Old 07-01-2021, 04:10 PM #1
ReconcileUs's Avatar
ReconcileUs ReconcileUs is offline
ReconcileUs is on a distinguished road
Question Engine sputtering / stuttering at 2500 rpm?
I have a 1999 4Runner SR5 with 208,000 miles that just developed a random issue when I picked my car up from my mechanic for an unrelated issue.
The engine is sputtering / stuttering at 2500 rpms. There's no check engine codes. It happens even in neutral. Anyone have any ideas as to what this could be?
My mechanic is very busy and he said he doesn't want to guess or throw parts on it and told me maybe I should just pay a dealership $150 to diagnose it.
99' SR5 | Purchased 171k 2019 | 214k
ReconcileUs is offline   Reply With QuoteReply With Quote
Old 07-01-2021, 04:23 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
What did you have done at the mechanic? What is the previous maintenance history?
Old 07-01-2021, 04:30 PM #3
This is my thread about that issue.
My mechanic texted me saying he "Installed the new fan clutch, replaced some hose clamps that leaked under pressure, replaced the radiator cap because I did not like how it felt or what it was doing... I let the car run about an hour temp just under the middle - $120 total"
Previous maintenance history link here
As far as the maintenance history is concerned, the only thing that catches my eye that I think could be related to this issue, is the new catalytic converter. I had to get that due to a "cat not ready" status for state emissions test, no check engine codes.
Old 07-01-2021, 04:37 PM #4
Real Name: Patrick
Real Name: Patrick
Do you have a Federal (1 cat) or California (2 cats) emission vehicle? Are you able to get the rpm's above 2500 rpm's? If you can does it clear up, get worse, or stay the same?
Old 07-01-2021, 04:41 PM #5
Federal, stay the same or worst. Didn't really try to push it. I'm not near the vehicle right now or I'd test it further for more solid answers.
Old 07-01-2021, 05:15 PM #6
Real Name: Patrick
Real Name: Patrick
Well there went my clogged cat theory... Do you have a way to scan it? It might have a pending code if you're lucky. I see that you did spark plugs in 2019, do you remember if you did spark plug wires at the same time?
Old 07-01-2021, 05:43 PM #7
spartacus's Avatar
spartacus's Avatar
Battery terminals, fender ground good. Clean the maf and see how it does. If problem still there then look at fuel pump, filter, injectors.
Old 07-01-2021, 05:49 PM #8
gamefreakgc's Avatar
gamefreakgc gamefreakgc is online now
Real Name: Jerod
Real Name: Jerod
If you can get your hands on the FSM, test the Throttle Position Sensor. They can go bad, not throw a code, and cause the engine to stumble or even stall.
326WHP 347TQ
gamefreakgc is online now   Reply With QuoteReply With Quote
Old 07-06-2021, 05:09 PM #9
Update: This is the Toyota Dealers diagnosis
Crankshaft sensor: graphing crank sensor shows senor is breaking up around 2500-3000 RPM. Replace crank shaft position sensor and removing timing covers to inspect for damage to crank timing gear/trigger wheel
Question: Anyone have the part number for this?
I tried searching the forums but not finding much
Old 07-20-2021, 03:40 PM #10
Replaced crankshaft position sensor with DENSO 196-1109.
Issue fixed.
Side note: Expensive for me ($300 labor only) because apparently someone broke the bolt head off and my mechanic struggled with it for days. Or he could've broke it and lied (which I doubt but?), who the hell will ever know.
Old 09-25-2021, 04:26 PM #11
Dealt with some new rapid stuttering, even at idle.
Problem & Solution: No check engine light, pending misfire code, ended up being some loose spark plugs.
Old 09-26-2021, 06:43 PM #12
turkeyman turkeyman is offline
turkeyman is on a distinguished road
cps
how do you access the crankshaft position sensor?
turkeyman is offline   Reply With QuoteReply With Quote
Old 12-30-2021, 10:14 PM #13
Post Final Update (hopefully?)
Update on this issue. Hopefully the last one.
Haven't driven much since the sensor issue. 2500 miles later, new issue. Currently at 211k with the issue fixed.
New stuttering: engine loosing power at idle and while driving after 30-40+ minute drives. Rough idle after engine driven 30-40+ minutes. Able to drive it but engine sputtering, max 45-50mph.
I replaced the spark plugs (6) and the wires (3) with NGK. Problem solved.
Old wires were NGK with only about 50k miles on them. The old spark plugs were the same NGK Iridium plugs, with only 40k miles on them, but dirty. Could possibly be due to valve cover gasket leaks, which were recently replaced.
I would recommend Denso plugs. A lot of reports of them lasting a really long time.
Old 01-02-2022, 09:37 AM #14
superhomunculus's Avatar
superhomunculus superhomunculus is offline
superhomunculus is on a distinguished road
Did you check for vacuum leaks? I wonder if a vacuum hose came loose or broke on one the previous repairs.
Edit: For some reason my missed the part "problem solved" I need my coffee.
superhomunculus is offline   Reply With QuoteReply With Quote
Old 01-02-2022, 10:06 AM #15
bmason8159 bmason8159 is offline
bmason8159 is on a distinguished road
For plug I wouldn’t use anything that didn’t have to prongs. It says right on the engine not to use single prong plugs
bmason8159 is offline   Reply With QuoteReply With Quote
engine , issue , rpms , sputtering , stuttering
Bad stuttering/sputtering under any load (Help, out of state) jross20 3rd gen T4Rs 23 08-11-2020 04:02 PM
Rough Idle, Engine Sputtering, Engine Ticking, Flashing CEL Sotovo 3rd gen T4Rs 29 04-18-2016 10:35 PM
1994 3.0l engine missing/stuttering hargee Maintenance/Detailing 3 04-13-2013 12:05 PM
Engine stuttering after replacing tbps BRONXRUNNER 3rd gen T4Rs 2 10-30-2011 07:36 PM
New 2011 T4R Engine Stuttering TroutBoy 5th gen T4Rs 4 11-17-2010 12:19 AM
