Old 07-06-2021, 12:49 PM #1
Bucket81's Avatar
Bucket81 Bucket81 is offline
Real Name: chris
Bucket81 is on a distinguished road
Bucket81's Avatar
Real Name: chris
Radiator Flush..
I purchased a new Denso radiator, and I was planning on flushing the old system before installing the new radiator. But I can't seem to get the system clean. I have ran distilled water through it multiple times, and the coolant comes out black. I've gone through about 10 gallons of water. This is 4 flushes worth...
Radiator Flush..-20210630_072603-jpg
Bucket81 is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 01:59 PM #2
Brian.'s Avatar
Brian. Brian. is offline
Brian. is just really nice Brian. is just really nice Brian. is just really nice Brian. is just really nice Brian. is just really nice
Brian.'s Avatar
did you run a detergent (flush cleaner)? Might help speed up the process a little. I think I was clean on the 5th or 6th flush myself.
Brian. is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 03:52 PM #3
bootown's Avatar
bootown bootown is offline
bootown is on a distinguished road
bootown's Avatar
How much are you getting out with each flush? Two gallons-ish hopefully? Might speed things up by draining the engine block too if you're not getting a couple gallons each time. Capacity is 8.5-9.5 qts
Pics are gone, but the write ups may still be helpful idk:
Coolant Flush https://www.toyota-4runner.org/1101715-post35.html
Radiator Replacement https://www.toyota-4runner.org/1034524-post23.html
bootown is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 05:17 PM #4
Bucket81's Avatar
Real Name: chris
Bucket81's Avatar
Real Name: chris
I did, I ran 3 bottles of the stuff. Usually ran them for a week each.
Yeah, I am getting about 2 gallons each time. I'll see if I can find that block drain next time I drain it.
Old 07-06-2021, 11:33 PM #5
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough
it's not oily stuff? hope it's not engine oil or atf that has mixed with the coolant. clean atf is red but if it's burnt, it can become black or dark brown
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 07-07-2021, 07:27 AM #6
Bucket81's Avatar
Real Name: chris
Bucket81's Avatar
Real Name: chris
I haven't seen any water in the oil or the AT fluid. I think some one mixed red and green....
Old 07-07-2021, 10:31 AM #7
Drcoffee's Avatar
Drcoffee Drcoffee is offline
Drcoffee is a jewel in the rough Drcoffee is a jewel in the rough Drcoffee is a jewel in the rough
Drcoffee's Avatar
You can buy a flush kit which allows you to splice a garden hose into the heater hose. Run the engine while running the hose with the radiator cap off until it run clean. Then open the block drains to empty out the lowest point.
I wonder if someone had used a leak stop product.
1999 4Runner SR5 4WD 3.4L AT 232,000 miles
2007 4Runner Sport 4WD 4.0L 222,000 miles
The real stats on gun murders in America compared to the world (link)
Good riddance to the Clinton Crime Family--> I Voted TRUMP
Drcoffee is offline   Reply With QuoteReply With Quote
Old 07-07-2021, 06:11 PM #8
the block drain is located on the RH side, between the 1st and 2nd cylinders. you have to undo the drain cock (bolt) then the coolant will flow from the union drain just below the drain cock (bolt)
Old 07-07-2021, 06:45 PM #9
Sarki Sarki is offline
Sarki will become famous soon enough
Unfortunately I have experience with buying a car (Mazda 3) that the seller obviously dumped in some leak stop in an effort to mask the fact that it needed a heater core, a very labor intensive job.
I found that a portion of it had settled in the coolant overflow tank. In speaking with the tech line at Bar’s they said that is very typical and a good way to determine if leak stop has been used.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 07-08-2021, 02:19 PM #10
phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of phattyduck has much to be proud of
That could just be a week's worth of rust then. I wouldn't freak out too much about it (yet). Get some good quality coolant in there and see if it changes color quickly.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-08-2021, 02:33 PM #11
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Best high volume flush is a garden hose.
I pull the lower rad hose, thermostat, stick the garden hose in the upper rad hose. Let it run full bore until you get nice clean water out.
Then reassemble the system and do a distilled water flush before finally filling with the appropriate coolant.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 07-08-2021, 11:55 PM #12
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 will become famous soon enough
Romeo1's Avatar
Radiator Flush..
OTC makes this power flush gun called a blast vac. I tried to link the listing but for some reason it kills the post. It’s awesome. Makes very short work of the job. Wished I had this thing 20 years ago when I used to work on semi’s.
Split the system and pull the thermostat. Reinstall the elbow and flush up and down. Then flush the heater cores/rear heater if you have one forwards and backwards.
The design of the cooling on these seems super prone to corrosion/buildup due to the high heater valve mount allowing rust to always form.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Kanati Trail hogs, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, kids call it “Vader”
Romeo1 is offline   Reply With QuoteReply With Quote
black , multiple , radiator , system , water
Coolant Flush With Radiator Out? LandZarc 3rd gen T4Rs 2 05-13-2019 06:27 AM
New Radiator with Coolant Flush? Power Steering Fluid Flush, and Brake Fluid Flush? jdotlim 4th Gen T4Rs 4 09-17-2017 07:52 PM
New radiator, flush or top off? mhk87 Classic T4Rs 0 04-26-2014 01:57 PM
Radiator flush problems mgcorreia 3rd gen T4Rs 5 11-17-2013 02:41 PM
Winter radiator flush Rumble Bee Classic T4Rs 4 12-15-2011 04:14 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
