrs never a problem worked the many times I used it got totaled when 96Red did in 18.
Bought SB 9.5 Syn for the 01 in 18 been working fine with couple dozen pulls on it so far. Don't need it alot so I went cheaper.
With AOR Plate cutting the grille depends on what year Runner you have. Pre 99 no trimming needed, 99-02 needs it.
Swapped a 96-98 grill onto 01, 2-2 1/4" difference in the two. Just saying.
Old 07-08-2021, 08:51 AM #44
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Have had an XRC8 on our CJ for 10-20 years now, that thing will not die What's sad is that XRC8 is infinitely better quality than my new XRC G3, but I guess that's just the way the world works. Most manufacturers see no reason or benefit to build something that'll last anymore.
What do you mean by "SB 9.5k synth" - what winch do you have now? Those are just the specs
Old 07-08-2021, 09:29 AM #45
Real Name: Mark
Real Name: Mark
XRC 9500 synthetic rope, whatever Gen it was in 2018.
Nothing lasts like it use to.
bumper , online , order , status , weeks
More than 13 weeks and no bumper - Addicted Offroad (AoR) dreyday General Discussions 27 11-07-2018 04:33 PM
Addicted Offroad's new 120 chassis bumper AddictedOffroad 4th Gen T4Rs 99 08-11-2014 04:04 PM
Addicted Offroad's new FJ Cruiser bumper AddictedOffroad Addicted Offroad 9 04-10-2014 10:20 AM
My Addicted Offroad winch bumper dustin Keeler 3rd gen T4Rs 21 06-23-2013 09:40 AM
