Old 06-19-2021, 05:58 PM #1
Richrd Richrd is offline
Richrd is on a distinguished road
limp home mode?
I just replaced the lower steering shaft {not that hard} and then found that the problem was under the dash. the bolts had fallen out of the plate that ties the steering wheel to the lower splined shaft.
Anyway, on the test drive it won't go over 25. I checked for codes and only found p1782 something about 4wlow. I cleared dthe code and tried again after moving the lower fitting a couple splines to level the steering wheel.
I got it up to 40mph but now power over 25.
any ideas?
Richrd is offline   Reply With QuoteReply With Quote
Old 06-19-2021, 06:14 PM #2
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Itís not accidentally in low range at the transfer case?
thennen is offline   Reply With QuoteReply With Quote
Old 06-19-2021, 06:28 PM #3
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked has a spectacular aura about Too Stroked has a spectacular aura about
Did you tie off / lock the steering wheel when you changed the intermediate steering shaft? If you don't prevent the wheel from turning, you can break the clock spring and cause all sorts of interesting problems.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 06-19-2021, 06:36 PM #4
Ripper238's Avatar
Ripper238 has a spectacular aura about Ripper238 has a spectacular aura about Ripper238 has a spectacular aura about
Ripper238's Avatar
Famous last words {not that hard}
Old 06-20-2021, 10:17 AM #5
tell me about the clock spring. Yes, the steering wheel got turned, it all came apart under the dash.
Old 06-20-2021, 12:04 PM #6
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad is a splendid one to behold sleepydad is a splendid one to behold sleepydad is a splendid one to behold sleepydad is a splendid one to behold sleepydad is a splendid one to behold sleepydad is a splendid one to behold sleepydad is a splendid one to behold
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
what year is your truck, clock spring is different thru the years. they can spin around like 2x times before you wreck them I think.
provided a link below for a 2000 clock spring (8430630120
CABLE SUB-ASSY, SPIRAL)
I messed one up one time and had to replace mine(1997), but I got the airbag light so that was the only way I knew it.
They are bit different thru the years. I know my 1997 did not work in a 1998 but the 1998 worked in a 2000 so... I don't know what you can just swap in and out thru the years with 100% certainty. They are kind of expensive but I would bet you can find a pick'n pull one for pretty cheap. super easy to swap them out, just be careful of the electrical connector is kind of goofy and I also ripped one apart by accident.
I was able to find one on ebay for super cheap brand new, 100% it was stolen from someplace.
SWITCH & RELAY & COMPUTER | 4RUNNER VZN185L-GKPZKA RZN18#,VZN18# | JT3HN87RXY0283787 | Toyota | Genuine Parts Catalogs | PartSouq Auto Parts Around the World
Old 06-20-2021, 01:02 PM #7
mines an 03
thanks
Old 06-20-2021, 02:33 PM #8
Skulking Skulking is offline
Skulking has a spectacular aura about Skulking has a spectacular aura about
mines an 03
thanks
In that case, you are in the wrong forum. You want the 4th gen forum for a 2003. They should be able to help you much better. That also explains why the FSM didn't list p1782 as a code when I looked.
Skulking is offline   Reply With QuoteReply With Quote
Old 06-20-2021, 06:08 PM #9
I thought the slack I was feeling was the lower steering shaft. I had tied off the steering wheel, but I needed to turn the shaft to get access to the bolts.
suddenly the wheel felt loose, spun easily and made a noise like something shearing. whwen I loooked under the daash this is what I found.
Old 06-21-2021, 02:25 PM #10
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold Bad Luck is a splendid one to behold
Real Name: Patrick
You're in the 3rd gen subforum (1996-2002). You need the 4th gen subforum: https://www.toyota-4runner.org/4th-gen-t4rs/ and you can try this 4th gen specific google search: https://www.google.com/search?q=site...4dUDCA8&uact=5
Good luck!
2000 Limited V6 Auto E-Locker
Old 07-05-2021, 11:47 AM #11
final report.
took the vehical to a toyota dealer. they told me the clock spring could not cause the problem. {bs}
they did a dianostic and found nothing wrong. but now the problem is gone. They also wanted to install two new air fuel sensors for $750. which I passed on.
btw, a friend is a tech at a mercedis dealer and he says the clock spring could definately cause the problem
found , lower , shaft , steering , wheel
Limp Mode P2138 Chilow 5th gen T4Rs 11 01-06-2021 01:43 AM
22re limp mode theking11863 Classic T4Rs 3 12-12-2019 08:57 PM
3rd gen Limp mode? MandAtaco 3rd gen T4Rs 6 06-04-2018 04:19 AM
Disable limp mode? mark.stevens.399 4th Gen T4Rs 2 03-17-2018 12:02 PM
Trans in limp mode '92 T4R luther91 3rd gen T4Rs 2 06-15-2015 07:14 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
