12-01-2022, 03:36 PM
#16
Real Name: Devan
Real Name: Devan
Originally Posted by mac33
bringing this old thread back up, sorry.
Anyone have any issues with JBA? Highly consider it but also considering SPC. Talk me into/out of one another.
RockAuto discontinued SPC so unable to get it cheaper.
I wish I would've gotten the Mevotech SPC arms over my JBAs. I don't have any complaints on them, it's just the SPC arms are actually designed to correct your alignment after a lift and ultimately provide more caster in comparison - I also like how instead of bushings they use two Johnny joints. A little overkill but kinda neat nonetheless. What's nice about JBA is they use some very common bolt-in GM ball joint that can be easily acquired, that also has a ton of articulation to it. But that said it's 90° degree of motion vs 80° between the two arms, and unless your LBJ has similar flex you'll never see that extra 10°
Tbh I only bought JBA because I was unaware you could get unbranded SPC arms for only a few extra bucks
12-29-2022, 06:16 PM
#17
The JBA Arms comes with 3* of additional caster to correct the Caster with a lift. It's not adjustable, but once aligned, it does force the wheel further forward in the well because you run your rear arms all the way out. They also feature a replaceable ball joint. I'm really happy with mine. 285's and no rub at full lock.
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
12-29-2022, 09:14 PM
#18
Doesn’t it move the wheel closer to the firewall so that you don’t have to max out the rear adjusters? Pretty sure the only way to move the wheel forward is moving the lbj forward and keeping the upper in roughly the same spot
99 SR-5 Highlander Elocker, 1.5” body lift, Ironman FCP coilover, FJ cruiser bilstein lift coils and fj80 kyb rear shocks, JBA ucas, TC gussets, custom front & rear tube bumpers, poly bushings all around, 33/12.5/15 on steels. 396k
98 Base 4x4 3rz. 5100s and ome coils. TBU. 360k
96 Taco rcsb 4x4 3rz 320k
12-29-2022, 10:23 PM
#19
If you follow the recommendation by SPC, after choosing Caster position "D" (I think), maxing out the rear Cam (Caster adjustment on these trucks) to move the LBJ forward is how you get the clearance and the better Caster angle. It's the same procedure with the JBA Arms, only the Caster position is already fixed for you.
This doesn't work the same way with the stock arms due to the reduction of the Caster angle after the lift. You cannot get both good Caster and Camber angles with the stock arms. You run out of adjustment.
EDIT: If you look at the Cams on the Toyota trucks with the aftermarket High Caster control arms, you'll see that most of them have the rear cams maxed and front cams in or near the neutral position. That's where mine are. The Alignment Cam Delete kits are based on these common positions.
12-30-2022, 12:14 AM
#20
With JBAs and 2” of lift my shop was able to dial in perfect alignment with 4* of caster. Rides nice!
12-30-2022, 02:24 PM
#21
Hey there. Can you take a look at the positions of your alignment cams and post where they are set?
12-30-2022, 03:24 PM
#22
Sure, next time I get a chance I would be happy to do that.
12-30-2022, 04:52 PM
#23
Rear cams maxed outward is normal on lifted Toyotas. This moves the lbj forward but the jba arms move the top of the spindle back towards the firewall at the same time. The only way to gain significantly more clearance is to keep the upper in roughly the stock spot and use lcas that move the lbj forward. That’s how you get more room and correct the caster. Jba is adding caster by moving the wheel closer to the firewall. I run mine rears maxed, and the fronts middle with roughly 2” lift and it seems decent though
12-30-2022, 06:14 PM
#24
I don't see a way to gain Caster with upper arms that doesn't involve moving the UBJ back a bit. And, it's 3*, so it's not a huge distance, but it's enough to make noticeable difference. The tech who worked on my truck had never seen them before and that shop does a lot of work on lifted Toyotas. He liked the arms quite a bit and said it made his job a lot easier.
SPC gives you the ability to also adjust Camber, so you can run your front Cams all the way in to get the LBJ a bit more forward. That's the advantage to their design. More customization with the UBJ placement.
With the JBAs and the resulting alignment, I have more clearance with the new arms than I did with the stock arms. I went with the JBAs since they would give me what I wanted at a lower price point. From what I researched, there were quite a few issues with SPC's bushings and ball joints. Plus, there were multiple generations of product out in the market. There was enough confusion about that I wanted to steer clear. I do like the SPC rear lower links that I bought.
It's good to have choices, and these days, there are a LOT more choices for our trucks than when they were on the market. It's amazing.
Cheers.
12-30-2022, 06:45 PM
#25
Real Name: C8H18 Mike
I'm running SPCs and cam eliminators
Rear LCA cam is positive, outboard, front cam is neutral.
SPC set to E position (D is basically stock)
With these settings my 33" tires do not rub anywhere on factory 5-star rims and a 3" lift
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
