Old 07-04-2021, 11:58 PM #1
CoCoCo4Runner CoCoCo4Runner is offline
CoCoCo4Runner is on a distinguished road
This is a bad headgasket right?
I did get this for fairly cheap as the PO disclosed there was likely a problem with the headgasket, here are some symptoms and a video that makes it clear.
-Consumes coolant
-Puffs of white smoke on overnight start (see video)
-smoke smells sweetish
Before I start researching parts, is there ANYTHING else that could be causing this?
Here’s a video showing a cold start
4runner cold start - YouTube
CoCoCo4Runner is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 12:19 AM #2
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Sounds and looks like it but I could be wrong as I have never dealt with a bad head gasket. Before you buy or do anything first I would run a compression test on all cylinders to see if theres a leak.
2000 4Runner Limited 4x4 V6
Old 07-05-2021, 12:55 AM #3
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
As far as I know, the only operator error that could possibly contribute to this is if they swapped around the TB/IAC hoses, but I don't think the car would start in that case. Still, some food for thought I guess.
Something else that happens with age - the intake manifold gasket starts to break down heavily with age right around the coolant ports, which are pretty close to the adjacent intake ports. If your oil is still good this could possibly be why. It might be worth pop out the spark plugs and take a borescope inside to see where the coolant is going. Look for a noticeably clean chamber (the coolant turns into steam and removes all the carbon)
Old 07-05-2021, 01:47 AM #4
RotaryDreamz's Avatar
RotaryDreamz RotaryDreamz is offline
Real Name: Sean
RotaryDreamz will become famous soon enough
Real Name: Sean
Usually on cold startup I see alot of smoke, but its all condensation, which is normal. But if you're losing coolant and has that distinct sweet coolant smell, it has to be your head gasket. You can do a compression check and leak down test afterwards if you have a failed numbers to be certain.
RotaryDreamz is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 02:45 AM #5
Interesting so if a compression test is good, it could just be an intake manifold gasket?
Old 07-05-2021, 11:30 AM #6
Outrider Outrider is offline
Outrider will become famous soon enough
I suggest also getting an exhaust gas in coolant detection kit (the correct name eludes me). In addition to the above suggestions.
That is what saved me from pissing away $1,500-$2,500 on a head gasket replacement on mine, when mine had not failed, despite many other symptoms making it look like it had.
Things are very often not what they seem.
'99 SR5 V6 2WD named Jolene / In the T4R 200 Club
Outrider is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 05:06 PM #7
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I believe you're referring to a block tester: Amazon.com: Block Tester BT-500 Combustion Leak Test Kit - Made in USA: Automotive
Old 07-05-2021, 07:06 PM #8
NC-Limited NC-Limited is offline
NC-Limited is on a distinguished road
I thought a head gasket had blue smoke
NC-Limited is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 07:17 PM #9
Bry n Bry n is offline
Bry n will become famous soon enough
it's thanks to all the Scotty Kilmer videos i watch while on the toilet that i actually know what this thread is talking about.
Bry n is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 07:18 PM #10
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
No way to know on the video. Was it warm or cold outside when you started it ?
Anyway, you consume coolant on a good rate and see no leak on the ground, and it smells sweet, PLUS the other owner stating so, this is a strong probability something's up with the head.
No way to know if it's a head gasket or cracked head. Could be one, the other or both.
Could open up the radiator cap when cold, then start the truck, if you are lucky, you'll throw enough exhaust in the coolant and see bubbles.
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
Old 07-05-2021, 07:22 PM #11
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Well not necessarily but it would be a good sign. I'm just trying to be optimistic here. As said you should get one of those kits to test for any exhaust in the coolant, they're cheap and can save you a bunch of trouble shooting
Oh boy. Pic related
This is a bad headgasket right?-screenshot_20210226-064644_youtube-jpg
Old 07-05-2021, 11:16 PM #12
Dead cold, overnight start. I’m having it towed to a friends shop, where we can do a compression/leak down test. As long as it’s contained to one bank, I can get away with one headgasket right?
Old 07-06-2021, 08:13 AM #13
diverscale's Avatar
diverscale's Avatar
yes, as long as it is the head gasket, not a cracked head, obviously. Since you don't know the history of the vehicle, maybe it was overheated by a coolant leak, for example. But most chances are it's a one head gasket job. Have you looked for bubbles in coolant at cold start?
1998 4runner SR5
Old 07-06-2021, 08:55 AM #14
Real Name: Patrick
Real Name: Patrick
It can be either but white sweet smelling smoke is a much more common indicator of a blown head gasket burning coolant. Blue smoke is burning oil.
Old 07-06-2021, 10:38 AM #15
calnhob's Avatar
calnhob calnhob is offline
calnhob is on a distinguished road
calnhob's Avatar
here's a video of mine. 250K now and still going. coolant reservoir does need topping off but never had issues
97 SR5 w/ elocker, 250K | BS 5100 adjustable front 5th gen coils, 5100 rear LC springs | KO2 285/70R17 on '15 Trail Rims | TBU | X-Bull 12K Winch | TG Sliders | front & rear NWTI bumper kit
calnhob is offline   Reply With QuoteReply With Quote
overnight , smoke , start , video , white
