Originally Posted by alumarine
Are you sure your compression tester works properly?
Is it the screw in type?
Should be tested with the motor warm, all plugs removed, the throttle wide open and a fully charged battery.
Crank it and count to 6 for each test.
Yes, screw in type, and the tester hasn’t given us any issues before. And that is how we tested it, first we did it cold, WOT, no plugs, but we cranked the engine until the tester stopped rising, probably about 5-6 seconds. Then we repeated the test, same procedure with the engine warm after running for 10 min.
The exhaust smells really rich, I didn’t notice this before but after idling it indoors it’s pretty smelly.
