Old 06-12-2021, 02:25 PM #1
02_SE_Runner_DAD's Avatar
02_SE_Runner_DAD 02_SE_Runner_DAD is offline
02_SE_Runner_DAD is on a distinguished road
Stock 4WD conversion
For guys/gals that have done a stock 4wd conversion. How long will it take to do a stock 4wd conversion if you have two 4 runners side by side and taking parts from a 4wd and swapping them to a non 4wd?
TIA
Fly High Son(NATE) 1995-2014
http://www.toyota-4runner.org/3rd-ge...od-thread.html
02_SE_Runner_DAD is offline   Reply With QuoteReply With Quote
Old 06-14-2021, 01:39 PM #2
phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of
It was 3-4 days of hard work and beer. Remember you need a welder for the crossmember and shifter holes.
Also, this is assuming no rust issues, etc.
Parts truck:
Front in place:
Transmission going in:
You can do various parts separately. The front diff/hubs/axles can be done separately. Then transmission, then wiring. Make sure you change the rear upper control arms when you do the transmission (2WD and 4WD upper arms are different).
'16 Honda Odyssey
Old 06-15-2021, 10:23 PM #3
Thank you for that great info! What is the welder for? Does everything just bolts on to the 2wd? Really appreciate this info and thank you. I might have some more questions if you don't mind.
Old 06-16-2021, 08:30 AM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold
Real Name: Patrick
You have to move the transmission crossmember location for the 4wd transmission mount to be able to bolt up to the frame. You'll also need to cut out, transfer, and weld the section of body around the transmission and transfer case shifters. The body opening for the transmission and transfer case shifter are different.
2000 Limited V6 Auto E-Locker
Old 06-16-2021, 10:22 AM #5
clearock clearock is offline
clearock will become famous soon enough
Hey phattyduck, just looking for clarification as to what is diff with the rear upper control arms?
clearock is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 12:57 PM #6
4WD upper arms are longer.
The 4WD pinion points up at the transfer case output (due to double cardan CV joint) and the 2WD pinion is level due to two single u-joints in the driveshaft.
'16 Honda Odyssey
Old 06-16-2021, 01:03 PM #7
As was already said:
Transmission crossmember has to be relocated (this pic is with the 2WD 4WD crossmembers in place while the 2WD trans was still installed):
Shifter holes (this is the 4WD holes traced out and the 2WD hole still there):
(this is the modified shifter area)
Check out the thread in in my signature for the whole story...
'16 Honda Odyssey
Old 06-16-2021, 01:26 PM #8
nice, have done a couple of 2wd to 4wd and never realized said, makes complete sense when u stop and think... diff add this to my list in the future. Thanks
Old 06-20-2021, 10:27 AM #9
asianalpha asianalpha is offline
asianalpha is on a distinguished road
phatty.. how much the 4wd conversion cost you?
asianalpha is offline   Reply With QuoteReply With Quote
Old 06-21-2021, 02:17 PM #10
$300 for the rolled 4Runner with no motor, about $500 in maintenance parts (seals, fluids, broken part replacements, etc.) and about $500 in beer.
I highly suggest getting a parts truck to do it... There are a lot of little things you will miss if you don't have a complete 4WD next to you to compare. Make sure it is the same year and trim if you want the wiring to go smoothly...
'16 Honda Odyssey
4wd , conversion , side , stock , swapping
Stock headlight conversion: to do or not to do?! FlannelShanel 5th gen T4Rs 8 07-12-2017 09:08 AM
Can't find it. Stock fog light-HID conversion Tucson4runner 3rd gen T4Rs 9 01-19-2012 10:20 PM
HID Conversion or 9006 to 9005? -05 T4R w/ stock reflectors keitht253 4th Gen T4Rs 1 06-24-2011 06:54 PM
4.3 conversion in a 95 t4r Jabo Classic T4Rs 4 06-27-2010 09:45 AM
Stock Headlight bulb conversion faq808 4th Gen T4Rs 4 02-06-2009 05:34 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
