Old 07-03-2021, 05:26 PM #1
domhanna domhanna is offline
domhanna is on a distinguished road
LED Blinker Hyperflash
I know this has been asked a million times but I can’t find an answer right now and my car needs to pass inspection soon. How do you get LED blinkers not to hyper flash. I’m assuming it’s a resistance thing does anyone know if you can just put a resistor in the circuit to trick it what Ohm?
LED Blinker Hyperflash-099775d5-98cb-4f5c-b8f1-4643a1227662-jpeg
domhanna is offline   Reply With QuoteReply With Quote
Old 07-03-2021, 05:49 PM #2
spartacus's Avatar
spartacus's Avatar
3
You'll have use a hyper flash relay and install it on the back of the ecu by the driver door. Here is a video
https://www.youtube.com/watch?v=w8zLOE4Xgg8&feature=youtu.be
edit: LED turn signal "hyper flash" fix?
Old 07-03-2021, 05:57 PM #3
LV2001BI LV2001BI is offline
Real Name: Rodel
LV2001BI is on a distinguished road
Real Name: Rodel
CF 18 flasher
Install a LED turn signal flasher (CF 18). The pic says Subaru but Toyota uses the same flasher / relay.
LED Blinker Hyperflash-b40db7ea-3da4-492e-b567-edd5a1a496fd-jpg
LV2001BI is offline   Reply With QuoteReply With Quote
Old 07-03-2021, 06:12 PM #4
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
On my Civic I have a Sylvania Resistor installed ($15) and spliced both ends - one to the ground and the other to the blinker. It's still working fine and the blinkers work great.
2000 4Runner Limited 4x4 V6
Old 07-03-2021, 06:16 PM #5
Sparky 97Runner's Avatar
Sparky 97Runner Sparky 97Runner is offline
Sparky 97Runner will become famous soon enough Sparky 97Runner will become famous soon enough
I used this relay from Napa when I installed LED blinkers and it does work. No more hyperflash.
LED Blinker Hyperflash-img_1135-1-jpg
1997 Toyota 4Runner
Sparky 97Runner is offline   Reply With QuoteReply With Quote
Old 07-03-2021, 06:58 PM #6
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Swap the relay, skip the resistors.
With bad luck, a hot resistor can start a fire... I've bought a bike that suffered that fate to use it as a track bike. Nevermind that it's just a sloppy way to fix the problem.
Brian. is offline   Reply With QuoteReply With Quote
Old 07-04-2021, 09:28 AM #7
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
3rd-gens don't use CF18s, those are for 4th-gens.
Old 07-04-2021, 09:56 AM #8
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
The other problem with most resistors is folks simply hack them into the wiring harness. Although it may cure the hyperflash issue, it opens the door to all sorts of (generally more serious) electrical issues down the road.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 07-04-2021, 10:39 AM #9
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
I would do a little more than run a single, tiny LED for a turn signal, that doesn't seem very safe
Old 07-05-2021, 12:52 PM #10
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
I used a adjustable flasher relay has knob on relay you turn to match load. 3 yr so far.
Old 11-09-2021, 03:54 AM #11
AUXITO.COM AUXITO.COM is offline
Real Name: AUXITO AUTO LED LIGHTING
AUXITO.COM is on a distinguished road
Decoder
You can try to use the resistance decoders to solve the problem of light bulb flickering
AUXITO.COM is offline   Reply With QuoteReply With Quote
Old 11-12-2021, 08:54 PM #12
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
How should the resistors be wired? Thank you.
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 11-13-2021, 05:06 AM #13
Back in the 90’s they were just called electronic flash relay. My 94 ram had one factory because of the trailer lights. They are loud when in use.
I used one on (spare from my truck) my motorcycle XL600 enduro when I canned the factory stalks for bark busters with built in led turn signals. Worked great
Old 11-24-2021, 07:03 PM #14
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
i think that now most LED lights are better.now i also know that there is cheap crap out there.....not only the bulbs but the flashers.
i switched all my exterior bulbs to led....well not head lights. Bulbs that many said were good to go. I also used a flasher relay rated for led's...from amazon...cheap.
i did not get hyper flash after that.....but I got an issue where if I stepped on brake ped that both rear turn signals light up dull but also on dash. here on the forum it was suggested I had a bad ground. I went through it all. then one day a member here said dont trust cheap flasher relays. so I went and got one from napa for LED's.....well other than the pain in the butt location for the relay....that fixed my issue.
all the realys come from china i bet...but then there is a better version...and a cheap as cr*p version. same with bulbs.
Old 07-11-2022, 09:29 AM #15
ricarhimel's Avatar
ricarhimel ricarhimel is offline
ricarhimel is on a distinguished road
ricarhimel's Avatar
Thank you for sharing! I have already bought it, and it works great. I needed new blinkers for my car, and I am glad I bought such bulbs. I destroyed my old ones because my dad pranked me. He bought me a car after I got my driver's license and said I needed blinker fluid. I found it on Amazon, and it arrived in one day. My father wasn't at home, so I watched videos of how to do it, and I found another prank that made a tutorial. I didn't think it was a prank, so it stopped working after inserting the blinker fluid.
ricarhimel is offline   Reply With QuoteReply With Quote
blinkers , flash , hyper , i’m , led
FS: 5th Gen Lasfit front turn signals. Canbus no Hyperflash no resistor Bayonne Nj 0 skillzo1 For Sale: T4R Items 1 04-05-2020 10:29 AM
Hyperflash question something different inscarguy 4th Gen T4Rs 1 06-11-2019 01:32 PM
Demello LED turn signal and hyperflash- Has anyone solved this issue with a resistor? PAULUNM 4th Gen T4Rs 7 11-05-2014 11:30 PM
4Runner: LED Blinker moved to Aux, Driving light installed in Blinker spot KU_MechE 3rd gen T4Rs 0 09-24-2006 05:31 AM
