Old 07-07-2021, 06:18 PM #1
domhanna domhanna is offline
domhanna is on a distinguished road
Rear Bumpers with Trailer Hitch
I'm looking for a rear bumper with a trailer hitch. I'm tight on budget so affordability is key. I'm not towing anything heavy just a little U-Haul trailer but the rear part of my frame where a trailer hitch would go isn't in ideal shape for towing so I'm looking for a bumper kit.
I know there's a lot of options on the market I just wanna get opinions before I go buying.
domhanna is offline   Reply With QuoteReply With Quote
Old 07-07-2021, 06:54 PM #2
You do understand that aftermarket bumpers bolt on to the same location of the frame that the stock hitch bolts to, right? If the frame is in bad shape back there, it will still be in bad shape with a new bumper.
There are a number of inexpensive aftermarket hitches that will do the job if you don't want to get an expensive rear bumper.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-07-2021, 07:00 PM #3
I figured they bolted in where the original bumper bolted in which is a little further up on the frame. I guess I'm stuck working with what I've got.
Old 07-07-2021, 07:32 PM #4
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
The factory rear bumper bolts to the body and I definitely wouldn’t want to tow anything with a hitch on those attachment points. Have that section of the frame repaired or find a friend who can help you. it’s an easy section to get to so not that hard to repair if you can weld, I fixed that section on mine and now have a factory hitch mounted
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 07-07-2021, 08:38 PM #5
this is probably what I'll end up doing. I have a buddy that can weld really well it's just a matter of how far we gotta go to find good steel to weld to. I definitely should've checked the whole frame before buying. It's great up until the rear suspension... ya live and you learn.
Old 07-07-2021, 08:59 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes the other users are spot on as if you frame is rotted so is your bumper mounts and floor pan were that hooks up to. Use my build thread as to how to fix your frame as DIY. Randy and I rebuld frames. So you can see how to do it as that's your best bet at this point. I wouldn't hook anything to a oem bumper nor those body mounts that support it.
Old 07-08-2021, 02:15 PM #7
Sounds like somebody was dropping boats into the ocean earlier in the truck's life. Check the rear lower control arm brackets (inside of frame area) while you are under there...
Old 07-08-2021, 08:23 PM #8
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
You should link your build thread to your signature. DIY frame repairs could be used by lot of people in here.
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
Old 07-12-2021, 05:14 PM #9
Riceye Riceye is offline
Riceye will become famous soon enough Riceye will become famous soon enough
4xinnovations.com
The fabrication is top-notch and their customer service is exceptional. Their rear bumper is truly DOT-3 rated.
I purchased both front and rear bumpers over a year ago (I took a 300mi road trip to save shipping costs) and had them hot-dip galvanised at a shop somewhat local to me in Milwaukee for $150. Everything went perfectly, although I did have to purchase a receiver with more drop to level my trailer.
96-02 4 Runner Rear Plate Bumper
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
Riceye is offline   Reply With QuoteReply With Quote
Old 07-12-2021, 05:36 PM #10
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
[QUOTE=Riceye;3655188
[/QUOTE]
Dang - something else to consider. There is Pacific Galvanizing right across the bay from me in Oakland....looks interesting.
Old 07-12-2021, 08:37 PM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I am really liking the idea of plate bumpers. . Deer will bounce off them. ;)
Old 07-12-2021, 08:38 PM #12
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I ran out of lines in my signature...;) That's a good idea though. :]
bumper , hitch , rear , towing , trailer
Trailer Hitch Bike Trailer SoCal4Run So Cal 0 08-05-2014 10:09 PM
Rear bumper and Trailer Hitch josh.bunch For Sale: T4R Items 9 11-18-2011 07:51 PM
Custom/aftermarket rear bumpers and trailer rental? Stick Figure 3rd gen T4Rs 6 01-04-2011 11:12 PM
Don't get rear ended if you want your trailer hitch ... UoD 4th Gen T4Rs 5 08-11-2005 07:52 AM
Rear Hitch Bumpers Mark86 Engines / Suspension / Wheels / Tires / Audio / Accessories 24 04-09-2005 11:35 PM
