Old 07-10-2021, 08:07 PM #1
RidingDirty RidingDirty is offline
RidingDirty is on a distinguished road
Crank Pulley Bolt Compatibility Question
Hey I just bought my 1st timing belt + water pump kit from ebay (aircabinman). I plan on purchasing a new crank pulley bolt for my 1996 4runner. I know there are (2) different crank pulley bolt part numbers due to an update mid-production. I ordered the updated crank pulley bolt from the dealer and my order was cancelled because it didn't match according to my VIN (1996). They would not let me speak with a mechanic. So is the updated bolt compatible with my 1996 4runner? Or am I going to have to buy another older style bolt and torque it to 217 ft-lb? Thank you.
The bolt from 96-98 is part #90105-16031. Torque at 184 ft-lb.
The bolt from 99-02 is part #90119-16006. Torque at 217 ft-lb.
RidingDirty is offline   Reply With QuoteReply With Quote
Old 07-10-2021, 08:23 PM #2
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I used the 90105-16031 bolt on my 97 5 speed and just torqued it 217 ft/lb when I did my timing belt on mine. Lets see what others say. :-)
brillo_76 is online now   Reply With QuoteReply With Quote
Old 07-11-2021, 12:06 AM #3
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
I mean, you are effectively being told by Toyota to use the original part number and torque spec. No need to reinvent the wheel. You're already using the old part number and torque spec and nothing has exploded.
Old 07-11-2021, 03:06 AM #4
4Reak Show's Avatar
4Reak Show's Avatar
Quick read
Crank bolt torque specification discrepancy
Crank bolt torque specification discrepancy - Toyota 4Runner Forum - Largest 4Runner Forum
Old 07-11-2021, 11:01 AM #5
That’s what I did. One 96 and two 97. I didn’t buy a new bolt.
Old 07-11-2021, 12:50 PM #6
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
96Red used original bolt for 2 TB changes 374k mi no problems was due a TB when totaled.
01 PO had belt changed at 130k mi don't know who torqued bolt, at 205k mi I did TB with bolt for 01 217 ft-lb so far so good.
Old 07-11-2021, 03:50 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I replaced the bolt as the factory manual reccomends it. I didnt see any damage on the threads. So good to know folks reused without issues as well.
Old 07-11-2021, 04:14 PM #8
If the bolt is not torque to yield i don’t replace it
Old 07-11-2021, 07:04 PM #9
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
Everything is torque to yield if you’re strong enough, or work at jiffy lube
RandyBobandy is offline   Reply With QuoteReply With Quote
bolt , crank , part , pulley , torque
Siezed Crank Pulley Bolt STI_MECE 3rd gen T4Rs 28 11-30-2019 08:22 AM
Stuck crank pulley bolt gaber6 4th Gen T4Rs 20 10-02-2018 03:31 PM
Crank shaft pulley question- not bolt jkfuel 3rd gen T4Rs 4 08-13-2017 07:17 PM
crank pulley bolt atcpup 3rd gen T4Rs 16 10-07-2016 01:31 PM
Crank pulley bolt Diverse4runner Classic T4Rs 5 12-09-2010 11:37 PM
