Old 06-21-2021, 12:38 PM #1
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk has a spectacular aura about cl4Rk has a spectacular aura about
cl4Rk's Avatar
Question about heat shields before putting the body back on the frame...
Hey all,
Before putting the truck back together, about to prep the underbody (cleaning, some wire-wheeling, some sand blasting, more cleaning, then POR-15, paint).
Anybody know the part number for these heat shields? (See attachment)
I've searched online and looked at the diagrams and can't seem to find them.
Or, any suggestions for maybe using something else here that would be an upgrade?
Thanks!!
Question about heat shields before putting the body back on the frame...-img_0612-1-jpg  Question about heat shields before putting the body back on the frame...-img_0612-jpg
2000 Toyota 4Runner SR-5 3.4L V6 4WD AT Sunfire Red Pearl "Ol' Ruby" - build thread
cl4Rk is offline   Reply With QuoteReply With Quote
Old 06-21-2021, 01:25 PM #2
Quantumkiwi's Avatar
Quantumkiwi Quantumkiwi is offline
Quantumkiwi will become famous soon enough
Something like this is probably your best bet: Peel and Stick Heat Shield - Sticky Shield | Heatshield Products
2000 SR5 - Build Thread
Quantumkiwi is offline   Reply With QuoteReply With Quote
Old 06-21-2021, 02:10 PM #3
HiLife HiLife is offline
HiLife is a jewel in the rough HiLife is a jewel in the rough HiLife is a jewel in the rough
I have a part number but cannot confirm it is the right one. Doubt any toyota parts counterman will be able to confirm it too, unless he is well experienced and not just a computer parts guy which most are these days.
Im particular to Design Engineering Insulation DEI myself.
Old 06-21-2021, 04:42 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold
brillo_76's Avatar
Real Name: Jon
Clean underneath compared with what I have to work with.. :-)
I would go with Hilife recommendation and that OEM Insulation is so flimsy on those 2 pieces
Edit: Check out KBS Seal and compare it to POR 15 as KBS is alot newer formula and
"RustSeal is based on about 25 years newer chemistry. POR-15 has 0 UV stabillity, RustSeal in all 10 colors has 90% UV stability. POR-15 always needs a UV stable top coat and RustSeal used somewhere not in direct sunlight, floorpans, chassis, etc has all the UV stabilty it needs and won't need a topcoat"
5 3rd gens listed in the build thread
Old 06-21-2021, 08:19 PM #5
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough
the part number for the lower one is:
55225-35110 --> Dash Panel Heat Insulator No. 1 for mid-1998 to 2002
the part number for the upper one is:
55223-35040 --> Outer Dash Panel Insulator
EDIT: I think this is the big insulator in front of the firewall
There is another part number related to the lower one:
55225-35080 --> Dash Panel Heat Insulator No. 1 for 1996 to mid-1998
Here's a link to the diagram I was looking at:
FRONT FENDER APRON & DASH PANEL | 4RUNNER VZN185L-GKPZKA RZN18#,VZN18# | Toyota | Genuine Parts Catalogs | PartSouq Auto Parts Around the World
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 06-21-2021, 09:00 PM #6
cl4Rk's Avatar
cl4Rk's Avatar
Originally Posted by HiluxSurf SSR-G View Post
the part number Ö
Awesome, thank you. Yes, those look like the right part numbers.
It also looks like these parts are no longer available. So it will be the cut-to-size-then-peel-and-stick solution from me.
Thanks everyone!!
back , cleaning , heat , putting , shields
Heat shields falling off caper 5th gen T4Rs 1 02-21-2016 08:50 PM
Heat Shields for front windshield NoDak General Discussions 6 05-30-2014 07:51 AM
Exhaust Heat Shields Maritimer 3rd gen T4Rs 0 05-09-2012 01:48 PM
exhaust heat shields o-evets 4th Gen T4Rs 9 05-01-2012 04:21 PM
are heat shields necessary? djrocketodd 4th Gen T4Rs 4 11-28-2011 01:23 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
