Old 07-01-2021, 02:39 PM #1
jzarech's Avatar
jzarech jzarech is offline
jzarech is on a distinguished road
jzarech's Avatar
97 4Runner Takes Five or Six Revolutions to Start
I just put a new engine (50k mile used engine) in my 1997 4Runner Limited with 320k miles - and it runs amazing!!!
The only issue is that it takes 5 or 6 six engine revolutions to start.
It seems like the fuel is getting pumped from the tank to engine every start instead of holding pressure in the fuel rail after shutoff like it should.
I have no proof of this and there's no fuel pressure connector on fuel rail to prove this to test this theory.
I've seen this behavior on our jeep wrangler in which a new fuel pump solved it. It has a one way valve in the fuel pump to prevent draining fuel rail back into tank.
Here's the details --
Before the engine swap I had put in a brand new Denso Fuel Pump (OEM), brand new OEM Fuel Filter, and Brand new OEM Fuel Pressure Regulator.
On the engine swap it looks like they replaced the vacuum line from the fuel pressure regulator to the intake manifold. Other than that it's all OEM parts.
I double checked with shop and they used all of my old parts including the fuel pressure regulator.
And, again, the truck runs absolutely amazing.
Thanks for your help.
Joseph
jzarech is offline   Reply With QuoteReply With Quote
Old 07-01-2021, 04:16 PM #2
phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of
Every 3rd gen I've seen (including mine, since new) has taken a bit to start. Like, about 1-2 seconds with the key. Just about the time you think something is wrong, bam, perfect start.
Most other cars (including other Toyotas) start faster when they are working...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-01-2021, 07:54 PM #3
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot is a glorious beacon of light Devbot is a glorious beacon of light Devbot is a glorious beacon of light Devbot is a glorious beacon of light Devbot is a glorious beacon of light
Devbot's Avatar
Real Name: Devan
^^^ this. You would probably have an easier time listing the cars from the era that DO start up right away over ones that don't. The only time I get immediate start up is when the engine's only been off for a few minutes - though I will say when I replaced my starter, there was a couple of days initially where it did start slightly but noticeably faster (as in 1 second compared to 2 seconds) but even that went away pretty quick
You can only expect so much from a low compression engine from the 90s
Y2K Highlander Millennium Silver 3.4L auto @ 295k and climbing
Tundra TRD Lift in Front / LC Lift in Rear / JBA UCAs / CVJ 9168R Axles / Diff Drop / PCK / Extended Bump Stops; Brake Lines; Sway Bar Links; Rear Diff Breather / True North Fab. Hybrid Bumper / Smittybilt XRC Gen 3 Comp. / Northstar 880CCA AGM / Drivelines NW Rear Shaft / Lil Skip Gas Skid / BudBuilt Front Skid
Old 07-01-2021, 07:56 PM #4
Eh, my '89 Camry with a '95 JDM 3s-gte starts up with just a tap of the key most of the time. Less than half the time of the 4Runner, at least. Always been that way...
Old 07-01-2021, 08:43 PM #5
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 is a jewel in the rough jgue467 is a jewel in the rough jgue467 is a jewel in the rough
jgue467's Avatar
Mine almost always takes 3-4 turns to fire up, every once in a while only part of 1 turn.
Also in your case engine may just need to be run for a few weeks before it gets back in the groove of things.
Could clean MAF, IAC and some of intake, may help. Luck.
2001 Limited 4WD - 333+K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL, ZERO RUST - StopTech ANGLED rotors - Magnefine trans filter - In series trans cooler, ORIGINAL: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and so on. WooHoo!!
Oh yeah, GO LONGHORNS!
Old 07-01-2021, 08:47 PM #6
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
totally normal. Mine does it for the last 200K miles I've owned it. Still original starter and every imaginable maintenance is done.
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
engine , fuel , pressure , regulator , start
WTB: ABS ecu, wheel sensor, and Transmission revolutions sensor ZionXIX For Sale: T4R Items 0 10-16-2017 11:20 AM
Warm engine takes longer cranking time to start? dbsoundman 3rd gen T4Rs 10 11-06-2014 07:30 PM
2000 4runner wont start without clutch start cancle jmcgahran 3rd gen T4Rs 3 08-29-2011 12:27 PM
takes a bit to start up??? 4rnr4me Problems & Warranty Issues 10 02-21-2011 12:06 AM
4Runner takes midsize SUV value award OUTRNNR 4th Gen T4Rs 1 02-03-2006 06:06 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
