Old 06-22-2021, 01:51 AM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Removing stripped screw on roof rack
I'm in the process of removing my roof rack rails so I can repaint them. I hit a little snag when I realized that the last owner was a nutcase and went to some length to prevent the removal of just one of the roof rails.
The roof rack uses torx screws to hold it in place. The last owner filled in the torx head with a metal plug and bonded it in place, so its essentially a rivet now. The plug was completely flush.
I took a Dremel and attempted to cut a slot in it so I could remove it with a flat screw driver. That failed because the slot stripped, and I can't remove any more material before I start cutting the roof rack itself.
So what are my options now? Drill out and increase the screw size or try a screw extractor?
If worse come to worse, what size drill bit should I get to drill out the screw?
Pyral is offline   Reply With QuoteReply With Quote
Old 06-22-2021, 03:08 PM #2
ReconcileUs's Avatar
ReconcileUs ReconcileUs is offline
ReconcileUs is on a distinguished road
I'd say drill it out. Just match it up to another screw that you've already removed by eye.
Not sure why you say you need to increase the screw size.
99' SR5 | Purchased 171k 2019 | 214k
ReconcileUs is offline   Reply With QuoteReply With Quote
Old 06-22-2021, 04:13 PM #3
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
In the case I ruin the old threads and need to rethread it
Old 06-22-2021, 04:22 PM #4
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Not sure if you have access to a welder but you could try to weld a nut to it? Would also loosen it with the heat from the weld too.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 06-22-2021, 06:07 PM #5
ledger35's Avatar
ledger35 ledger35 is offline
Real Name: Bob
ledger35 is on a distinguished road
ledger35's Avatar
Real Name: Bob
Other than that bullshit, is it a relatively easy job to do? Are you keeping the rack together or separating it?
ledger35 is offline   Reply With QuoteReply With Quote
Old 06-22-2021, 07:11 PM #6
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
Removing everything from the roof is a really simple job. Each roof rail has 4 or 5 torx screws holding it to the roof, the outer 2 torx screws also hold down a plastic cap preventing you from sliding the cross bars off. Once you remove the rail caps you can slide the cross bars off, it makes it easier to lift the roof rails (the ones that run the length of the roof) off. If the last owner hadn't put a hardened plug in one of the screws, I could remove everything off the roof in 15 minutes.
From there you can go about disassembling the roof components. The crossbars and roof rails have a rubber insert to protect the paint when they are fitted to the roof, you can just slide it out. You need a Philips screwdriver to separate the plastic part of the crossbar from the aluminum part (I'm only painting aluminum so I separate the plastic parts). I keep everything labeled in plastic bags, but I don't think there are any parts that could be mixed up.
Old 06-23-2021, 11:45 AM #7
PrinceValorum's Avatar
PrinceValorum PrinceValorum is offline
PrinceValorum will become famous soon enough
You could try a chisel and hammer to loosen the bolt, that will work even with the slot you cut being stripped. If you end up having to drill it, I'd use a left handed drill bit. Sometimes that alone will back it out as well.
PrinceValorum is offline   Reply With QuoteReply With Quote
Old 06-24-2021, 12:45 PM #8
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
I don't recall how much access there is to the fastener, but if you can get a pair of these pliers on the screw, this may be a good way to go - ENGINEER PZ-58 Screw Removal Pliers Extractor Pliers (Combination Pliers), with unique non-slip jaws for quickly removal of damaged or rusted fasteners - - Amazon.com
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
rack , roof , screw , stripped , torx
Roof rack rail screw size JBurt 3rd gen T4Rs 10 03-21-2023 07:32 PM
Stripped Roof Rack Screw Head ColoradoToyota 5th gen T4Rs 10 11-18-2019 11:53 AM
Missing Screw Factory Roof Rack DEKA3 5th gen T4Rs 20 05-02-2019 09:50 PM
Roof rack screw Intruder 5th gen T4Rs 4 08-22-2011 02:33 PM
WTB: knob/screw for 2002 roof rack HNTMUP Want to Buy/Trade 0 08-20-2008 05:30 PM
