Originally Posted by Bad Luck
Sounds like you need to find a new mechanic if he was too lazy or incompetent to locate the noise correctly. To locate the noise it will need to be put on a lift or jack stands and driven (all 4 tires off the ground) and listen for the origin of the noise. We could play the guessing game all day but you need to narrow down where the noise is coming from.
It was a timing and scheduling problem. I had it in for other stuff and he just noticed this on the test drive following the work he did. I couldnt leave it with him I needed it for transportation.
Im the one that stated I thought it was probably a wheel bearing and he mentioned that he wasnt so sure. So, I agree with you 100% that it needs narrowing down. I like the idea of getting it off the ground I may try that.
