Old 06-29-2021, 07:57 PM #1
fatherohenry's Avatar
fatherohenry fatherohenry is offline
Real Name: Mark KN6TZI
fatherohenry is a jewel in the rough fatherohenry is a jewel in the rough fatherohenry is a jewel in the rough
Brake Line Suggestion with TBU
I just ordered Cardone Ultras (13WE) from rockauto and OEM rotors and pads from Toyota for the 199 TBU on my stock height '96 SR5.
I can't get a grip on which part number this cracked hose is. My best guess from the diagrams at parts.toyota is 9094702862 Brake Hydraulic Hose and it's $76. Am I getting this wrong? I know critical systems really require OEM and brakes are pretty critical, but $76 for a length of hydraulic hose seems nuts.
I've read tons of posts about "stainless steel lines" for the TBU but my experience here is limited and I just want to get it right, preferably the first time. Odds are as soon as I finish the TBU this will start leaking. Any chance there's a kit that contains every brake hose/line I need (at a reasonable price)?
EDIT: Looks like I have time to figure this out. Dealership emailed telling me rotors are on back order until the end of July. I called another dealership and he says there are zero in the country, 670 in transit and 1700 back ordered.
Perhaps this Performance Brake Line Set from Wheelers?
Brake Line Suggestion with TBU-img_2898-jpeg  Brake Line Suggestion with TBU-2021-06-29_16-48-50-jpg
'96 T4R SR5 | 4WD | Auto | 199 TBU | 262k+
fatherohenry is offline   Reply With QuoteReply With Quote
Old 06-30-2021, 03:12 AM #2
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
get the wheelers braided brake lines. also, you don't have to use Toyota rotors. you can get slotted aftermarket rotors
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 06-30-2021, 11:38 AM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I'm using wheeler's front brake lines as well with no issues.
A little advice for you when you got to replace the brake lines, use a length of wood/pipe/etc to wedge between the front of the driver seat bottom and the brake pedal pushing the brake pedal about 1/2"-1". This will keep your brake system from continually draining when you open the brake line. You'll lose some brake fluid initially but it won't continue to free flow brake fluid. If you decide to do this and you're going to take longer than an hour I would recommend disconnecting the battery or the brake switch to keep the battery from draining down too low from the brake lights.
Old 06-30-2021, 01:51 PM #4
You can also just put a vacuum cap over the brake lines while doing the line/caliper swap.
Don't let the master get dry if you can help it - it is a huge pain to get re-bled correctly.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 06-30-2021, 04:21 PM #5
I saw those caps in Tim’s list on YT and ordered them along with the plugs. Anything to help the job go smoother, especially for this novice!
Old 06-30-2021, 04:40 PM #6
Too many options. Took me long enough to decide on calipers! Plus I recalled seeing image comparisons between OEM & aftermarket rotors somewhere that indicated OEM was the way to go. But I’m rethinking it now that I’m looking at at least a month and having to break off the wear indicator tab in the meantime.
$76 , brake , hose , hydraulic , tbu
Rear Center Line installation and other SS brake line info tv4184 4th Gen T4Rs 7 07-10-2023 04:33 AM
FS: Galfer USA Brake Line Assembly tool with SS Line tacticalone For Sale: Non-T4R Items 4 09-09-2015 01:27 PM
e brake line too short? landcruiser e brake? D Farms 3rd gen T4Rs 0 05-25-2015 12:19 AM
Help On Brake Calipers - Looking For auto repair in chicago, Any suggestion? toyotainnova64 General Discussions 1 04-27-2011 03:35 PM
