Old 06-22-2021, 11:27 PM #1
TheSaturnV TheSaturnV is offline
TheSaturnV will become famous soon enough TheSaturnV will become famous soon enough
Original MY2000 Radiator vs current 2020 Denso "OEM" w/ bonus cutaway pics
I'm no radiator or metals expert, but the current Denso offering, made in Taiwan and available over the Toyota parts counter seems to be of a very similar quality to the original. The transmission fittings were handled a little differently, but it plugs right in and still has the handy metal hangars built in so it will stay put on its own until you can get the bolts started. EZ one man job. The biggest difference I can see is that there are about 67 core tubes in the original rad, and around 55 in the current offering.
Here are some comparison shots, and I also took my sawzall to the old rad for fun. I had always assumed the strawberry milkshake syndrome was a failure of the plastics, but obviously not.
I wonder if the transmission core tubes themselves developing holes or is the leak developing where the in/out fittings connect in to the tubes? I wonder if this is why they changed how those fittings bolt in because you can see it's an entirely different way they attached it. I wish I would have put a big wrench to those fittings before chucking it in the dumpster.
Overthinking for sure, but just curious.
Original MY2000 Radiator vs current 2020 Denso "OEM" w/ bonus cutaway pics-img_9240-jpg  Original MY2000 Radiator vs current 2020 Denso "OEM" w/ bonus cutaway pics-radcomp1-jpg  Original MY2000 Radiator vs current 2020 Denso "OEM" w/ bonus cutaway pics-radcomp2-jpg  Original MY2000 Radiator vs current 2020 Denso "OEM" w/ bonus cutaway pics-img_9266med-jpg  Original MY2000 Radiator vs current 2020 Denso "OEM" w/ bonus cutaway pics-img_9267med-jpg
"Not everyone is cut out to be a 3rd Gen owner."
2000 Black LTD with ELOCKER, almost 100% stock
TheSaturnV is offline   Reply With QuoteReply With Quote
Old 06-22-2021, 11:59 PM #2
JZiggy's Avatar
JZiggy JZiggy is online now
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Cool, I love teardowns! Thanks for sharing. That is very interesting about the construction of the ATF passage. Great info!
One disappointing thing is the design of the drain on new Denso units. Seems to always make a mess unless you’re very careful.
JZiggy is online now   Reply With QuoteReply With Quote
Old 06-23-2021, 01:13 PM #3
You can uncrimp the tank from the bottom of the core to see things a bit more clearly:
The pink milkshake happens from internal corrosion, likely from lack of changing the coolant sufficiently. That pic above is my radiator from a few years back that was original with like 270k miles on it...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 06-23-2021, 06:51 PM #4
Thanks PD, I knew this was probably well covered ground. I like your surgical look better than my caveman attempt.
Old 06-24-2021, 03:39 AM #5
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
it would be interesting to see one that had gone milkshake
Old 06-24-2021, 08:36 AM #6
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
yes, as that would give a definite indication on where and how failure occurs
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
current , original , rad , radiator , tubes
Frasty's very original white TRD "Faux" build Frasty 5th gen T4Rs 10 05-23-2018 02:04 AM
Pics of 2.5"/1.5" leveling kit w/ 1.25" wheel spacers pics Jake_289 5th gen T4Rs 2 04-08-2014 03:01 PM
Do OEM spark plug wires say "DENSO" on them? Ask10 3rd gen T4Rs 6 04-01-2014 03:59 AM
Current VLEDS.com promo code: "CLUBLEXUS" SFAngus 3rd gen T4Rs 0 12-20-2013 03:44 AM
What is the current list of "Customize Settings" for the latest version of TechStream 38vn38fa 5th gen T4Rs 0 02-28-2013 11:18 PM
