Old 07-23-2021, 12:41 PM #16
Originally Posted by Doc2012 View Post
I’m running 4.88s which is good for street/weekend wheeling; I’m at 2200 RPM at 70MPH (yes, it’s correct) with 37/12.50/17.
Mathematically, 4.88's on 37's is the same as 4.10's on the stock 30.6" tires. 5.29's would be better for low end power and crawl ratio.
My impression of tire sizes:
Stock = stock
Metric "32's" = fit with no mods other than a correct alignment
33's = hope you are comfortable using a hammer or have a body lift
35's = get out the grinder and welder and the pocketbook for gears/etc.
Also keep in mind that you start losing up travel and you only gain half of the tire diameter in clearance for each size increase...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-23-2021, 01:02 PM #17
Iron duke's Avatar
Iron duke Iron duke is offline
Iron duke has a spectacular aura about Iron duke has a spectacular aura about
Iron duke's Avatar
Stock = stock
Why would I lose up travel? Couldn’t I just grind the body panels and tub the firewall to clear them at full flex?
On the subject of gears, what brand should I get if it makes a difference?
Iron duke is offline   Reply With QuoteReply With Quote
Old 07-23-2021, 02:39 PM #18
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Couple things I’ll add to keep in mind(some have been said already):
-ECGS won’t warranty their diffs above 35” tires.
-Going to want to replace/test your LBJs very often
-people have done it so it’s not impossible
-be prepared for an absolute ton of work getting them to fit (just did 35’s myself and I can see why most ppl stop at 35’s)
-highly recommend body lift 1-2”
-highly recommend wheel spacers
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 07-23-2021, 03:48 PM #19
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
I say go to 39s. It's probably going to be a same amount of cutting, body work, and moving things at that point.
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 07-23-2021, 05:09 PM #20
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
No.
And because of the Apron; unless you do a custom front end.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
Old 07-23-2021, 09:47 PM #21
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
That's not exactly accurate. In there warranty policy it states they will only honor the warranty up to 35's. In reality they will honor it up to much larger. I know guys with 38's and 40's that have had ECGS warranty failures. And yes, both of them where honest about what size tires where on their rigs.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 07-23-2021, 09:57 PM #22
rkntoy's Avatar
rkntoy rkntoy is offline
rkntoy will become famous soon enough
rkntoy's Avatar
Originally Posted by eimkeith View Post
might as well get the Solo LCAs - move the tire forward 1" and help with firewall interference some.
This
And SPC uppers
1999 Base model 4x4 3RZ 5 speed - added e-locker, front Aussie, dual cases with 4.7 front, manual hubs, Tundra/OME 861 springs, Shaved firewall (thanks Tyler James Inc), AssBurns rear links (run as 3 link),Limited interior w/ Mazda3 Grand Touring seats, Savage front and rear bumpers w/ winch, sliders, Thorley header w/ Magnaflow exhaust, SPC UCAs, 37s with 5.29 gears, roof rack and storage box, sport hood, BL and more. Linky
rkntoy is offline   Reply With QuoteReply With Quote
Old 07-23-2021, 10:49 PM #23
T4topher's Avatar
T4topher's Avatar
Arrow
I guess that’s what I should’ve said, that it mentions it in the warranty*. I think it says it’s up to their discretion or something. Good to know though! Lol.
Old 07-25-2021, 08:53 AM #24
Iron duke's Avatar
Iron duke's Avatar
Thanks for the info. I just replaced my lbj's 7500 miles ago and have a lifetime warranty on them so it gives me no excuse to let them get too far gone. Only a Autozone drive away.
Old 07-25-2021, 08:57 AM #25
Iron duke's Avatar
Iron duke's Avatar
No.
From the hub I'm gaining 1" of tire in the wheel well per perspective size. 33" to 35", and 35" to 37". It's not rubbing the apron on the 33's, so would'nt that be true of 37's with a 2" body lift?
Old 07-26-2021, 02:14 PM #26
Because the tire also moves "backwards" with increased diameter - while the body only moves up.
Old 07-26-2021, 02:30 PM #27
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
I've fit 37's on mine but as far as I can tell its easier to fit them on a 4th gen. It survived the Rubicon and Blanca Peak. Didn't have to retub the firewall just some grinding and beating with my 1.5" body lift and a +2" LT kit with heimed UCA's adjusted all the way forward.
3rd gens probably have a weight and power advantage so as far as drivetrain strength and upgrading they might actually be easier to fit. The 8" rear diff might be strong enough.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 07-27-2021, 12:23 AM #28
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
I got nothing to add. I’m just here for the insanity. Can’t even fathom what 37” tires would be like……
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 07-27-2021, 02:34 PM #29
Greeny's Avatar
Greeny Greeny is offline
Real Name: Riley
Greeny is on a distinguished road
Greeny's Avatar
Real Name: Riley
Do it, drive it, report back.
If you've got a grinder and a welder theres no reason it cant be done, just a matter of whether the pros actually outweigh the cons. You're introducing a lot more strain on a lot of parts, making the truck drive and handle worse everywhere, and you'd probably never even be able to take advantage of the bigger tires' capabilities off-road.
Greeny is offline   Reply With QuoteReply With Quote
Old 07-27-2021, 03:32 PM #30
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
I really wouldn’t want to run 37s on autozone ball joints, even with a lifetime warranty there have been reports of aftermarket ball joints failing in as little as 10k miles. With how much it will cost for the tires and regear and all the work required a set of oem ball joints and bolts isn’t very expensive
RandyBobandy is offline   Reply With QuoteReply With Quote
37’s , break , don’t , front , parts
fitting 285 75 17 BunchDub11 4th Gen T4Rs 12 08-11-2012 03:27 PM
Fitting 35's SnoYota General Discussions 8 11-13-2009 02:36 PM
Fitting a 2nd Gen A-bar fit a 3rd Gen Surf_MoFo 3rd gen T4Rs 0 09-13-2008 01:46 PM
TRD not fitting on my 05 V8 - Help! voodoodown Engines / Suspension / Wheels / Tires / Audio / Accessories 2 03-30-2006 10:52 AM
Need help on rim fitting mae.mike Gallery 0 12-27-2004 03:59 PM
