06-18-2021, 12:00 AM
#16
Thanks but I have no clue. The Tribeca is still on the same old springs. Not doing all the work for the good old grocery getter. Subaru springs are not pricey which is partly why I am regretting my decision now.
As for the 4R, see what the OEM rates are, I am sure it has to be posted around here, and go from there. But I doubt you will find softer than OEM specialty spring for a regular shock. As for aftermarket regular springs, I wonder if you can figure out the spring rates.
At the end, it will all come down to original geometry, springs not stiffer than stock, and same for shocks. So whatever springs and shocks are closest to stock should do as far as comfort goes.
(6112s/650lb at 1.25"-1.5" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
06-18-2021, 12:08 AM
#17
Originally Posted by raincoyote
What coil springs did you go with? OEM? They're expensive as hell. Looking at Rock Auto and thinking about these AC Delco ones but wondering if I'm being a cheap bastard. The sedan ride is what I want.
@ MAST4R
and
@ RotaryDreamz
I'd be curious about your input on this too.
I went oem with ball joints bushings and tie rods.
06-18-2021, 12:31 AM
#18
Real Name: Sean
Real Name: Sean
I would go with OEM as stated above if you want that Sedan ride feeling. I have no idea what the ride would feel like to be honest. Haha. It was crappy when I bought the truck. But I can tell you once I changed all my suspension components, i felt the difference. My setup is meant for weight, and i even installed airbags to compensate for more weight or if im towing, but its nowhere near a "sedan" feel.
06-18-2021, 01:32 AM
#19
Originally Posted by ch1966
Ok interesting! I'm looking at Rock Auto and they weirdly have the same models but also are suggesting one digit off. So they carry both ACDELCO 450H369 and the ACDELCO 450H368 but it is not clear what the real difference is between these springs. Any ideas?
2002 4Runner Limited 4WD 200K Black/Thundercloud (KG1)
06-18-2021, 07:11 AM
#20
368 is 99 tall
369 is standard height.
Maybe?
My filter shows 369 fitting 99 and 01
368 fittting 99 sport.
06-18-2021, 11:06 AM
#21
@ ch1966
this is sort of what I could work out last night as well. I ordered parts last night, I'll let you guys know how it turns out and if the ride is significantly better
06-18-2021, 02:56 PM
#22
Check your center of hub to fender height. If you are at 20" already, don't replace the springs. If anything, you might only need rear springs - the fronts don't sag like the rears often do.
(Too) Soft shocks will allow bottoming, which will be very harsh. With new shocks all around and the right ride height, much of your comfort will be handled. Bushings and end links may also be an issue, but you can check that while you are in there doing the other work - they may not all be bad, depending on how the 4Runner was treated before you got it.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
06-18-2021, 05:45 PM
#23
Real Name: Jerod
Real Name: Jerod
So I was going over the quote from the regional tire/suspension shop and price checking online. Going with straight KYB OEM rec'd replacements, but they quoted me at $137 per KG9025 Gas-a-Just Strut, which is about $40 of margin vs. directly buying them online so I'm taking a moment to suss this out more.
Generally, if I just want to do the LBJs and all the suspension components that matter. I've been looking through posts and diagrams but can't work it exactly out. Here's what I'm thinking I should just replace in one big go:
- LBJs
- Struts
- Shocks
- Coils front and back
- Sway bar linkage
- Sway bar bushings
- Bump stops?
Am I missing something? This one has thrown me through a loop and I'm pressing pause until I can figure it out for myself.
I can give some real world experience. I have the KYB Gas-a-Just shocks with new stock height coils. The ride is a little bit stiffer than a stock 4Runner suspension. You'll feel cracks and potholes but not so much that your brains turn to butter. I like the quick response of the shocks as it gives a better on and off-road feel and keeps grip very well. But if you want plush, stick with OEM Tokico shocks.
Also, shops will always mark up their part prices, that's industry standard. They never invoice parts at cost so it's not a surprise that you can get it cheaper yourself. Many shops will not installed customer supplied parts.
