Old 07-19-2021, 09:59 PM #16
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
Originally Posted by CoCoCo4Runner View Post
Yeah, felpro has been around forever, I feel like their stuff should be reputable?
The problem is, so have companies like Land Rover
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 07-20-2021, 02:47 PM #17
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by diverscale View Post
Guess all the know-it-all saying don't go with FEL-PRO, go with OEM, have never worked with fel-pro gaskets. Easy when it's not their own money.
These are top-notch. You won't have a problem with them if correctly used and installed. And I don't know about the OEM price, but you'll also probably pay a small fraction for all the material you've got there.
Go with them with peace of mind.
I use OEM with my own money when it comes to any gasket that requires a lot of work to get to when it fails unless there is a known problem with the specific OEM gasket material or design.
Old 07-20-2021, 03:07 PM #18
jlaho jlaho is offline
jlaho is on a distinguished road
While a bit anecdotal, I can say that I installed Felpro PermaTorque MLS headgaskets in my own 4Runner and have had no issues so far. While getting my heads resurfaced, I chatted with the owners of the machine shop and they had no concerns with using Felpro either. They certainly weren't in a rush to suggest OEM. Take that how you will.
What I can say is that the performance of whatever headgasket you use will mainly come down to proper cleaning, inspection, and installation.
jlaho is offline   Reply With QuoteReply With Quote
Old 07-20-2021, 04:11 PM #19
CoCoCo4Runner CoCoCo4Runner is offline
CoCoCo4Runner is on a distinguished road
I haven’t gotten the heads off yet, ran out of time
over the weekend. But I intend on getting the block as clean as possible and sending the heads out to be cleaned, resurfaced, and pressure tested
CoCoCo4Runner is offline   Reply With QuoteReply With Quote
Old 07-20-2021, 05:49 PM #20
19963.4lsr5 19963.4lsr5 is online now
If you choose to buy the Yota-Shop kit give them the valve stem seals it’s part of the kit.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 07-20-2021, 05:55 PM #21
diverscale's Avatar
diverscale diverscale is online now
diverscale will become famous soon enough
diverscale's Avatar
Thank you so much for sharing your vast experience and wisdom in gasket designs of OEM vs fel-pro
1998 4runner SR5
diverscale is online now   Reply With QuoteReply With Quote
Old 07-20-2021, 06:27 PM #22
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
When doing the head gasket for my echo, my dealer suggested a Toyota packaged top end gasket kit that included everything I needed and more. Price was very reasonable.
I wonder if they have a similar part number for a 3.4 kit?
Any fel-pro gasket I have used eventually had to be replaced with oem. I won’t use them again personally.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 07-20-2021, 06:37 PM #23
Will do. The Yotashop kit seems to come with an MLS gasket, which I’m not sure is compatible with my engine or not.
Old 07-20-2021, 06:59 PM #24
It’s preformed well for my 2 97’s I put them on.
Old 07-20-2021, 07:06 PM #25
Good to know! I know Toyota revised it from composite to MLS for 1999, so clearly they realized it’s the better option
Old 07-21-2021, 09:45 AM #26
Real Name: Patrick
Real Name: Patrick
I bet you're a blast at a party, eh? Why do you have such a problem with me sharing my opinion which differs from your opinion? You must be a mechanic, right? Or an engine builder?
Old 07-22-2021, 08:09 PM #27
NachesPass4x4 NachesPass4x4 is offline
NachesPass4x4 is on a distinguished road
I have done a lot of head gaskets. Not on 3.4's but 22R/22RE's. Replacing aftermarket Head gaskets (especially fel pro) that failed in 10-15K miles has made me a fair bit of money. The cost difference between a aftermarket and oem 22re gasket is about $25. If you compare oem and Fel pro head gaskets, the quality difference is obvious. Oem only for any engine I work on.
I have never used an MLS head gasket but guys I know and trust speak highly of them. I believe the head needs to be re surfaced with the correct finish for an MLS gasket.
NachesPass4x4 is offline   Reply With QuoteReply With Quote
Old 07-22-2021, 08:48 PM #28
I went with an oem composite kit from Yotashop
Old 07-22-2021, 09:00 PM #29
There is a lot of block prep to replacing head gaskets. The most important is chasing the headbolt threads. Any head gasket will fail if the prep work wasn’t done and the torque stages followed. It’s hard to blame it on a specific brand.
Old 08-03-2021, 02:15 PM #30
Took a day off to wrench on the 4runner again, does the timing appear off? Not that it matters too much, as the belt is coming off
bad , headgasket , issue , leak , there’s
Confirmed: X-REAS Leak sport2004 4th Gen T4Rs 20 04-09-2019 11:15 AM
Confirmed: 2014 4Runner to get changes dekeman 5th gen T4Rs 75 03-29-2013 04:29 PM
Chevrolet Colorado Confirmed For US Bigmikelakers All Other Vehicles 23 10-20-2011 01:21 PM
Should I Replace Headgasket or Dump wlmbusiness 3rd gen T4Rs 8 05-27-2009 07:53 AM
Confirmed Timing Chain Jumped! prodigy2k7 Classic T4Rs 2 01-03-2008 03:42 PM
