Old 06-20-2021, 09:58 AM #1
ledger35's Avatar
ledger35 ledger35 is offline
Real Name: Bob
ledger35 is on a distinguished road
ledger35's Avatar
Real Name: Bob
Intermittent wiper doesn’t work
Intermittent wiper wasn’t working and the wipers just kept going so I replaced the stalk and after $100, problem still there. All other positions work normal except the intermittent position. Any member run across this and what advice can you give? 2000 LTD 4WD
ledger35 is offline   Reply With QuoteReply With Quote
Old 06-20-2021, 03:58 PM #2
ledger35's Avatar
Real Name: Bob
ledger35's Avatar
Real Name: Bob
You mean to tell me out of over 30 lookers no one has any advice to give on this thread?
Old 06-20-2021, 04:36 PM #3
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
I would check the wiring going to the window motor first. If the wiring is flexed like for example, the wiring harness hooked to any door - it starts cracking after 20+ years of use and can cause an intermittent connection. I had to redo my entire harness from the rear hatch due to cracked wire which luckily fixed some of my electrical issues.
Might not be your problem but it's worthy to check.
2000 4Runner Limited 4x4 V6
Old 06-20-2021, 05:45 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Here is the wiring diagram for that circuit.
"3. INT POSITION (w/ INTERMITTENT OPERATION)
With the wiper SW turned to INT position, the relay operated and the current which is connected by relay function flows from
TERMINAL 17 of the front wiper and washer SW to TERMINAL 2 to GROUND. This flow of the current operates the
intermittent circuit and the current flows from TERMINAL 17 of the front wiper and washer SW to TERMINAL 7 to TERMINAL
2 of the front wiper motor to GROUND and functions. The intermittent operation is controlled by a condenser’s charged and
discharged function installed in relay."
Old 06-21-2021, 02:14 PM #5
This is most likely an issue in the wiper motor - mine does it intermittently.
Basically, the stalk doesn't get the signal from the wiper motor that it has done a fully cycle due to a dirty track in the wiper motor position sensor.
Wait for the first good rain, and it might start working again on its own...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 06-21-2021, 05:15 PM #6
ledger35's Avatar
Real Name: Bob
ledger35's Avatar
Real Name: Bob
Thank you all for your advice, I have some investigating to do!
intermittent , normal , run , wiper , work
Rear Wiper doesn't work... H1_VLTG 4th Gen T4Rs 8 12-04-2022 08:56 PM
Rear window wiper doesn't work! Mason Fresh Maintenance/Detailing 7 04-24-2017 02:28 PM
Rear wiper doesn't intermittent... Jpete16 3rd gen T4Rs 9 01-16-2016 03:34 AM
Rear wiper doesn't work pinhead999 Problems & Warranty Issues 4 06-07-2008 06:55 PM
06 SE, rear window wiper doesn't work? Bill3508 Problems & Warranty Issues 6 09-02-2006 01:27 AM
