Old 06-15-2021, 11:40 AM #1
raincoyote's Avatar
raincoyote raincoyote is offline
raincoyote is on a distinguished road
raincoyote's Avatar
Red face Suspension upgrade to get the smoothest ride?
Have done a lot of research looking around the forum about getting a smoother ride in the 3rd gen by swapping out suspension. I know my sway bar bushings are about due for replacing, and I'm noticing a lot of bumps feel much bigger than they should and it can't all be down to my 265/70R17s.
Seems like the two camps are between the Tokicos and the Bilstein 5100s. This is not an offroad rig. Forest service roads are the worst it's ever going to see so we're going for what's the cushiest, Rolls-Royce-iest ride I can squeeze out of this thing?
2002 4Runner Limited 4WD 200K Black/Thundercloud (KG1)
raincoyote is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 12:14 PM #2
RomanSchnobrich's Avatar
RomanSchnobrich RomanSchnobrich is offline
Real Name: Roman Schnobrich
RomanSchnobrich will become famous soon enough
Do you use your 4Runner for camping at all? Will it ever see heavier weight/more cargo or not really? Tokicos can be kind of stiff without any additional weight as they're valved for heavier Land Cruisers. I like mine, but I have a steel bumper and swing out with a spare 33" tire, and some might say it rides too stiff still.
Whatever you do, I'd veer away from Old Man Emu-- they're not on your list but I'll mention it just in case. Their shocks did not last over a year and a half on my 4Runner, and I don't beat it up that badly.
2000 SR5 Midtravel Cookie Cutter Build
https://www.instagram.com/roamin.creative/
RomanSchnobrich is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 12:41 PM #3
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Smooth ride? Stick OEM. Everything else is stiffer. With the exception of the front shocks, OEM is not that much more expensive.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 12:46 PM #4
Seconded.
Also make sure the ride height front and rear is around 20" (from hub center to fender lip) - if it is lower, you'll want to replace the springs to get it up around that high to keep you off the bump stops on bigger suspension hits (potholes, speed bumps, etc.).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 06-15-2021, 12:51 PM #5
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
get the 1999-2000 4Runner Highlander shocks and coils for both front and rear
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 01:16 PM #6
spartacus's Avatar
spartacus's Avatar
Agree tokicos or bilstein hd4600 a little stiffer. Also Driving on Forest service roads will be way better if you air down to 18-20 psi also.
Old 06-15-2021, 01:33 PM #7
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
One thing that actually makes your ride pretty smooth when it hits bumps is duro bumps..
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 01:38 PM #8
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Yes indeed
And when the time comes to lift it get some nice monotube shocks
JZiggy is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 01:57 PM #9
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
Not GX460 air suspension? LOL
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 12:39 PM #10
raincoyote's Avatar
raincoyote's Avatar
Going with OEMs and getting the sway bar links replaced as they're cracking. Hopefully this makes a difference, after driving it for a week it's noticeable just how bad it is.
Old 06-17-2021, 10:38 PM #11
raincoyote's Avatar
raincoyote's Avatar
So I was going over the quote from the regional tire/suspension shop and price checking online. Going with straight KYB OEM rec'd replacements, but they quoted me at $137 per KG9025 Gas-a-Just Strut, which is about $40 of margin vs. directly buying them online so I'm taking a moment to suss this out more.
Generally, if I just want to do the LBJs and all the suspension components that matter. I've been looking through posts and diagrams but can't work it exactly out. Here's what I'm thinking I should just replace in one big go:
  • LBJs
  • Struts
  • Shocks
  • Coils front and back
  • Sway bar linkage
  • Sway bar bushings
  • Bump stops?
Am I missing something? This one has thrown me through a loop and I'm pressing pause until I can figure it out for myself.
Old 06-17-2021, 11:16 PM #12
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
  • LBJs
  • Struts
  • Shocks
  • Sway bar linkage
  • Sway bar bushings
  • Bump stops?
Well, it would depend about the various bushings on their condition.
I know two things.
1/ The aftermarket KYB on some models like our Subaru are stiffer than the OEM version of the same KYB shocks
2/ I failed to replace the springs on our 2008 Tribeca and have been paying the price since. Because they sag more than 0.5" on a vehicle with very little front travel, the result is a pretty nasty ride. It takes road hits in stride, but the ride quality is bad.
So, as mentioned earlier, it pays off to restore factory geometry even if it has been distorted by age rather than mods. And see if aftermarket KYBs are tuned the same as OEM.
Old 06-17-2021, 11:23 PM #13
RotaryDreamz's Avatar
RotaryDreamz RotaryDreamz is offline
Real Name: Sean
RotaryDreamz will become famous soon enough
Real Name: Sean
When I overhauled my suspension, I replaced pretty much every bushing, if I didn't end up upgrading to aftermarket parts. My rig hadd 300k + on original everything.
Since you will have everything apart, I would include front and rear lower control arm bushings. Front and rear upper control arm bushings. Front upper ball joints.
Optional but recommended. I rebuilt my CV's because all my boots were torn. Steering rack bushings. Unless your current bump stops are rotted, I don't see a need to change them really, but they are very simple to change. I upgraded mine because it was needed due to my lift. Good luck.
RotaryDreamz is offline   Reply With QuoteReply With Quote
Old 06-17-2021, 11:35 PM #14
ch1966 ch1966 is offline
ch1966 will become famous soon enough
The first thing I did with mine was new ball joints bushings links tie rods 99 springs and KYBs.
It’s not much for flex but it rides like a sedan.
I’m a 1/4” higher in the back empty. I’m going to swap out the rear with Dobinsons and Bilsteins so I can run with more weight without squat.
ch1966 is offline   Reply With QuoteReply With Quote
Old 06-17-2021, 11:54 PM #15
raincoyote's Avatar
raincoyote's Avatar
What coil springs did you go with? OEM? They're expensive as hell. Looking at Rock Auto and thinking about these AC Delco ones but wondering if I'm being a cheap bastard. The sedan ride is what I want.
@MAST4R and @RotaryDreamz I'd be curious about your input on this too.
5100s , bilstein , lot , ride , suspension
In your opinion, which kit would provide the smoothest ride? SoFloT4Run 5th gen T4Rs 24 10-16-2017 03:01 PM
Looking for the Smoothest Ride Possilbe Caffeine27 4th Gen T4Rs 18 10-02-2014 06:30 PM
What lift options give the smoothest ride? yellowssm 4th Gen T4Rs 13 10-05-2011 10:45 PM
Which Lift is the Best and Smoothest bigwalts4runner 4th Gen T4Rs 12 12-15-2009 03:29 PM
