Old 07-06-2021, 06:10 PM #1
Limoncho Limoncho is offline
Limoncho is on a distinguished road
Question Not shifting into 4th unless I let off the throttle
Recently I've adjusted the kickdown cable (was loose), as far as I my understanding goes this won't affect upshifting, right now at highways speeds 100km+ the transmission won't shift into 4th (3k rpm) unless I let off the throttle for a split second, it will shift eventually but I feel it should not take that long. Any advice?
Limoncho is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 07:30 PM #2
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
will affect Trans oil pressure. Adjust the throttle cable per manual, you need to put that small black ball 50% out of the cable, if I remember well.
Edit: went to look, you have a small, round (1-2 millimeter) plastic cylinder on the transmission cable attached to the throttle body. The cable goes out a grommet, and that black cylinder shall be 50% in and 50% out of the grommet (center).
the small black cylinder attached to the wire you see in that picture must be center with the black grommet.
throttle valve cable/transmission kickdown cable stuck
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
Old 07-07-2021, 11:31 AM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Adjusting that cable only affects shift firmness by changing the line pressure in the transmission. Is the engine and transmission warm when this happens?
Old 07-07-2021, 12:34 PM #4
ReconcileUs's Avatar
ReconcileUs ReconcileUs is offline
ReconcileUs is on a distinguished road
Have you tried the ECT power button? That changes the shifting speed to shift quicker. Not an actual solution but curious about the effects.
99' SR5 | Purchased 171k 2019 | 214k
ReconcileUs is offline   Reply With QuoteReply With Quote
Old 07-07-2021, 01:34 PM #5
Yes, this happens after the engine is at operational temps
Old 07-07-2021, 01:36 PM #6
When running ECT on the city my MPG is way too low, I used to run ECT all the time and the upshifts where indeed quicker
Old 07-07-2021, 02:05 PM #7
Real Name: Patrick
Real Name: Patrick
Have you checked your transmission fluid level and condition?
4th , rpm , shift , split , throttle
Quick Fix for better Throttle Response, Better Shifts (Throttle Cables) gamefreakgc 3rd gen T4Rs 5 07-03-2019 12:54 PM
2002 6cyl. 175k Vacuum leak, Throttle Body throttle lever? Hollywood1 3rd gen T4Rs 3 12-29-2018 06:25 PM
The small black plastic "cap" on throttle body near throttle cable - What is it? bugman-74 3rd gen T4Rs 3 03-10-2015 10:23 PM
Electric throttle body to cable throttle body conversion Dirtyfingers 3rd gen T4Rs 8 12-29-2014 10:05 AM
Throttle body troubles...WOT=half throttle Idahosr5 3rd gen T4Rs 0 10-31-2010 04:09 PM
