Old 07-24-2021, 11:37 AM #1
PhotoKirk's Avatar
PhotoKirk PhotoKirk is offline
PhotoKirk is on a distinguished road
PhotoKirk's Avatar
A/C blowing hot - ZERO pressure on high side
My '99 started blowing hot air out of the vents. Hooked up the manifold and got normal/low on the low side and zero on the high side. Looks like the compressor clutch isn't engaging, checked the fuse and it's good. I can spin the clutch by hand and it moves freely.
Where should I start?
PhotoKirk is offline   Reply With QuoteReply With Quote
Old 07-24-2021, 12:50 PM #2
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
Could be your low pressure safety switch has failed, unplug it and jump it with a paperclip and see if the clutch engages, if it does then you know the switch is bad
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 07-24-2021, 01:40 PM #3
PhotoKirk's Avatar
PhotoKirk's Avatar
Clutch engages, but no change in high side, low drops with RPMs.
Expansion valve?
Old 07-25-2021, 12:28 AM #4
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
if the clutch is not engaging, it is impossible for you to get pressure on the low side and no pressure on the high side. What should happen is you have the same pressure on both sides. System should be ''balanced'' since the clutch does not engage. To be clear, you should for example be reading 30 PSI on the low side and 30 psi on the high side, because the compressor did not compress.
at 20 celcius, you should have something like 70-80 psi in your system (both low and high side) if your clutch does not engage. You are probably lower than that, if it is the case, your clutch does not engage because you are low on refrigerant, which means there is a leak.
I use a cheap gas with dye and a cheap uv flashlight to find leaks.
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
Old 07-26-2021, 01:34 PM #5
azrex azrex is offline
azrex is on a distinguished road
I would guess that your coupler isn't depressing the schrader core on the high side. If you only have 30psi on the low side with the compressor not engaged, you're low on refrigerant, which means there's a leak somewhere.
azrex is offline   Reply With QuoteReply With Quote
blowing , clutch , high , hot , side
Heater only blowing warm air on drivers side wolfman13 4th Gen T4Rs 18 10-14-2023 05:30 PM
Heater blowing hot on one side 2004 Sport Amorica 4th Gen T4Rs 3 11-26-2022 06:57 PM
Front defroster blowing cold on the Driver side Rick U 5th gen T4Rs 6 09-20-2016 06:46 PM
I need high pressure ps line!!! NCrunner0 3rd gen T4Rs 1 06-16-2012 01:35 PM
