Old 06-27-2021, 05:51 AM #76
ch1966 ch1966 is offline
ch1966 will become famous soon enough
Originally Posted by 4x3Lander View Post
Not to derail this thread, but how did you get the AT Fluid Temp sensor? I have the same app for my 2002 and have never been able to find a working transmission temp sensor.
ch1966 is offline   Reply With QuoteReply With Quote
Old 06-27-2021, 12:01 PM #77
4x3Lander's Avatar
4x3Lander 4x3Lander is offline
4x3Lander will become famous soon enough 4x3Lander will become famous soon enough
4x3Lander's Avatar
Originally Posted by ch1966 View Post
Thanks so much! I’ll give this a try to see if I can get it to work.
2002 4Runner Sport Edition - 4WD auto / 3” lift / 33” tires
4x3Lander is offline   Reply With QuoteReply With Quote
Old 06-28-2021, 08:53 PM #78
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
Had my 1998 V6, automatic in death valley, and it had a new radiator, and approx 1 years old aisin clutch fan at the time. We were fully loaded, coming from Quebec, which could compare to at least some of the weight of your armor.
Scangauge is in the truck. I did monitor, and from memory
It was very, very hot (during summer) in death valley, and the truck coolant temp would be higher than usual (usually 87-89 celcius, 188-190F), but would keep around or below 95 celcius (200F) most of the time, and I could always hear the clutch fan being on it's ''max'' setting, very loudly.
Only once it went over 212 (went to 101-103 celcius), and it was on a long, slow uphill drive, and I was not going easy on the truck at all.
Pretty normal that in higher ambient temps, you see higher coolant temps. We just don't happen to have scangauges in every of our cars, and also, the clutch fan system calls for more temp variations than a fixed speed electric fan. Happened to me, and was not really surprised. As long as I heard that clutch fan scream, I was happy and A/C was going full-blow.
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
Old 06-28-2021, 11:00 PM #79
Unner's Avatar
Unner Unner is offline
Unner is just really nice Unner is just really nice Unner is just really nice Unner is just really nice
Unner's Avatar
My two cents... There is probably nothing wrong with your 4Runner, you are meticulous with maintenance. The only thing working against you is the age of the vehicle and things like corrosion that could impact your cooling ability. I think if you weren't monitoring your temps you would have been fine to leave the AC on and keep going, but I would have done the same thing as you because that is how I am. I know mine runs 186-193 normally. 195 or 198 on really hot days and I'm working the engine in stop and go traffic or up long highway grades, but that is when temps are in the mid 90s, 100 at most. The humidity down here is killer, but that doesn't really impact the engine much.
These things are rated to tow 5,000 lbs from the factory with nothing special added. I have to imagine Toyota did some extreme weather testing towing at or near that limit. Otherwise you'd have people pulling trailers through the desert overheating. I would also assume that even with your rig loaded down and the larger tires killing the gearing, it isn't as hard on the engine as towing 5,000 lbs with a stock 3rd gen.
I do think the regear and possibly a better radiator would help keep the temps down though, which would be a good thing.
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
Unner is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 01:09 PM #80
@mtbtim
Any luck with your truck Tim?
I’ve been thinking about yours while working on mine.
Your thermostat may be sticking or not opening fully.
I threw a 170* in mine.
And added a trans cooler + 6qt drain and fill.
I baselined the following results on a road that gains 1000’ in altitude in less than 3 miles at 7%-12% grades.
Baseline run ~25 mph +-
2nd gear mostly
All temps measured at the summit.
Here’s the same run with a new thermostat
And with the trans cooler added in line and drain and fill
The temperature relationship between the coolant and transmission fluid is interesting.
Good luck. I’m watching to see what you figure out.
driving , engine , extra , rear , temps
2017 Toyota 4runner SR5 premium heavily modified SOLD The_Green_Wang For Sale: Vehicles 4 01-09-2020 08:23 PM
2014 4Runner, Heavily Modified, Lots of Extras, $31,500 WandaRunner For Sale: Vehicles 0 05-19-2019 04:40 PM
FS: 2013 Limited 68,000 miles heavily modified $30k bimrunner For Sale: Vehicles 16 04-18-2018 03:39 AM
