this morning...
Started it. The fly by wire was dead. I've had a LOT of trouble with this truck losing contact at the connectors. That one is behind and below the throttle body on the passenger's side. Disconnected it, shot it with CRC contact cleaner then gooed it with Permatex sillyclone grease. Made some progress...
Moved on to the o2 sensor. Same deal with the plug. Made some more progress. It stopped throwing codes at that point. It STILL bogged, right off idle. Replaced o2 sensor. RESET THE COMPUTER. Ran it down the freeway. It MAY be fixed!
Or it may blow up, the next time I start it... KA-BLOOIE! C U Later, papa san Toy rota. I'd take some bets but I'll be damned if I know which side to take...
2001 Sr5 V6 2WD
"...The closer you get, to the meaning, the sooner you know, that you're DREAMING..." (Black Sabbath - HEAVEN AND HELL)
