Originally Posted by 96RedRunner
The quirks of VSC and TC in the 01-02's. Could try recalibrating VSC or go with the Andy Mod 2.0
I have done both Andy Mod does the trick. Lots of Info to read to understand how system works How-to's on both in forum.
166k mi is nothing for a 3rd Gen.
this is right on, and the Andy Mod is the way to go, even if you were not having problems because the VSC/Trac is designed to not only regulate what power goes where using the abs system to apply brakes, but will also cut power to engine when you need it most.
I think I saw on youtube where a guy just unplugged something from the master cylinder for a temp disable
Sean did a nice video on this mod and its listed under his and timmys videos
