Old 07-08-2021, 01:45 PM #1
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light
JBA Offroad Upper Control Arm Install
are you guys getting tired of our videos yet?????
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
infamousRNR is offline   Reply With QuoteReply With Quote
Old 07-08-2021, 02:12 PM #2
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
I think it goes without saying your guys' channel is one of the most appreciated assets on here
Old 07-08-2021, 10:04 PM #3
Breaker Bar's Avatar
Breaker Bar Breaker Bar is offline
Real Name: Jarrod
Breaker Bar is on a distinguished road
Real Name: Jarrod
T4R folks will never tire of your guys’ videos. I like that JBA added a threaded hole for the ABS bracket, my set from a couple of years ago doesn't and has the bracket zip tied to the arm. One thing I noticed is that you torqued the through bolt while it was up on jack stands… On the UCA’s I’ve installed the instructions always mentioned to torque at ride height with the wheels installed.
96 5-spd w/E-locker, SS1.2 lift, JBA UCA’s, 1” BL, Other stuff
Breaker Bar is offline   Reply With QuoteReply With Quote
Old 07-08-2021, 10:24 PM #4
counterculture counterculture is offline
counterculture is on a distinguished road
Thanks for the informative video!
counterculture is offline   Reply With QuoteReply With Quote
Old 07-08-2021, 10:44 PM #5
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Since the UCA bushings are fully floating it doesn’t matter their position when the bolt is torqued. A rubber bushing is bonded to the inner and outer sleeves so it’s neutral position has to be set at ride height.
JZiggy is offline   Reply With QuoteReply With Quote
Old 07-09-2021, 01:22 AM #6
Real Name: Jarrod
Real Name: Jarrod
Good to know, I did see that the bushings in the vid are different than mine from 2018. The press in poly bushings with steel sleeve inserts on my JBA’s, as well as on my Readylift UCA’s that I installed on my Ram pickup stated to torque with the tires on the ground.
Old 07-09-2021, 01:36 AM #7
looks like JZiggy beat me to the punch..
thanks for the kind words guys. Tim and I were beginning to wonder if anyone on here watches our stuff anymore lol
Build Thread
Old 07-09-2021, 08:34 AM #8
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
I watch at least one of your videos most days! Lol
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 07-09-2021, 08:45 AM #9
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Literally every single repair I do I try to find something from you guys on the topic before I start
Old 08-22-2022, 06:36 PM #10
BoomSticks's Avatar
BoomSticks BoomSticks is offline
BoomSticks is on a distinguished road
BoomSticks's Avatar
Any special considerations for getting the through bolt out of the passenger side?
"Bender" Silver 99 Limited with e-locker.
BoomSticks is offline   Reply With QuoteReply With Quote
Old 08-23-2022, 12:49 AM #11
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Watch Tim and Sean's video, you have to remove the airbox and loosen the AC lines. Passenger was easier than the driver side IIRC.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 10-17-2022, 05:26 PM #12
BoomSticks's Avatar
BoomSticks's Avatar
Yep, they didn't mention it, because there aren't any special considerations. I didn't have to move anything to get the passenger side bolt out.
Old 12-01-2022, 12:41 PM #13
mac33 mac33 is offline
mac33 is on a distinguished road
bringing this old thread back up, sorry.
Anyone have any issues with JBA? Highly consider it but also considering SPC. Talk me into/out of one another.
RockAuto discontinued SPC so unable to get it cheaper.
mac33 is offline   Reply With QuoteReply With Quote
Old 12-01-2022, 01:15 PM #14
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Mevotech branded SPC control arms are still out there. Google MEVOTECH CMS861193 and MEVOTECH CMS861192.
Old 12-01-2022, 03:17 PM #15
cblock406's Avatar
cblock406 cblock406 is offline
Real Name: Christian
cblock406 is a jewel in the rough cblock406 is a jewel in the rough cblock406 is a jewel in the rough
cblock406's Avatar
When I did mine, JBA's didn't have adjustable caster like SPC, so I ruled them out and went SPC. No regrets. Maybe they are different now?
Build Thread: http://www.toyota-4runner.org/3rd-ge...ce-thread.html
@projects_always
cblock406 is offline   Reply With QuoteReply With Quote
arm , control , jba , offroad , upper
4th & 5th Gen Upper Control Arm UCA Install - Write Up Slowgoat 4th Gen T4Rs 66 04-18-2024 07:11 PM
FREEDOM Offroad Control Arms - Under $350 Tubular Upper Arms from Battle Born! Battle Born Offroad Suspension 26 06-14-2021 08:29 PM
Issue after upper control install The_Green_Wang 5th gen T4Rs 16 11-17-2018 10:03 PM
Will I clear the upper control arm if I install landcruiser wheels? JerryT 3rd gen T4Rs 14 05-18-2009 03:05 AM
