Old 07-09-2021, 11:22 PM #1
02_SE_Runner_DAD's Avatar
02_SE_Runner_DAD 02_SE_Runner_DAD is offline
02_SE_Runner_DAD is on a distinguished road
33" tire in the spare location
Can I fit a 33" tire in the spare location without worrying about weight capacity of the chain? what mods have you guys done to keep the chain from breaking.
TIA
Fly High Son(NATE) 1995-2014
http://www.toyota-4runner.org/3rd-ge...od-thread.html
02_SE_Runner_DAD is offline   Reply With QuoteReply With Quote
Old 07-09-2021, 11:32 PM #2
HiLife HiLife is offline
A friends 265 70 17 mounted at the stock location used to rub badly on the track bar.
My 265 70 16 Hankooks spare rubs on the track bar. Deflating it just clears it. I carry air in case I have to use the spare.
I don't think your 33 will even fit in the stock spare tire location.
Old 07-10-2021, 12:56 AM #3
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Unfortunately no. That's why you see many with tire carriers or throwing it in the trunk. For some reason even if you balance it perfectly well and cinch it up real tight, it will still eventually move around and rub against the panhard.
Old 07-10-2021, 01:38 AM #4
kasra kasra is offline
kasra is on a distinguished road
TIA
I have my 33 under and didn't even think of chain capacity! It fits fine.
kasra is offline   Reply With QuoteReply With Quote
Old 07-10-2021, 01:56 PM #5
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Curious what the tire make/model is and what the embossed dimension numbers are. A friend said he had to ditch the hitch, deflate to 10psi and carefully guide the spare while cranking it down to make a 33" General M/T of some kind "fit"......that's not really a fit in my book and I bet it rubbed eventually.
Old 07-10-2021, 04:31 PM #6
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
Do you own a 3rd gen?
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 07-12-2021, 10:51 PM #7
Ron Burgandy Ron Burgandy is offline
Ron Burgandy will become famous soon enough
i looked at trying to fit a bigger tire in there and didn’t think it was worth it, not a fan of big heavy bumpers on an already underpowered rig so the stock spare works for me.
Sent from my iPhone using Tapatalk Pro
Ron Burgandy is offline   Reply With QuoteReply With Quote
Old 07-13-2021, 02:41 AM #8
Sparky 97Runner's Avatar
Sparky 97Runner Sparky 97Runner is offline
Sparky 97Runner will become famous soon enough Sparky 97Runner will become famous soon enough
A 33" will not fit without rubbing the panhard bar without some sort of mod. I believe there were some threads years ago where the Sonoran Steel owner used the spare tire parts from an earlier gen 4runner to make it fit. I'm not sure about the weight capacity of the spare tire cable but I completely understand your concern. It was obviously designed to hold the factory spare but probably not a much heavier tire while bouncing down trails.
1997 Toyota 4Runner
Sparky 97Runner is offline   Reply With QuoteReply With Quote
breaking , chain , location , spare , tire
Spare Tire location tire size limits Ogre75 5th gen T4Rs 3 03-06-2020 01:11 PM
How to make a 33" tire fit in spare location? gshadow325 4th Gen T4Rs 11 08-05-2016 02:18 AM
Largest fully inflated 16" spare tire that will fit in the stock spare location? 240m3srt 3rd gen T4Rs 16 09-26-2013 01:30 PM
Spare tire location Polish Power 3rd gen T4Rs 9 11-26-2012 03:21 PM
Using the spare tire - what location? BurghRunner General Discussions 10 06-22-2009 11:37 AM
