Old 07-21-2021, 11:46 AM #1
Mudflaps's Avatar
Mudflaps Mudflaps is offline
Real Name: Chris
Mudflaps is on a distinguished road
Mudflaps's Avatar
Real Name: Chris
So....this is a dumb question
So, I'm halfway through doing a timing belt and water pump job. I reinserted the crank bolt to properly time the engine but.....now I cant back the crank pulley bolt back out....you know the struggle Im sure.
I cant do the old wrap a belt onto itself trick since the belt and tensioner are already on. Anyone have any other clever ideas?
Sent from my SM-A215U using Tapatalk
*My clock still works*
Mudflaps is offline   Reply With QuoteReply With Quote
Old 07-21-2021, 12:42 PM #2
Impact? If not, DIY a pulley holder. There are M8x1.25 holes in the crank pulley for this exact purpose.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-21-2021, 02:06 PM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Use an impact on it
Old 07-21-2021, 03:16 PM #4
AJPuleo23's Avatar
AJPuleo23 AJPuleo23 is offline
AJPuleo23 will become famous soon enough
AJPuleo23's Avatar
If an impact and DIY cam tool are not available, I used this and it worked just as intended.
Amazon.com: EWK Universal Camshaft Pulley Holder Cam Sprocket Holding Tool Camshaft Tool for Ford GM Honda Mazda Nissan Toyota Volvo: Automotive
2001 SR5 | 275K+ | 3" Toytec Ultimate Coils | SPC UCA's | MotegiMR150 17x8.5 + Yoko Geo 295/70/R17 | 4Xi full drivetrain skids | OCD sway bar links F&R | Powerstop TBU | Opt OR Upper & Lower rear arms | MF Overland Exhaust | Retrofit LEDs | Vivid Lumen Fogs | Full Prinsu Rack | Front bumper retrofit/fat lip delete
1983 Pickup SR5 | 93K | LCE Street Headers | 31x10.5 BFG K02's, Full Desmog and Otherwise Original
1981 Pickup SR5 longbed | 142K |
AJPuleo23 is offline   Reply With QuoteReply With Quote
Old 07-21-2021, 03:32 PM #5
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I agree with the others. I use impact tools for that specific reason. :-)
I think the auto parts stores have a free loan a tools programs if you don't have one.. :-)
brillo_76 is online now   Reply With QuoteReply With Quote
Old 07-21-2021, 07:23 PM #6
Mudflaps's Avatar
Real Name: Chris
Mudflaps's Avatar
Real Name: Chris
Okay so I guess Im gonna go the impact route. Hopefully I can find a small enough impact wrench to fit lol. Thanks for the help, guys.
Old 07-22-2021, 12:07 AM #7
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Use a small 3/8" impact and you'll be able to get in there. The bolt shouldn't be that tight. When we shot the video for this job, we held one of the cam pulleys with a special tool and the belt was able to hold the crankshaft timing gear while we loosened the 19mm crank bolt. There is a chance you could skip a tooth doing this but I doubt it. Like I said, the bolt shouldn't be that tight just from turning over the engine. But, the safer option is an impact.
The crankshaft timing gear does have two threaded bolt holes which are a M6 x 1.0 thread pitch. Like Charlie said, you could make your own holder tool with some scrap metal or a piece of wood.
Old 07-22-2021, 10:22 AM #8
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
What Tim said small 3/8's. I got my Milwaukee 3/8 stubby in there and it did the trick.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
Old 07-22-2021, 01:56 PM #9
Oh, shoot, you may be right that they are M6 instead of M8... Either way...
Old 07-22-2021, 02:27 PM #10
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
The crankshaft pulley (harmonic balancer) has M8 x 1.25 bolt threads so you were right. I'm just assuming he doesn't have the crank pulley on yet and he's dealing with just the crankshaft timing gear which has M6 x 1.0 bolt threads.
back , belt , bolt , clever , crank
Dumb question of the day Gromforlife 4th Gen T4Rs 2 10-11-2017 02:10 PM
Really dumb question GHARP57 3rd gen T4Rs 5 05-22-2015 01:40 PM
Dumb question Deathorglory 3rd gen T4Rs 11 06-05-2014 10:32 PM
Dumb Question jpintx 4th Gen T4Rs 12 03-28-2010 07:38 PM
Very Dumb Question!!! JGRIMBALL 4th Gen T4Rs 15 02-20-2004 12:23 PM