Your parts list is still solid though. No matter if you go with KYB's or Toyota/Tokicos, your ride will be considerable better. Mine was so bad before I did exactly what you are thinking that people actually got motion sick in the back seat!
06-18-2021, 08:18 PM
#24
Originally Posted by HiluxSurf SSR-G
get the 1999-2000 4Runner Highlander shocks and coils for both front and rear
Absolutely. If not OEM, then the Highlander route is the way to go. A little lift but still a nice, cushy ride (compared to some).
06-18-2021, 09:26 PM
#25
Real Name: Natey
Real Name: Natey
How about a Bilstein 5100 and Toytec set up?
TTHA-CK-RCC - 3" Lift W/ Bilstein 5100 Front Coilovers (FJ/4Runner/GX)
The way the front end porpoises when you hit the brakes in a stock 5th gen Limited is not anything to do with smooth or safe.
2012 Limited...Stock
06-19-2021, 01:14 PM
#26
Parts List
OK here's what I decided to go with.
- OEM lower and upper ball joints
- ACDELCO OEM replacement coils
- KYB KG54317 shocks
- KYB KG9025 struts
- Mevotech tie rods
- Mevotech sway bar links
- Energy suspension sway bar bushings
- Energy suspension bump stops
Sort of a mix between ultra plush and performance. Any update will be an upgrade over the tired OEM parts and the cracked sway bar links. The rig goes in for service at the end of the month, when I get it back I'll report back how it feels.
06-20-2021, 01:04 AM
#27
Any experience comparing the KYB gas-a-justs to the Bilstien 4600s? Ride quality specifically? This is one I have been trying to sus out for a while.
I've swapped my rear 4600s for OEM 99 Toyota shocks and I am happy with that trade, want to do similar in the front but the OEMs are very spendy.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
06-20-2021, 02:10 AM
#28
Real Name: Jerod
Real Name: Jerod
No, I have not ridden or driven in one with Bilstein's. I agree, the front OEM struts do cost a bit. Not sure why the rears are so cheap and the fronts are so much.
07-13-2021, 08:37 AM
#29
Final verdict after all-new suspension upgrades
- KYB KG9025 struts
- Mevotech tie rods
Ok all, I finally got the truck back from the shop and oh man, was this worth every penny. Where before I was literally bracing myself on the steering wheel against any tiny little bump in the road, now I just sort of glide over it like... a normal car.
It's not quite "sedan level" quality but it is so much nicer. I can't believe what a difference it makes, it's so much more comfortable. It seems like sort of a big outlay for what it gets you, but I can't imagine driving it without the new suspension parts now.
If you're on the fence... do it!
08-13-2021, 06:59 PM
#30
Real Name: Mark KN6TZI
- KYB KG9025 struts
- Mevotech tie rods
I don't mean to hijack your thread but I'm trying to basically replicate your upgrades on my '96 SR5.
I'm curious about which ACDELCO coils you went with. I've read differing opinions about coils for the 15"/16" wheels being equivalent to 99 talls. I'm only seeing 45H0368 (16") & 370 (15") on RockAuto for the fronts. Had to search specifically for 45H0369 to even find them. Every time I think I'm ready to order, another question comes up!
I'm already at 21 1/4 FL and 21 1/2 FR, hub center to flare, which leads me to believe these aren't original coils on my '96. (or are they?) Rears are at 20 1/2 left and 21 right. Point is, I don't want to end up lower than I am now. I've lost count of how many browser tabs I have open trying to figure this out. Seems everyone is right and everyone is wrong about the color codes. I have blue/red front driver side, blue/blue front passenger side and single orange on the rears.
Driver front (and if I understand Timmy, that spring's clocked about 90 degrees off?)
Passenger front
About a foot in height, installed
My original plan was to order 45H0368 for the front and 45H2131 for the rear (both for 16" wheels). Also wondering if I should order new top plates or just reuse what's there. History tells me I'm probably overthinking this. I'm hoping someone can help straighten me out!
'96 T4R SR5 | 4WD | Auto | 199 TBU | 262k+
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
