Old 07-26-2021, 09:16 AM #1
scshack scshack is offline
scshack is on a distinguished road
Successful Lift Install (Tundra Bilsteins and OME 882/891)
I wanted to share my latest success install new shocks and springs to my 2002 4runner. This setup was intended for heavy loads on both the front and the back. With this setup, I gained about 4 in of clearance (saggy old shocks and springs), but with some time and the shocks and springs are settled, it should yield around 3 in of clearance. So far it rides really smooth, much better than the OEM suspension that has most likely been.
My question to the community (and EVERYONE'S question here) is, will I be able to run 33 in tires? Should I look into getting 17 in wheels with new tires? (currently, 16 in wheels) This is an off-roading rig (non-daily) that takes some abuse and flexing without rubbing is important in this setup. I would like to avoid rubbing and I would also like to avoid cutting or hammering the pinch weld. Shoot me your thoughts. Also, let me know anything else I should do or look out for after installing this lift.
The parts installed:TOTAL COST ~$805.28
Some notes around the install:
  • Decided to hold off from installing a diff drop unless it's necessary after the truck has settled
  • Plenty of clearance from the upper control arm both internally and externally
  • Brake lines have plenty of slack, no extensions are needed
  • Currently the pictures are showing 31 in tires
  • The back is about 0.5 in higher than the front
  • The install took 5-6 hours with two people
  • Future alignment once I put around 200-300 miles on the new setup (which will add around $100 to the total cost)
    Here are a few more images around the install.
Here are some of the resources I used to install the lift:
Successful Lift Install (Tundra Bilsteins and OME 882/891)-before_after-jpg
scshack is offline   Reply With QuoteReply With Quote
Old 07-26-2021, 01:55 PM #2
32's (metric - 265-75-16 or 265-70-17) are the largest you can fit without a body lift, and even then, the front alignment and offset needs to be right.
With a body lift or some hammering in the front you can fit 33's.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 07-26-2021, 02:24 PM #3
Thanks for your response. Should I be looking into A) body lift B) some hammering, or some combo of the two? Or should I just dog my 31s and enjoy the life of no rubbing and full flex on the trails?
Old 07-27-2021, 01:18 PM #4
calimobber's Avatar
calimobber calimobber is offline
calimobber will become famous soon enough
calimobber's Avatar
Enjoy the lift and tires. Not a fan of body lifts and you dont need larger tires than that. larger tires will only kill your power and gas mileage. Ive got 285/55/16(31.7") and Ive never came accross something I wanted to get accross but could not. Easily done all the hard trails in Death Valley and places in utah Ive gone. Im not rock crawling in moab just 4x4 trails.
Ive got a very simular lift as you and never installed my diff drop. I ended up selling it new in bag.
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
Old 07-27-2021, 01:29 PM #5
Definitely get out on the trails and see what you want next instead of assuming you need more tire.
If you need more traction or diff clearance, get tires. You may find you need something else first. Maybe get sliders before tires - save that body!
Old 07-28-2021, 07:58 AM #6
This is great advice, I am painting my All-Pro rock sliders today and hopefully having them welded on before I hit the trails this weekend.
Cheers
Wheelin: 2002 SR5 3rd gen 4runner - 4wd w/ locker - ARB bumper, 10K Smittybilt winch, Victory 4x4 roof rack, All Pro Sliders, Tundra 5100, OME springs (3in lift), 31 in Kumo A/T tires (265/70/r16), Custom Rear Bumper, Full Body Armor (Front, transfer case, lower control arms, rear control arms, rear lower shocks, gas tank, rear diff) - 265K miles.
Daily: 2000 SR5 3rd gen 4runner - 4wd - Tundra 5100, OME springs (3in lift), 32 in Falken Wildpeak AT3W (275/70/r16) - 245K miles
front , install , setup , shocks , springs
Doug Thorley headers...successful install stories. Runabout36 4th Gen T4Rs 69 03-20-2024 09:01 AM
[4K] Successful AJT Designs Key Injection Fob Case Install / 5th Gen 4Runner youngwas 5th gen T4Rs 20 11-29-2018 12:35 PM
Successful Front & Rear Sway Bushing Install treverd 3rd gen T4Rs 1 07-22-2016 04:53 PM
Anyone running Tundra/Bilsteins up front for 3" lift? yota_addict 3rd gen T4Rs 14 03-12-2016 01:11 AM
Tundra Adjustable Bilsteins: amount of lift for stock height springs? Dagobah 3rd gen T4Rs 5 12-08-2012 07:15 PM
