Old 06-29-2021, 09:32 PM #1
domhanna domhanna is offline
domhanna is on a distinguished road
IDK what to do for my suspension HELP
So I just bought a 1999 4Runner and it needs some suspension work. I found a 16 Piece kit on 1AAuto. It's from TRQ. I'm just concerned because it's $358.95 and that seems really cheap. Is that just because it's an OE replacement and not a lift?
Here's the link to the kit: 1996-02 Toyota 4Runner 16 Piece Steering & Suspension Kit TRQ PSA59936
If you recommend against this what would you recommend for a near OE replacement of shocks struts and coils? I don't want to lift it right now cause it's just not in my budget. I'd be willing to lift a bit if it's affordable no more than 1.5" though.
domhanna is offline   Reply With QuoteReply With Quote
Old 06-29-2021, 10:11 PM #2
3rdgensnowhite 3rdgensnowhite is offline
3rdgensnowhite is on a distinguished road
I would buy LBJs only from oem heres the part numbers
RH LBJ: 43330-39585
LH LBJ: 43340-39465
4 bolts for each side of LBJ (8 total): 90080-10066
as for the rest, what are your intentions with the car?
3rdgensnowhite is offline   Reply With QuoteReply With Quote
Old 06-29-2021, 10:18 PM #3
calimobber's Avatar
calimobber calimobber is offline
calimobber will become famous soon enough
calimobber's Avatar
Yeah I would avoid that. Stick with oem for the ball joints but for suspension you have so many options. I just went with ome rear coils and reused the factory fronts. went bilstien 5100 all around which have me about 2" lift. That cost me like $550 shipped? The front is a little springy since the factory coil is so compressed so Id prob just get ome all around and still get the bilstiens if your trying to keep the cost down.
deal with the other components separately. lower ball joints are the only ones you should consider replacing if they old. others can be put off unless you notice big problems.
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
Old 06-29-2021, 10:46 PM #4
RH LBJ: 43330-39585
LH LBJ: 43340-39465
Honestly, right now I'm keeping it mostly stock. I just need a reliable truck to get me to college and back and haul my stuff and friends around.
Old 06-29-2021, 10:50 PM #5
Where did you find OEM springs that cheap, I'm looking at $625 for all four springs from my nearest dealership?
And where did you buy the Bilstiens from I found 4600s on shock surplus @ $333 for all four.
Old 06-29-2021, 11:56 PM #6
fatherohenry's Avatar
fatherohenry fatherohenry is offline
Real Name: Mark KN6TZI
fatherohenry is a jewel in the rough fatherohenry is a jewel in the rough fatherohenry is a jewel in the rough
For what it's worth I saved about $40 by asking the dealership for the recall kit that contains both LBJs and 4 cotter pins - 04005-02235. Paid $211.
I put on new castle nuts too, 2/$7 90171-A0005
'96 T4R SR5 | 4WD | Auto | 199 TBU | 262k+
fatherohenry is offline   Reply With QuoteReply With Quote
Old 06-30-2021, 12:51 AM #7
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
OME (Old Man Emu) is a manufacturer with their own line of springs primarily for lifted Toyotas. It can definitely cause confusion. If you are looking to keep things stock, KYB Gas-a-just or Bilstein 4600's are generally the recommended aftermarket shocks. As far as springs go, you almost certainly don't need to replace the fronts, but are more likely to need to replace the rears as they do tend to sag.
As others have said, the typical recommendation is to go OEM only for lower ball joints as a failure is catastrophic. I would stay away from that kit.
Skulking is offline   Reply With QuoteReply With Quote
Old 06-30-2021, 12:59 AM #8
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
I've used 1AAuto for my 2006 Civic many times and their parts all came out great other than the engine mount kit I bought from them which had to be modified to fit correctly. I wouldn't mind using their suspension parts but I would definitely skip their lower ball joints and get strictly OEM's. Don't expect them to last like the Toyota parts though.
2000 4Runner Limited 4x4 V6
Old 06-30-2021, 11:44 AM #9
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Both LBJ's 04005-02235 (1 required) (comes with cotter pins)
Castle nut 90171-A0005 (2 required)
LBJ Bolts 90080-10066 (8 total required) (59 ft/lb)
kit , lift , recommend , replacement , suspension
WTB: TRD Pro Rear Suspension Take-Offs (Shocks & Suspension) - Houston, TX steveh_2007 For Sale: Suspension/Wheels/Tires 0 03-06-2020 12:02 PM
Box of new 4th gen suspension parts(Energy Suspension, OME, MOOG) and headunit $35 nytosc For Sale: T4R Items 0 08-06-2019 01:01 PM
FJ TRD suspension vs FJ TT suspension vs 5100 & FJ coils andreylights 4th Gen T4Rs 4 11-16-2018 12:48 PM
Swappin my OEM suspension to FJ Cruiser suspension James_T 4th Gen T4Rs 15 08-17-2010 09:04 PM
