07-13-2021, 01:27 PM
#16
Originally Posted by willhaman21
So you want to run 35" tires on your 3rd gen 4Runner, but you don't want to run a drop-bracket suspension or giant body lift? Here's how I fit 315s on my 4Runner.
Specs:- Tires: 315/75R16 Yokohama Geolandar M/T
- Wheels: 16x8" Level 8 MK6, 4.110" BS (-10 offset)
- Suspension: Icon/SPC mid travel, ~2.5" lift at ride height, SPC's set all the way forward
- Body: 1/2" Fat Pat's body lift
Tools Needed:- Angle grinder
- Sawzall
- MIG welder
- 6-ton jack stands
- 3-ton floor jack & some wood blocks for extensions
- Hand tools (pliers, sockets, wrenches, hammers, etc)
Materials Used:- (1x) 2x2' sheet of 20ga steel - Order more if you want practice pieces. (Link)
- (4x) 2' sticks of 1/8" steel rod - You can also find it in 4' sticks at Home Depot. (Link)
- (1x) 3M Seam Sealer - I ordered 3 cans but only used 1. (Link)
- (2x) 3M Rubberized Undercoating - I ordered a 6 pack, only needed 2 cans. (Link)
- Noico sound deadening mats (optional) - you only need a few pieces, I had a lot on hand. (Link)
- Noico sound deadening foam (optional) - same as the mat, you only need a few pieces. (Link)
Whoa, nice work & great job on the write up. I really appreciate your thoroughness in explaining the process & the pictures helped visualize what you were describing. You also did a great job of sequencing the steps which made it really easy to follow.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
07-13-2021, 01:42 PM
#17
Fantastic write up, Nice clean work.
When you cut into the rocker panels for example and then weld them back up, enclosing them, How do you properly prevent the bare metal inside from rusting? Seems like most people just don't worry about it but I assume the pros have a way of dealing with this. If anyone knows, I've been wondering
07-13-2021, 05:00 PM
#18
There's weldable paint & primers offered by companies like steel it, SEM, seymour, eastwood etc. Speaking of pro's, the several times I've had something professionally welded, weld through paint/primer was never mentioned but I always brought it myself & asked that it be used. There's debate on the effectiveness of weldable paints/primers but something seems better than nothing.
07-14-2021, 01:18 PM
#19
You can probably get to access to the inside of most of that to spray some Fluid Film or similar on the back side... Or maybe some eastwood internal frame coating with its hose 360* sprayer thing.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
07-26-2023, 06:57 PM
#20
Amazing write-up! I just did this to my 5spd. And for those wondering the clutch clears!
