Old 01-12-2012, 02:57 AM #1
Nashvegas34's Avatar
Nashvegas34 Nashvegas34 is offline
Nashvegas34 is on a distinguished road
P0751 caused by low transmission fluid level
I'm adding this mainly so it shows up in a search for someone else down the road, as it had me stumped for a good couple if days until I realized I was the idiot.
A year or so ago I managed to trigger error code P0751 - Shift Solenoid "A" Performance or Stuck Off - because of how I performed a basic transmission fluid drain and refill. In order to get the container I had on hand under the drain plug, I drove my truck up on some ramps to elevate the front end a little. After draining, I refilled to what appeared to be the right level on the dipstick and went on my way. A day or so later my check engine light came on, caused by P0751. For some reason it didn't occur to me to recheck the fluid level because all of my research turned up people approaching the problem by replacing the solenoid inside the transmission pan. When the light bulb finally came on in my head I checked the fluid on level ground and it was low. I added to the correct mark, then disconnected the negative cable on the battery to reset the ECU, and the error never came back.
There are a bunch of codes related to shift solenoids that may or may not pop up as a result of a low fluid level. I happened to get P0751. Here are others:
P0750 Shift Solenoid "A"
P0751 Shift Solenoid "A" Performance or Stuck Off
P0752 Shift Solenoid "A" Stuck On
P0753 Shift Solenoid "A" Electrical
P0754 Shift Solenoid "A" Intermittent
P0755 Shift Solenoid "B"
P0756 Shift Solenoid "B" Performance or Stuck Off
P0757 Shift Solenoid "B" Stuck On
P0758 Shift Solenoid "B" Electrical
P0759 Shift Solenoid "B" Intermittent
P0760 Shift Solenoid "C"
P0761 Shift Solenoid "C" Performance or Stuck Off
P0762 Shift Solenoid "C" Stuck On
P0763 Shift Solenoid "C" Electrical
P0764 Shift Solenoid "C" Intermittent
2000 4Runner SR5 2wd | 3.4L V6 Auto | Millenium Silver Metallic | 218,000 miles, 1 owner | Sonoran Steel 3.0 ('99 coils) | Tundra 199mm brake upgrade - Brembo blanks & Akebono pads | Koyo 1998 radiator | Bridgestone Dueler A/T 265/75/16 tires | Hella MicroDE fogs | Rear-facing aux lights | Deckplate mod | Fiamm Freeway Blaster horns | Curt Class III receiver | SilverStar Ultra bulbs
Nashvegas34 is offline   Reply With QuoteReply With Quote
Old 11-27-2023, 06:15 PM #2
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
Great tip
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 11-27-2023, 07:36 PM #3
The final step is always to check the transmission fluid level when warm on a level surface - the cold marks are only for reference.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
how to check transmission fluid level? Idgy Maintenance/Detailing 14 01-03-2022 05:05 PM
transmission fluid level bcantrell Maintenance/Detailing 10 03-31-2020 02:35 PM
Checking A/T fluid level (non-sealed) A/V1 Maintenance/Detailing 1 06-28-2011 12:39 AM
3rd gen transmission fluid level question wm69 Maintenance/Detailing 8 11-19-2008 12:31 AM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
