Old 07-01-2021, 05:57 PM #1
denvermaxd denvermaxd is offline
Real Name: Max
denvermaxd is on a distinguished road
Real Name: Max
How do I check the steering rack?
With summer and the ability to drive with my windows down, I noticed a lot of noise from my tires (Cooper Discoverer A/T3). I also noticed the tires were wearing unevenly in front, so I figured my alignment was wonky. I've done quite a bit of off-roading and just driving on super rocky/bumpy roads the past couple years without an alignment adjustment.
Took it to a local Brakes Plus because it's just an alignment, right?
They told me they couldn't align it because, "Steering rack has quite a bit of internal looseness causing steering angle to be off and tire wear, needs the rack replaced before a proper alignment can be set."
I haven't noticed anything specific about the steering feeling funny until now. Since I got it back, I have noticed a definite "wobble" at highway speeds.
So my question is: How can I verify there's an issue with the steering rack?
I'm inclined to DIY, and typically use OEM Toyota parts, so I'm leery of ordering $700 worth of parts and spending my weekend under the truck if it's not really necessary.
2000 4Runner SR5 5-speed manual e-locker, 231mm Tundra brake upgrade, OME 881/890 Suspension, Stubbs Rock Sliders, TRD Supercharger
2022 Highlander
2002 Dodge Ram 1500
denvermaxd is offline   Reply With QuoteReply With Quote
Old 07-01-2021, 06:57 PM #2
spartacus's Avatar
spartacus's Avatar
Get under the truck have someone else turn the steering and see if there is movement. New bushings could remedy that. Inner tie rods could be shot also kind of pricey I think around 80 bucks a piece. Steering rack guide could have loosened. There is a very specific way off tightening that in the fsm.
edit: A second opinion wouldn't hurt.
Old 07-02-2021, 10:05 AM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Lay underneath and look at the steering rack for movement while someone else turns the wheel lock to lock. Pay attention to the steering rack bushings. Mine are wore out and cause a lot of feedback in the steering wheel when I hit bumps. Jack the front tires off the ground and grab the tire at 3 and 9 o'clock and wiggle back and forth. You will have some movement, but it shouldn't feel like a click or pop movement. It would probably be helpful to have someone in the cab to brace the steering wheel still while you wiggle the tires.
Old 07-02-2021, 05:00 PM #4
jsluse jsluse is offline
jsluse is on a distinguished road
Get the truck in the air, remove at least the back half of the skid plate, with that off you’ll have easy access to look at the rack. I had movement from my rack and replaced the bushings with Poly and it’s great. The bushing in mine were so bad the rack would move left and right, we could actually move it by hand. Energy Suspension bushings we’re like $30.00.
jsluse is offline   Reply With QuoteReply With Quote
Old 07-02-2021, 06:51 PM #5
sportscarfan's Avatar
sportscarfan sportscarfan is offline
sportscarfan will become famous soon enough
^^^What they said.
You can also reduce some of the free play by adjusting the steering rack guide. Some replace it. IIRC, there is an early version and later version.
rack guide replacement.
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
sportscarfan is offline   Reply With QuoteReply With Quote
alignment , bit , noticed , rack , steering
Excessive play on drivers side steering - replace steering rack guide cheeser 3rd gen T4Rs 17 05-05-2022 08:15 PM
Power Steering Pump or Steering Rack? *VIDEO* LexusFTW 3rd gen T4Rs 44 08-11-2021 10:11 AM
Power steering leak/steering rack SRQ-Runner 3rd gen T4Rs 1 10-25-2014 02:13 PM
Steering Rack and Power Steering Pump Replacement thebrandon 3rd gen T4Rs 5 07-02-2013 10:07 AM
Power steering/steering rack question (need help fast) alex bland 3rd gen T4Rs 9 01-09-2010 07:37 PM
