Old 07-09-2021, 01:20 AM #46
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Originally Posted by 4x3Lander View Post
Thank you both as that’s useful info to know! I was potentially considering these:
WARN 103255 VR EVO 12-S
Smittybilt X2O COMP
Will see if I do go with them or not. I don’t foresee the need to remove the grill once this is all done since I will replace the radiator too, but might be better if I mount the control box as mentioned.
I didn’t realize how many things require removing the grill, like when I did my headlight retrofits lol. FWIW warns are probably one of the best winches on the market, but you gotta ask yourself are you going to be winching all the time? Warns are a must if your winching everyday but if your only winching like 10-20 times per year you’d be fine with a SB IMO. That’s why I went with SB at least, lot of happy ppl with SB’s.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 07-09-2021, 08:05 AM #47
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Originally Posted by T4topher View Post
you gotta ask yourself are you going to be winching all the time?....
How I looked at it, how you do your rigging makes a difference on how much abuse your putting on winch.
Didn't use power cables supplied with winch welding cable is much better it all helps.
Old 07-11-2021, 12:24 AM #48
4x3Lander's Avatar
4x3Lander 4x3Lander is offline
4x3Lander will become famous soon enough 4x3Lander will become famous soon enough
4x3Lander's Avatar
THE MAGICAL EMAIL HAS ARRIVED! Finally
Sent via FedEx starting Monday and set to arrive on Thursday.
Notified 19 weeks after purchase. Set to arrive 20 weeks after purchase.
2002 4Runner Sport Edition - 4WD auto / 3” lift / 33” tires
4x3Lander is offline   Reply With QuoteReply With Quote
Old 07-11-2021, 12:51 AM #49
T4topher's Avatar
T4topher's Avatar
Stoaked for you brah! Grats.
Old 07-11-2021, 12:58 AM #50
4x3Lander's Avatar
4x3Lander's Avatar
Thanks! Timing is coincidental in that I’m right in the middle of replacing all of my front end suspension components. Now I can remove the bumper and all that related stuff
Appreciate the opinion on the winch too. I don’t foresee using it a lot. Just when needed and if I’m guessing right, maybe a couple times a year.
Old 07-11-2021, 12:34 PM #51
Real Name: Mark
Real Name: Mark
@4x3Lander , good to hear of receiving ship notice for sure, relax aye.
Things about mounting bumper there is no way to adjust body to bumper gap as it comes, it's awkward getting it mounted without dinging paint.
Before paint do a mock up, I elongated the six holes 3/8" that hold bumper to cross member so I could achieve the correct gap, no two Runners are the same.
Thin flat washers on these 6 bolts as designed is a weak link from the git go, elongating holes making it fit your Runner makes it worse.
Washers in pic are 1-9/16" square 1/4" thick stout, for ease of install 4-5/8" long bolts with head cut off makes a guide rod.
Addicted Offroad Bumper Status-img_0694-jpg
Old 07-11-2021, 07:10 PM #52
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
Along the same lines, be prepared to go shopping for fasteners to finish the installation. The original tie down bracket bolts are not long enough to properly engage with the added thickness of the crossmember, so I needed four 12x1.25-40mm flange head screws:
Also, at least in my case, the 1/2"-13 screws that were supplied with the bumper (to attach the bumper to the crossmember) were all cross-threaded, so I had to get six new 1/2"-13 flange head screws:
I had a number of other issues with the bumper (e.g. the cutouts in the bumper for the fog lights were crooked), but hopefully you won't have to deal with that.
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 07-11-2021, 09:04 PM #53
4x3Lander's Avatar
4x3Lander's Avatar
Great advice on the mock up. When I installed my rear bumper, I was fortunate that I was able to use two FrontRunner boxes on each side of the bumper with two rolls cart things. It was perfect for the amount of times I had to line up and install the bumper. Will try that with this bumper to make it easier.
Another great idea on elongating the holes. Will definitely assist in gapping all around.
Those heavy duty square washers look perfect too. I will grab some of those. The guide rod - to line up the holes?
Old 07-11-2021, 09:17 PM #54
4x3Lander's Avatar
4x3Lander's Avatar
I REALLY appreciate this info as well! I loathe going to Home Depot / Lowes for hardware like this because they never have enough or a large variety. I appreciate the pictures of the bolts and the info for them so that I can easily buy them. After completely removing the entire front bumper assembly today, all the hardware was too rusted or in bad shape. The only bolts I was able to keep were the ones holding the tow hook.
Assuming there is hardware included with the bumper, although seems I will need to buy what you have suggested? When you say the bolts were stripped, you got them that way or you stripped them in the process?
Sorry to hear about the cutouts with the lighting. The bumper style I ordered has no lights at all, so I won’t have those issues.
On a different note - LOVE my Spiker Engineering hood struts
Old 07-11-2021, 10:12 PM #55
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Go to Fastenal or whatever local fastener store is near you. Here in the PNW we have Tacoma Screw which is kick ass, but I'm not sure if they stretch down to NorCal. Sometimes local hardware/home improvement stores even have a better selection than Lowes and Home Depot - both are comically bad for any nut or bolt that isn't a shouldered, standard carriage bolt. Lowes almost carries nothing in metric usually
Old 07-11-2021, 10:32 PM #56
4x3Lander's Avatar
4x3Lander's Avatar
Having lived in the Tacoma area for about 6 years in the past, I can’t tell you how much I miss Tacoma Screw and no, there is definitely not one here in the Bay Area because if there was, I would have lived next to it I used Tacoma Screw a lot when I was building my 1st Gen MR2.
Agreed, as I should go to local hardware stores more often. Admittedly though, since Spiker Engineering provided the packaging specs of the bolts, found them instantly on Amazon for $18.50 for 10.
Old 07-11-2021, 10:50 PM #57
Real Name: Mark
Real Name: Mark
Those heavy duty square washer,
The square washers are used with Unistrut in electrical construction local electrical supply has them.
The long headless bolt is to hang bumper on slide it into position in a controlled manner.
I had same problem with bolt threads as Spiker mentioned, get a tap to cut good threads
AOR must like using worn out taps.
Old 07-11-2021, 11:17 PM #58
Real Name: Mark
Real Name: Mark
Originally Posted by Endlessblockades View Post
It's not worth the headache for me to deal with...
Your odds are better than going to the Casino, lol, lifes a crap shoot some times.
Old 07-11-2021, 11:22 PM #59
4x3Lander's Avatar
4x3Lander's Avatar
Ahhh, that’s where I have seen those types of washers. Thanks for the reminder.
OK, looks like I am going to buy replacement bolts as Spiker did. I would buy a tap, but already investing in more tools than I planned
Old 07-11-2021, 11:42 PM #60
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
For sure - I take chances and I roll plenty of snake eyes....
bumper , online , order , status , weeks
More than 13 weeks and no bumper - Addicted Offroad (AoR) dreyday General Discussions 27 11-07-2018 04:33 PM
Addicted Offroad's new 120 chassis bumper AddictedOffroad 4th Gen T4Rs 99 08-11-2014 04:04 PM
Addicted Offroad's new FJ Cruiser bumper AddictedOffroad Addicted Offroad 9 04-10-2014 10:20 AM
My Addicted Offroad winch bumper dustin Keeler 3rd gen T4Rs 21 06-23-2013 09:40 AM
