Old 07-02-2021, 04:23 PM #1
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
tbu surprise
ok...so this new to me highlander...history is very very limited, twisting wrenches today.....
someplace....somehwere...sometime someone did a TBU brake upgrade....score
and at one time someone really liked and did mild mods to this rig....
Old 07-02-2021, 05:56 PM #2
rickmum's Avatar
rickmum rickmum is offline
rickmum is on a distinguished road
rickmum's Avatar
dont them seqwoias have the same brakes as them tundras?
1998 Desert Dune Limited w/ rear diff locker
300,000 kms
rickmum is offline   Reply With QuoteReply With Quote
Old 07-02-2021, 06:05 PM #3
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Yet another TBU, yet another report of soft pedal feel. Always wondered if this could just be remedied by swapping the master as well.
Old 07-02-2021, 06:40 PM #4
sportscarfan's Avatar
sportscarfan sportscarfan is offline
sportscarfan will become famous soon enough
Would make sense if you need to move a larger volume of fluid. Is there a bigger direct fit master available?
I've always thought the brakes were adequate on my '97 SR5, but I don't tow.
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
sportscarfan is offline   Reply With QuoteReply With Quote
Old 07-02-2021, 06:45 PM #5
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
The corresponding Tundra master should bolt right up if I'm not mistaken. I believe a few have gone the extra mile and done it but it's certainly less than a handful for whatever reason
Old 07-02-2021, 07:07 PM #6
A few years ago I put 4 piston calipers on the front of my old Honda and found out after the 1st drive I was going to need to change the master. Went from 13/16" to 15/16" and made a huge pedal feel improvement.
Old 07-02-2021, 08:26 PM #7
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
is it the 231mm or the 199mm? Perhaps soft pedal can be remedied with a rebuild of the MC and more brake bleeding
Originally Posted by 3bears View Post
ok...so this new to me highlander...history is very very limited. i wonderd why brakes were soft, twisting wrenches today.....
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 07-02-2021, 09:35 PM #8
Real Name: 3 Bears
Real Name: 3 Bears
wow...i did not know this was going to turn into a brake master cylinder discussion. But funny enough...I have a rear wheel cylinder that leaks so I have new wheel cylinders coming as well as new brake hoses front and back...and was thinking of doing a new master cylinder while at it.....as that would be the only old thing left....
so now.....without changing out booster....wonder what master I can switch too
and dont say chevy....I have seen websites that list the GM master cylinder for this fix....and I wont do it.....no cheby master cylinder for me.
ive driven these 4runners with the TBU and soft pedal for so many years...now it does not bug me much
Old 07-02-2021, 09:42 PM #9
Real Name: 3 Bears
Real Name: 3 Bears
which tundra master ? I was under the impression that there was not a simple bolt on one without changing the booster too
but im open for ideas
Old 07-02-2021, 09:52 PM #10
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Which of the TBU calipers does your Hilander have? If I am not mistaken there are 2 types. Ones that are the same size rotor except the rotors are wider. Or the ones that require the 17 inch wheels with the larger rotor diameters.
Anyways, if you have leaking wheel cylinders. I change those and bleed the system well. Then adjust the back brake shoes up. Might just fix up your softer pedal.
Old 07-02-2021, 09:57 PM #11
Real Name: 3 Bears
Real Name: 3 Bears
when I first got it....it had a soft pedal and a way sloppy ebrake. So one of the fitst things I did was pull drums to inspect. thats when I found it had a very slight leaking wheel cylinder, and thus ordered wheel cylinders. and new SS hoses for all .
being in a giant hurry that day, I did not pay much attention to the calipers...other than bleed the system and adjust the ebrake at drums....and then of course yank the ebrake about 20 times....
it was not until today, inspecting other things on the front end that all of a sudden i noticed....wow...those are the 13we calipers..... the 199's...then I noticed the thicker rotors....how could i not notice earlier...cause the day b4 I had to do brakes on a 2016 ford f250 so did not notice the big brakes on the 4runner
but yep...old ....rusty..but yep at some point in this 4runners life it got a TBU
Old 07-03-2021, 05:13 AM #12
i think the Tundra has LSPV. If your 4Runner doesn't have LSPV, then the Tundra MC may not be compatible.
Old 07-03-2021, 05:16 AM #13
the 1999-2006 Tundra has only one brake rotor size. However, the earlier 199mm calipers were updated to the bigger 231mm calipers and bigger brake pads but rotor size remained the same.
Old 07-03-2021, 12:20 PM #14
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Pretty sure it’s the t100 brake master.. if you go on opt offroads IG page in his saved stories one of them is the t100 master upgrade. It looked like a decent amount of work, he had to shorten the shaft that connects to the brake pedal and also had to install it upside down.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 07-03-2021, 02:40 PM #15
Dahlken Dahlken is offline
Dahlken is on a distinguished road
Sounds like a score! I'm getting ready to do the TBU on my 99 when I install my new Toytec coilovers tonight after work. Finally will be able to get rid of the "college-kid" installed spacer lift with the springs on the wrong side of course!
Dahlken is offline   Reply With QuoteReply With Quote
brake , somehwere , someplace , tbu , upgrade
tbu surprise 3bears 3rd gen T4Rs 0 07-02-2021 04:18 PM
SURPRISE - more tax for you! blackrifle01 Off Topic 82 08-11-2019 09:52 PM
Surprise re: V6 Engine TorontoMike 5th gen T4Rs 20 11-16-2012 10:39 PM
Much to my SURPRISE! TXLUGNUT 3rd gen T4Rs 4 03-16-2011 12:04 PM
Rear window (surprise surprise) but this case seems different than most. Please help! foskco87 Classic T4Rs 2 02-19-2008 02:47 PM
