Old 06-19-2021, 10:59 PM #1
5VZ-FE's Avatar
5VZ-FE 5VZ-FE is offline
5VZ-FE will become famous soon enough 5VZ-FE will become famous soon enough
5VZ-FE's Avatar
ARB Switch Illumination
Got my ARB compressor (CKMA12) installed last weekend and drove up to Tahoe immediately following that. I took the blue switch wire (dash light illumination) and spliced it into an undimmed wire under the dash. On the drive up I noticed that the white light in the switch was too bright for me (actually the reflection of it in my window was too bright), so today I switched the splice to a dimmed wire under the dash.
I used the positive wire going to the cigarette lighter that has a green illuminated ring around it, which is a dimmed wire, but the switch still doesn't dim. It does have power, just won't dim. Any ideas? Thanks...
And because threads with pictures are more fun:
‘98 T100 SR5 4X4 5spd (sold)
‘99 4Runner SR5 4x4 5spd E-Locker Unicorn
5VZ-FE is offline   Reply With QuoteReply With Quote
Old 06-19-2021, 11:03 PM #2
5VZ-FE's Avatar
5VZ-FE's Avatar
I just realized that the green ring surrounding the cigarette lighter is no longer illuminated. I must not have made a solid connection in the butt connector. I think that would explain the lack of dimming since I think it needs a negative in order to dim...
Old 06-20-2021, 12:00 AM #3
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
The negative and positive both have to be hooked up to a dim source, can’t be either or. I just tied into the dimmer knob as it was really close to my switches.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 06-20-2021, 12:23 AM #4
5VZ-FE's Avatar
5VZ-FE's Avatar
Hmm… Did you do that with the wiring loom supplied by ARB? As far as I’m aware, there is no negative wire for dash illumination coming out of the loom.
Old 06-20-2021, 12:51 AM #5
T4topher's Avatar
T4topher's Avatar
I’m actually using Ottraw switches but it’s the same thing basically. There are 2 grounds(blk) wires on the switch one of them is ground for the thing your switching and the other is the ground for the light, just gotta figure out which one is which. Then the positive side you hook up to the blu-wht wire. I’ll bet it’s #7 but gunna have to test it out.
bright , dash , light , switch , wire
DIY: Factory E-Locker Switch Illumination Killer Squirrel 3rd gen T4Rs 9 08-23-2022 01:17 AM
AOB Switch Illumination Issue QUESTION/Trouble With Switch Fully Engaging FIX mbumpus11 5th gen T4Rs 11 10-23-2021 03:51 PM
2020 illumination wiring on windshield warmer switch colours mkivalex 5th gen T4Rs 7 06-16-2021 03:15 PM
Light switch illumination headache! kolelt 3rd gen T4Rs 8 04-10-2016 01:19 AM
Where can I find a 3-pos-switch that could replace the dash-illumination wheel? 38vn38fa 5th gen T4Rs 8 02-11-2013 05:39 PM
