Old 07-14-2021, 04:45 PM #1
3bears 3bears is offline
Real Name: 3 Bears
3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light 3bears is a glorious beacon of light
Real Name: 3 Bears
strange led ? not dash
so i relaced all my exterior lights....blinkers, parking, brake and back up with LED's. a week or so go and no issues...so today.... when i hit my brakes the right side dash turn signal indicator lights up but dull. But after a few hits...it goes away.. turned brake bulb around...pulled panel and checked my ground....is it just the led bulb being funky...a bad one.
btw...I did just replace housings and switched out to the 2001 and up tail lights I did pull the panels...plugged into oringinal harness...and reattached the grounds on the 10mm bolt...or what ever size that was..
stupid me...i threw out the old bulbs so dont have one to switch into
the led bulb or do i have something else going on ? I assume it must be related to brake light ..somehow.. did not have this issue b4 swtiching to the 2001 light housings or led bulbs.
all other lights work great. and am happy with the brightness of them all, aside from this issue
2000 SR-5 Highlander. 4:30's, factory locker green bought june 2021
2001 SR-5...sold june 2021
2000 SR-5 V6 Auto . lifted, e locker, other cool stuff, totaled 10/20
Old 07-14-2021, 08:24 PM #2
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot is just really nice Devbot is just really nice Devbot is just really nice Devbot is just really nice Devbot is just really nice
Devbot's Avatar
Real Name: Devan
It was a while back when I did my dash but I'm fairly sure BOTH my turn signals had current bleeds and required incandescent bulbs. I've never heard of a current bleed that comes/goes so it very well could be the LED, but might be worth checking into. I don't think it would be a short if you never noticed anything before. Regardless you're probably gonna need another couple bulbs. They shouldn't be more than a buck at autozone, if that. Unfortunately with the dash its a lot of trial and error, but thankfully it comes out much easier than most vehicles
Y2K Highlander Millennium Silver 3.4L auto @ 295k and climbing
Tundra TRD Lift in Front / LC Lift in Rear / JBA UCAs / CVJ 9168R Axles / Diff Drop / PCK / Extended Bump Stops; Brake Lines; Sway Bar Links; Rear Diff Breather / True North Fab. Hybrid Bumper / Smittybilt XRC Gen 3 Comp. / Northstar 880CCA AGM / Drivelines NW Rear Shaft / Lil Skip Gas Skid / BudBuilt Front Skid
Old 07-15-2021, 11:42 AM #3
Real Name: 3 Bears
Real Name: 3 Bears
no all the bulbs are outside of the car, I did not change anything in the cluster so i cant imagine its a bulb in the cluster.
Old 07-15-2021, 02:05 PM #4
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Oh my mistake, I would be almost certain it's a bad bulb or maybe a relay issue then. You very often need a new relay with LED turn signals to prevent hyperflash, not sure if it can prevent other issues but it might be worth checking out
Old 07-15-2021, 02:58 PM #5
Skulking Skulking is online now
Skulking has a spectacular aura about Skulking has a spectacular aura about
When you say it lights up but dull but after a few hits it goes away, is it blinking, or is it on solid? By a few hits, do you mean that after you have hit the brakes a few times the problem goes away and doesn't come back?
Skulking is online now   Reply With QuoteReply With Quote
Old 07-16-2021, 12:41 AM #6
Real Name: 3 Bears
Real Name: 3 Bears
1) yes i put in a relay for LED's for turn signals....btw...stupid location for relay.
2) it is dull, does not blink...just comes on when I hit the brakes and if I hit the brakes a few times it goes away and does not come back for the rest of my drive time even if I shut down for like 15 minutes while shopping...no problem....sits over night....guess what...there it is
3) had my grandson get in and hit the brakes...in morning..when it was playing this game...all the lights work as they should
think its just a gremlin making fun of me for some reason, glad that little bugger ( gremlin) is just doing that...little fricker could play a lot worse games
Old 07-17-2021, 01:19 AM #7
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Sounds like just a cheap bulb to me, or just bad connection. I don't see a way a short or something could do that
Old 07-17-2021, 11:37 AM #8
It sounds like the brake light is somehow feeding power back to illuminate the turn signal indicator, but the only thing they have in common is that the brake lights and rear turn signals ground to the same point. And I can't explain why it only affects the indicator the first time, or why hitting the brakes a few times makes it stop until the car sits overnight.
Old 07-17-2021, 01:40 PM #9
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Well an LED in the 3rd brake light will trip things like ABS, if he has one installed maybe it's messing with turn signals too? Just shootin in the dark here
Old 07-17-2021, 03:16 PM #10
Sure, but the 3rd brake light and the ABS are connected as part of the same circuit. The turn signals and the brake lights aren't part of the same circuit in any way except that they share a rear ground connection. My bet is on an issue with the rewiring on the right hand rear brake light.
@3bears You have concerns that it might be an issue with a bad LED. Since it is only the right hand turn signal indicator which lights up when you hit the brakes, swap the LED's from the right hand lights to the left hand lights and the left hand lights to the right hand lights. Swapping all 3 from one side to the other and then seeing if the left hand turn signal is the one that comes on when you hit the brakes should either confirm or rule out the LEDs as the source of the problem. If it follows the LEDs, then it's a bad LED, if it stays, then double check the wiring work you did.
Old 07-18-2021, 01:40 AM #11
Real Name: 3 Bears
Real Name: 3 Bears
thanks.....that will be my next step....however...I do reme,ber now...and for got to bring up...that it has a aftermarket trailer connection relay box thingy and that wiring was and still is a mess that I planned to go back and clean up. wonder if can be related
Old 07-18-2021, 01:43 AM #12
Real Name: 3 Bears
Real Name: 3 Bears
thanks , I should have clarified that yes I said I replaced all the exteior bulbs with LED's. What I did not say was EXCEPT the third brake light bulb....I learned that one years ago...when I put in an LED.....than found out that did not work, then put in a standard...but slightly smaller bulb...and that caused issues when it bounced out of the socket.....yes that 3rd brake light can cause issues..
Old 07-19-2021, 12:13 AM #13
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C is just really nice Ed_C is just really nice Ed_C is just really nice Ed_C is just really nice
Ed_C's Avatar
Real Name: Ed
I run LEDs in all the brake lights (including 3rd), have no issues with ABS or cruise like a lot of people have. They're not the cheapest ones, first taillight bulbs I used were Sylvania Zevos which I reused in my Tundra after switching to VLEDS; 3rd brake light is also VLEDs.
Sure can.
10mm , bulb , dash , led , lights
Strange buzzing sound from dash under acceleration..... AlphaQup 4th Gen T4Rs 8 12-28-2020 12:51 AM
Strange Dash Lights Chilow 5th gen T4Rs 19 06-18-2019 12:18 PM
Strange electrical motor noise coming from dash clkcrawford 5th gen T4Rs 22 10-24-2018 08:47 PM
Very Strange Dash Issue morphious 4th Gen T4Rs 12 12-07-2013 10:34 PM
Strange Noise from DASH!?!? 4x4runner91 Classic T4Rs 5 06-14-2009 03:15 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
