Originally Posted by Pyral
I got the clutch spring. What is the best way to remove the old one?
Edit:
Okay I got it removed using a pry tool. The spring feels nice, though it does introduce some horizontal play but it isn't enough to matter.
I still have another squeak that seems to be coming from where the clutch goes into the transmission. Don't know if it is a dry grease zerk but there is still a squeak coming from the other side of the fire wall where the clutch linkage comes out. Any idea what is causing the squeak?
Check a few pictures down on this thread:
https://www.toyota-4runner.org/2524321-post7.html
Put some bearing grease on the clutch arm pivot. Easy to do this with a grease needle. Should fix your issue. I find I have to reapply grease about once a year.
