Originally Posted by Mudflaps
Okay so I guess Im gonna go the impact route. Hopefully I can find a small enough impact wrench to fit lol. Thanks for the help, guys.
Sent from my SM-A215U using Tapatalk
Use a small 3/8" impact and you'll be able to get in there. The bolt shouldn't be that tight. When we shot the video for this job, we held one of the cam pulleys with a special tool and the belt was able to hold the crankshaft timing gear while we loosened the 19mm crank bolt. There is a chance you could skip a tooth doing this but I doubt it. Like I said, the bolt shouldn't be that tight just from turning over the engine. But, the safer option is an impact.
The crankshaft timing gear does have two threaded bolt holes which are a M6 x 1.0 thread pitch. Like Charlie said, you could make your own holder tool with some scrap metal or a piece of wood.
