Old 07-02-2021, 04:04 PM #16
Originally Posted by Biogenic View Post
It’s green. Should I just run a few gallons of distilled water and just flush the system out and then add the Toyota red ?
Don't just run it through, do a fill with just distilled water for a week (or at least one full heat/cool cycle). Drain, repeat... Make sure to operated front and rear heaters. Then do the red. Assume there will be some distilled water left when you fill, which is fine if you are mixing your own red.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-02-2021, 05:35 PM #17
NachesPass4x4 NachesPass4x4 is offline
NachesPass4x4 is on a distinguished road
Originally Posted by HiluxSurf SSR-G View Post
if the water coming out of the garden hose contains lots of hard minerals, then that will be an issue. better to use distilled water
removing the radiator hoses and putting them back several times to do several flushes wouldn't be practical. just open/close the radiator drain cock
I agree hose water isn't ideal. If you run the distilled water through when your done though, the amount of hose water that remains is going to be pretty small. I've had good luck with this method. The pressure you can build up has blown out some pretty crazy stuff that wasn't going to come out on its own.
NachesPass4x4 is offline   Reply With QuoteReply With Quote
Old 07-02-2021, 09:36 PM #18
Biogenic Biogenic is offline
Biogenic is on a distinguished road
So, after flushing everything out, how many quarts of distilled water are left in the system just doing the radiator drain? Want to calculate the coolant / water ratio when adding the red.
Biogenic is offline   Reply With QuoteReply With Quote
Old 07-02-2021, 10:43 PM #19
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
yep...doing the radiator drain wont drain the block fully so you will have some left over fluids left in it...
being honest...I dont know your answer to how many quarts etc are left....however.. when I do a flush...I run the full strenth...not the dilluted and I add distilled water to that .I use one of those cheap antifreese testers to tell me how cold the outside world can get...since I need to be good to -40 but I aim for -50. But some antifreeze jugs tell you the conversion ...say...-40 is this ratio.
I dont think without doing a block and heater drain...you will never really know the exact ratio you are running
Old 07-03-2021, 05:04 AM #20
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
if you like, you can also drain the cylinder block. the drain for the cylinder block is on the RH side, between the 1st and 2nd cylinders, just in front of the engine support.
you need to undo the drain cock (bolt) then the coolant comes out of the drain union just below the drain cock.
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 04:27 PM #21
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
When I did my radiator/timing belt/water pump replacement I calculated about a half gallon of water was still in the engine from my previous flushes.
case , coolant , find , iphone , sale…
V6- coolant not siphoning back from coolant overflow (not overheating) djtc 4th Gen T4Rs 32 08-27-2021 10:13 AM
Dealer Coolant Flushed with Wrong Coolant? peebee 4th Gen T4Rs 35 07-02-2021 05:52 AM
pink coolant and green coolant Larry Maintenance/Detailing 30 11-17-2014 11:09 PM
Coolant Leak- Drivers side coolant manifold? Shibby! 3rd gen T4Rs 19 12-28-2012 09:37 PM
22RE headgasket 'reversal' - coolant in oil, then oil in coolant kompression 3rd gen T4Rs 0 09-20-2005 12:23 AM
